When i turn on the screen prompts no os found
When i turn on the screen prompts operating system not found. but when i try to install os...it starts to work but after a minute a bluescreen will appear then i have to go through the same procedure again to make it work.
  • 34 Answers
Sounds like a BIOS or hard disk error. May be fixable. Download this and burn it to ISO on CD-R only, not DVD-R and run a disk recovery. Or test the disk for errors. http://www.hiren.info/pages/bootcd
download from link, follow directions carefully, make sure to burn to ISO, boot at start up and look for a recovery program.
Posted on Oct 05, 2009
    Genius:
  • 1,341 Answers
Go to bios and see if it recognizes the hard disk if not then u have a faulty hard disk.
Gateway zx4351 operating system missing
When did you get this Gateway? Where did you get it? I assume you mean that it has no OS, cause Gateway does NOT make an operating System. Need more details, please!
Nov 08, 2014 | Computers & Internet
Operating system not found
there is problem with your hard disk. your hard disk wire may be loose. try to remove and refix all sata wires of your hard disk. "operating system not found" message may be coming because you may have not installed any os (windows, linux or mac) in your notebook. try to install operating to system to fix this. there may also be proble with your hard disk, your hard disk may be dead. if your notebook is showing message "operating system not found" without any reason then you may have put your notebook in high magnetic field area. due to high magnetic field, sometimes hard disk's are formatted automatically.
Apr 10, 2013 | Samsung N150 Notebook
No operating system not found comes up. It is a
You must install your OS (Windows XP, Vista, Windows 7, etc....)
Nov 21, 2009 | Sony VAIO VGN-BX760NS2 Notebook
Computer wont start up...
It means it cannot find it's operating system or windows to start. When a PC boots it checks for boot devices, usually the floppy, then cdrom, then hard drive, if there is a disk in the floppy or if your pc is set to boot from cdrom and there is a disc in it - it will say OS not found.
The second possible cause is something has happened to windows - either the hard drive has failed or windows has lost it's startup files. If the drive appears to be normal and chatters slightly on startup ( a light clicking noise) then possibly running the original windows install disc and reinstallin windows should fix the problem, on 98 or ME you can re-install, on 2000 or XP try the recover/repair option first.
Oct 26, 2009 | Computers & Internet
There is no bios setting comes and also no operating system found message come and also format not star
Every computer needs a BIOS and an Operating System. The key combination to get to the BIOS is displayed on the screen for a couple of seconds at system startup. If you fail to press those keys the computer will try to start any existing OS. If no OS is found then you MUST install one to use your computer.
Oct 07, 2009 | Toshiba Satellite M100 Notebook
Operating System not found! HELP!
If you are running windows, Insert your windows cd and set computer to start from cd. When prompted to, hit a key to boot from CD. Let Windows start the install (relax it is not really installing anything) when it gets to the prompt tell it you want to Repair an existing installation. Then pick the prompt that gets you the recovery console. When you get to the prompt type CHKDSK /R and let it run. Sometimes this can take an hour or more depending on the size of your drive. Do not get worried if the percentages complete go backwards, like from 70% back to 50%. Sometimes it will go back and fix files. Hopefully you will not get the error that there are unrecoverable errors. This has worked for me on about 90% of the hard drives that I received the inaccessible boot device and about 30% of the drives where it said OS not found. If this does not work your hard drive may have failed. Let us know.
May 04, 2009 | Computers & Internet
Ibm thinkpad prompt: operating system not found.
that message means that windows 2000 professional/98 is not installed which means you have a blank computer you need to put the disk that came with it in and install the OS or purchase one but i'll warn you now those disk are not cheap around a couple hundred bucks
Apr 06, 2009 | IBM ThinkPad T21 2647 Notebook
Please help in need of a mirical
try in safe mode,if the problem persist you have to repair or reinstall the os
Apr 26, 2008 | Toshiba Satellite A55-S106 Notebook
Intel Pentium IV Trouble (40gig)
os not found usually means that your hd is faulty.
try remove hd and reseat it.
if no joy have os disk(windows) in cd drive start pc and boot from disk.
select install windows...system checks drive and informs of existing os..want to continue...install windows...next screen shows partitions.choose to delete partition then create new then format and install.
if when u try to boot from disk system say no hd found then hd is damaged.
Mar 14, 2008 | Computers & Internet
Operating system not found? I have got Windows Boot Genius to fix problem safely!
Oct 14, 2007 | Fujitsu Siemens LifeBook S-6000 Notebook
Computers & Internet Logo
163 people viewed this question
David Payne
David Payne
