Question about Apple (661-2795) for iMac Motherboard
Graphic chip wonky on C2Duo 2.13 - 2007? Lines and artifact on screen. Runs 20 minutes or so and locks up - requires reboot.
  • 212 Answers
I would think your graphics card is overheating. is the problem there when you just start the pc or does it only come after a few minutes?
Posted on Oct 05, 2009
Does rebooting help fix pc game issues
The game usually comes with a minimum spec for the computer. The game may require better graphics or more memory. What is the game? What is the computer? Are you saying the game runs fine in WinXP/Win7 but not win 8?
Rebooting will only help fix an issue if the computer has been bogged down by a program (or programs) that are misbehaving. If you have a game that requires all your PC to run, you can try quitting everything that runs in the background.
Most games have options you can also tweak. Try selecting a lower screen size, lower graphic details,etc ..
Nov 29, 2014 | Video Game Consoles & Games
Samsung grand stuck at Android system recovery 3e and even after rebooting it getting there only
Try doing this
fortunately you will lose everything on your device unless you have it backup
  1. Press and hold Power key + Home or your volume buttons to power on the phone and bring up a triangle with an exclamation point inside next to a green Android graphic.
    The background should be black and the lettering blue
  2. use Volume buttons to scroll up or down Highlight "wipe data/factory reset"
  3. Press the power button to confirm
  4. Handset will ask you to "Confirm wipe of all user data"
  5. Select "Yes -- delete all user data"
  6. Press power button "Ok" screen prompt to start wipeout of phone, handset will begin to format handset showing progress with multiple lines of ellipses (....)
  7. Handset may take from 5-20 minutes to format.
  8. When format is complete, press power button "Ok" screen when prompted to reboot (Reboot system now will be highlighted)
  9. You will see either an open box and the green android graphic when handset is rebooting
  10. Handset will be cleared of previous personal data, and you will need to start over with initial set-up process.
Nov 02, 2013 | Samsung Galaxy Grand unlocked
My Droid x hd is frozen and I can't get a response
Remove the backing of the phone and pull out the battery. Then put the battery back in and turn on the phone. If remove the battery isnt an option,
1. Turn off phone
2. Press and hold Power key + Home hard key to power on the phone and bring up a triangle with an exclamation point inside next to a green Android graphic.
3. Press Search hard key (only froyo 2.2) to show the Android recovery menu. ( for firmware 2.3 Gingerbread Press both Volume buttons)
4. Tap to select "wipe data/factory reset" (you can also use Volume buttons to scroll up or down in this menu)
5. Press Menu hard key under "Ok" screen prompt (camera button can also be used to confirm selection)
6. Handset will ask you to "Confirm wipe of all user data"
7. Select "Yes -- delete all user data"
8. Press Menu hard key under "Ok" screen prompt to start wipeout of phone, handset will begin to format handset showing progress with multiple lines of ellipses (....) (camera button can also be used to confirm selection)
9. Handset may take from 5-20 minutes to format.
10. When format is complete, press Menu hard key under "Ok" screen (or use the camera button) when prompted to reboot (Reboot system now will be highlighted)
11. You will see either an open box and the green android graphic when handset is rebooting (or the red DROID eye graphic).
12. Handset will be cleared of previous personal data, and you will need to start over with initial set-up process.
Sadly thats the only process which includes wiping contacts etc. and last alternative.
Oct 20, 2013 | Cell Phones
Troubleshooting droid
1. Turn off phone
Dell Inspiron 6400
If you get the erroneous characters in the set-up (BIOS) screen on external monitor, then either your graphics card is defective or the motherboard. The diagnostics are just reporting that it cannot detect the LED display. Unfortunately the only way to determine if the graphics card is defective is to replace it. If that does not resolve the problem then you know it's your motherboard. That whole process can be costly. That model laptop is about 5 years old and parts could run you about $100 to $300 online. Might be time to shop around for a new one.
Feb 12, 2013 | Dell Inspiron 6400 Notebook
WHEN PLAYING GAMES A WHOLE LOT OF COLOURFUL LINES AND BLOBS POP UP WHAT COULD BE THE PROBLEM
your graphic card is low you need to upgrade in order to play games with higher graphics
Apr 27, 2010 | ASUS A9600GE/TD RADEON 9600, (128 MB)...
Colored dotted lines across the screen
If you understand the components of a computer pretty well, open the case and remove and reseat the graphics card into the slot.
Does it seem to only do it after so long, for example turn the computer of for a few hours, and it wont happen when its first turned on, but then a few moments later it starts after its warmed up?
If this does not resolve the issue, you may be experiencing graphic artifacts which can occur when a gpu is overheating due to a poor cooler. Check to make sure the heatsink is touching the gpu.
Artifacts: http://www.playtool.com/pages/artifacts/badgpu.jpg
Apr 20, 2009 | XFX GeForce 6200 Graphic Card
Display issues for NX7010 Compaq laptop
Try to plug in an other screen......(graphic component problable shot)
Feb 27, 2009 | HP Compaq nx7010 Notebook
Problem
uninstall ALL video drivers reboot computer should reboot with standard windows video drivers does the screen still play up if so you may have faulty video card.let me know please
Jul 17, 2008 | ATI Mobility RADEON Graphic Card
Vertical lines and purple artifacts when the camera is aimed at bright subjects
Current LCD display technology can reproduce about 300 different levels of brightness. Brightly lit scenes or light sources may exceed this brightness range, causing a temporary disruption (artifacts) in the live display. Artifacts are part of the display, but they are not part of your recorded image. If you take a picture while you see artifacts on the screen and then display the picture on the LCD, you will no longer see the artifacts.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Apple (661-2795) for iMac Motherboard Logo
69 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
