Question about Canon PIXMA MP160 All-In-One Printer
Canon printer flashes "e" then "2" twice?
When i turn on printer it is fine for about 20 seconds Then it says "E" then "2" twice. i have tried greasing and cleaning the slider thing. still doesnt work. what do i grease it with is there a special grease. i also get a erorr 5100 on my xp window. what is wrong and how do i fix it? thanks
    Scholar:
  • 81 Answers
A sensor in the printer is reporting that one of the print cartridges has been incorrectly installed.
Quickest solution is to power off the printer, remove each cartridge, ensure all packaging has been completely removed and then reinstall the cartridges and power back up.
Posted on Oct 05, 2009
    President:
  • 787 Answers
It's E22.This is Carriage error.
Posted on Oct 13, 2009
Canon ip90 printing
Internal battery needs replacement
Oct 19, 2013 | Canon S Office Equipment & Supplies
Canon mp287 error 5B00?
hi me uttam jaiswal i have instaled MP287 inkjet but i have problem P07 get any solution
May 20, 2012 | Canon Office Equipment & Supplies
Cannon mp170 orange light flashes twice then pauses then flashes twice and so on i cant get my printer to do anything
Try resetting the printer:
1 - power off.
2 - hold stop/reset ,hold ON/OFF
3 - release stop/reset, push stop/reset twice, quickly, then release ON/OFF
4 - wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
5 - then push power twice, quickly
6 - power off and power on.
Nov 27, 2011 | Canon PIXMA MP170 All-In-One InkJet...
I have a canon pixma mp250 and error P07 flashing.Now,I refill blac and colour cartridges,and clean ink absorber,but still flashing P07.How to reset printer? Best regards, Misko
its mean absorber full..(i think)
Check this steps :
1: Unplug power and USB
2: Open door and hold power button.
3: Connect power.
4: Close door, then release power button
5: Connect USB and an press power to use.
1 Press the power button to turn off the printer.
  • 2 Hold the "Stop/Reset" button while pushing the power button. While still holding down the power button, release the "Stop/Reset" button and then push it twice in a row.
  • 3 Wait approximately 20 to 30 seconds until the LED shows 0.
  • 4 Push the "Stop/Reset" button four times in a row.
  • 5 Push the power button twice.
  • 6 Turn off the printer by pushing the power button one more time. The printer is now reset. Next comes resetting the counter on the cartridge.
  • 7 Unplug the power and the USB cables from the printer.
  • 8 Open the cartridge door and hold down the power button.
  • 9 Reconnect the power cables while still holding down the power button.
  • 10 Close the cartridge door and release the power button. The ink cartridge is now reset.
  • Aug 11, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
    My Canon MP210 printer is showing error 3, stuck paper, there is no paper that I can see. Please help!
    Try this:
    Hold the RESET button then press POWER. While POWER button is pressed, release the Reset. Press Reset twice (always with Power keep pressed)
    Release Power. You are now in Service Mode Menu 2.
    * Wait until Power light turns to Green
    * Press Stop/Reset three times within 3 seconds between each press.
    * Press Power once to Set data. Now the light should change color.
    * Open the printer and remove the ink tanks. The printer should be in replace mode.
    * Reinsert the ink tanks.
    * Close the printer and wait 20 - 30 secs.
    * Press Power to shutdown the printer.
    * Turn On the printer the 2 ink levels should be reset. Error should be removed. Source(s): http://www.toner2ink.com/
    May 30, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
    Open the top cover and insert a toner cartridge. message shows when i try to print but top cover already closed properly
    check on the left hand side of where the top cover opens , in the inside there is a clip along with a senor
    check that it si not stuck . if that doesn't work, open the top cover hold in the cancel button or the bigger play button ( differs printer to printer ) or both for approx 10 - 20 seconds , you will see all the lights flash remove the toner , re-insert the toner & close the top cover . This will reset the drum unit & the printer status. Alternativly switch the printer off ( with top cover closed ) hold in one or both buttons and turn it on for approx 10 - 20 seconds again , you will again see all the lights flash, Your printer will reset its status And clear its page count .
    also try open the back cover close the front then the back , press cancel or play button twice there after.
    ( this is a common diagnostic procedure with small laser printers )\
    Please post back if this doent solve the issue
    Thanx
    May 27, 2011 | Canon LASER SHOT LBP-2900 Printer
    How to repaire canon MP 510 error, wen turn printer on in the lcd diplay get message : error service required 5800
    Welcome to Fixya.
    Please try the following steps to resolve this problem - this same procedure worked for my colleague :
    • Power off printer
    • Hold down STOP/RESET button then Press and Hold down Power button
    • Keep Power button down and Release STOP/RESET button
    • Push STOP/RESET button twice
    • let go of power button
    • Wait 20-30 seconds - my display shows "canon Idle"
    • Then Push STOP/RESET button four times
    • Push Power button twice
    • Power off (shut printer down)
    • Wait for at least 5 seconds and power it back on
    This should do the trick and will get you printing again in no time.
    Thanks for using Fixya.
    May 25, 2011 | Canon PIXMA MP510 All-In-One InkJet...
    I am trying to print a document on my computer and I am receiving error 5100. On the little screen on my printer it is either flashing a the number 2 or an upper case E I have a canon PIXMA MP150 all in...
    1 Unplug the printer for at least 2 minutes from the wall.
    2. Plug the printer back in but leave the printer turned off. 3. Enter Service Mode
    a. Hold Stop/Reset button and the Power button for 5 seconds
    b. Release Stop/Reset button but continue to hold Power button
    c. Press Stop/Reset twice
    d. Release the Power Button
    e. Wait for the light to stop flashing. The printer is now in service mode. The display may be blank or simply read "Canon" during this time.
    4. Do an EPROM reset.
    a. Press the Stop/Reset button 3 times.
    b. Press the Power button twice. The printer will save the changes and then it will reboot. A little cd/dvd icon will appear in the LCD screen.
    3. The printer will probably now require the same setting up as when you first unpacked it. That is, you will need to select a language and let the printer do a head alignment.
    The printer is now enabled.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Dec 19, 2010 | Canon PIXMA MP150 All-In-One InkJet...
    I have refilled my color ink. After it prints 20 pages it lights up the "color ink" button meaning it's out of ink and starts printing poorly. I tried refilling twice with new ink - same thing happened.
    Try this, it will reset your counter.
    Power off printer
    Wait 20-30 seconds - our LED showed Idle
    Power off
    Next time the printer is started the waste count will have been reset
    Sep 12, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
    Canon I850 won't print , it has a green light for about 2 seconds then flashes a yellow light for about 6 seconds
    Hi there
    This is only a try it may do it but I not know,
    Start with the printer OFF
    1. Hold down RESUME and then hold down POWER
    2. Release RESUME
    3. Press RESUME twice, then release POWER
    4. Let green light blink until printer is done futzing
    Select function with RESUME press POWER to execute:
    presses - light color - function
    Number of presses - light color - function
    0 presses - green - Test print (or exit service mode on i850)
    1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
    2 presses - green - EEPROM initialize
    3 presses - orange - Reset waste ink counter
    Jan 19, 2010 | Canon i850 InkJet Photo Printer
    Canon PIXMA  MP160 All-In-One Printer Logo
    128 people viewed this question
    old marine
    old marine
