Question about Brother Disney ULT-2002D
When I attach the 4x4 or 6x10 hoop to my brother 2002d it says no hoop is there, I replace the sensor ( the part with the little tabs) and it still says no hoops attached
dupina
  • 110 Answers
SOURCE: Husqvarna Des 1.. won't recognize hoops
The embroidery unit needs to be calibrated. Can only been done by a trained dealer. you can relax, it is not a major issue and shuold not cost you a arm and a leg. Ask the dealer to also calibrate your touch screen and download the working hours on your machine.
Regards
dupina
Posted on Dec 12, 2007
SOURCE: Singer Quantum Futura CE-200 Problem
My machine did the same thing. I had several frustrated nights ans then it just started to work. Some suggestions that I had was that there may be dust where the units connect. Not sure what I did, but it worked.
Posted on Jan 02, 2008
  • 185 Answers
SOURCE: 180E Hoop problem
Joan, there are 3 micrositches on your embroidery unit arm. these switches are depressed when you attach the hoops, it appears from your comments that one switch is not functioning. This could be simple, it is out of alignment or more complex it is broken. Either way you need to take it to a professional for repair.
Posted on Feb 25, 2008
maklean
  • 1665 Answers
SOURCE: Mega hoops
have a look at link below
http://www.berninausa.com/media/knowledgebase/a200/projects/pdf/EmbroideryWithArtista/embwa0008_9d5b.pdf
Does it help?
Posted on Apr 06, 2008
SOURCE: how to repair a brother 4000d hoop screw
check with brother customer service about the parts you need
or
sewingpartsonline.com
Posted on Mar 31, 2012
How do I format a floppy disk for use in a Brother ULT 2002D Embroidery Machine
Contact Brother Online Service. They can direct you best.
Nov 17, 2014 | Sewing Machines
When I install embroidery hoop light keeps blinking n saying wrong hoop size looked it up n it's saying malfunction
Ok, there are a couple of possibilities, and I'm going to include an image. I"m not sure whether you're trying to use the small or large hoop, but the first thing you should try is turn off the machine, take the hoop off entirely, then turn on the machine without anything and let it reset to its default position, which will be the center. If it has a problem there, make sure the needle it at its highest position.
Next, put the large hoop on, bring up a design, (preferably a design that came with your machine--there are sample designs in the \Library directory where the program is--that's generally in c:\program files\futuraquartet--and is designed for the hoop you're trying to use, and transmit to machine. If it tells you the hoop is the wrong size, download a patch from www.futura-support.com. If it STILL tells you you have the wrong size, reseat your USB cable into the machine and tape it in place with masking or duct tape.
The third possibility--and the one pictured in the photo I'm going to attach--is there is a tab on your hoop which indicates the hoop size, and your TAB may be off. It needs to be dead center of the sensor, which is also pictured. A while ago a BUNCH of hoops were manufactured with the tabs slightly off, and if it's off, your machine can't read the size. What generally happens there, though, is it will indicate that there is NO hoop attached, rather than the wrong size.
You can see the sensors--they're inside the arm where you put your hoop, and they're not covered up. Below it are the large hoop (top), and small hoop (bottom). The hoop tabs have to match up to the sensors exactly, and you'll be able to see if it doesn't by matching up the notch in the hoop that matches the catch in the embroidery arm.
Oct 20, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
Futura xl 400
There are a couple of things to check. First, check to make sure that your machine is on a solid flat and level surface. If the surface is even slightly sagging, your connectors may not be making a complete connection.
Next, you cannot put your small hoop on the machine and turn it on; it will not allow the machine to go to its default position. Turn it on without any hoop attached.
Next, take a look inside the unit where you slide in the hoop. About midway up, you will see three black rectangles in a row; those are the hoop sensors. Those sensors have little plastic "feelers" sticking out to touch a corresponding tab on the hoop to indicated which size of hoop is attached. You can see them if you look sideways. If one or more of those feelers is not sticking straight out, it will cause this problem. GENTLY run your finger over them (you don't want them to break), and make sure that they ARE sticking straight out.
Jul 14, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
Can the brother pacesetter ult 2002d floppy drive be replaced with usb
Julie, You should be able to have that on-board floppy drive repaired. USB is from a computer only to send a design to the machine.
Cheers,
Embroidery Services
San Diego, CA
Jul 23, 2012 | Brother Disney ULT-2002D
What type of bobbin is used for the Brother DIsney ULT-2002D? I see L and A types.
For the price of them - try buying both, then buy more of the one that works best.
Dec 27, 2010 | Brother Disney ULT-2002D
Where can I get a power cord for my Brother Pacestter ULT 2002D? I have moved and can"t find mine. I'm going crazy!
There's a place online called Sewing Parts online.
I saw them tonight while looking for another part for my ULT.
Their prices are good.
Nov 14, 2010 | Brother Disney ULT-2002D
Machine not sensing embroidery frame
Depending on your model of machine this problem is solved by replacing the hoop attachment unit on the hooping arm. (hoop sensor cable is not properly welded)
Jan 14, 2010 | Brother Sewing Machines
Needle plate ?
Check this link:
http://www.google.com/products?hl=en&q=ULT%202002D%20needle%20plate&um=1&ie=UTF-8&sa=N&tab=wf
Feb 26, 2009 | Brother Disney ULT-2002D
Sewing Machines Logo
63 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
