Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Ice dispenses rusty, because of rusty blade.. is there replacement that doesnt rust
  • 3,600 Answers
Yes you can go tothis web site and buy the blade then buy a can of food grade zinc to spray on it before use. the web site is http://www.appliancepartspros.com/ if you need hel let me know and I wll give you detailed device.
Posted on Oct 05, 2009
Dispenses crushed ice only, not cubed
remove the dispenser bucket where the ice drops into inside the freezer and get a Tupper ware bowl,remove the bucket and dump this ice into the bowl,then rinse with the dispenser bucket with warm tap water to melt any ice on each end of this ice maker,then wipe dry and replace into freezer where you removed it to get cold again and leave empty till the next harvest of ice,this can be normal on some units after so many weeks,as it will not let the blades retract so as just to dispense only cubes,once bucket is cleaned of ice jams the solenoid and blades will again retract for cubes only
Feb 10, 2013 | Refrigerators
Ge profile artica ice dispenser and chute frosing.
This may be because the chute door is not all the way shut when off. If yes the warm moist air is being pulled through the opening and causing this. Sea Breeze
Oct 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice machine not working
inside your dispenser, on the front door it is solenoid valve, it got rusty and stock slosed so you need to replaced it....it is a common problem for GE Profile..about $20 for part can be messy but i hope you can handle it
Aug 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice dispenser has rust
The rust will conterminate your ice, please have the spiral ice dispenser replaced.
Jul 30, 2009 | GE Profile Performance 25.2 cu. ft....
RUST ON DOOR UNDER DISPENSER
THE HIDDEN SCREWS UNDER THE DISPENSER TRAY ARE NOT STAINLESS STEEL
ONLY WAY TO SOLVE THIS IS TO KEEP AREA DRY
OR TO REPLACE SCREWS WITH STAINLESS STEEL ONES
May 26, 2009 | Refrigerators
GE model # GSS25KGMC WW
  1. There is a solenoid that operates the trap door. When the lever is pressed to get ice, the solenoid operates and there is a plunger mechanism that pulls a metal pin into the solenoid. When I took mine apart I found the pin rusty which hangs up in the sleave of the solenoid. I tried cleaning the rust off with steelwool but it just rusted a month later and is now hanging up again. I may reclean the rust and spray it with silicon spray. Most likely I will need to replace the solenoid. It is located behind the touch panel. To remove there are 3 small holes just underneath the lip of the touch panel that you must push a small screwdriver or pin of some type through the holes to release the latch for the the front touch panel. Pull the touch panel toward you while pushing on the latch. You will then be able to see the rest of it.
May 24, 2009 | KitchenAid Superba Architect KSCS25INSS...
Frosty Ice dispenser
you need the flap in the dispenser replaced ,,, you can get a door flap kit to fix it ,,, i know cause i still have one here from when i closed my shop ,,, if flap isnt closing tight the air goes in and it frost up the opening and dispenser / larry
Dec 08, 2008 | Frigidaire FRS3R5EMB Side by Side...
WATER & ICE DISPENSER HAVE ALWAYS STAINED A DIRTY RUSTY STAIN
please send $19.95 AND i WILL SEND YOU DETAILED INFORMATION ON A UNIQUE SOLUTION
Sep 04, 2008 | Whirlpool Refrigerators
Rust in washer
hi. thanks for the question .. well i would call this its final breath . the bearings are going. that's the rust y pieces .its time to go thanks the appliance doc
Sep 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
69 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
