Question about Samsung VR8460 VHS/S-VHS playback VCR
Does this vcr record also? does it have a tv tuner
  • 934 Answers
Thisd unit has both record and PB features and an analog tuner. So if you're using it on a regular stick antenna you will require a converter box if you're using it as a tuner. Otherwise, cable or sat it will work just fine.
William Rayburn, CET
Premium Technologies
Posted on Oct 05, 2009
Have just retuned digital terrestrial receiver Matsui DTR -2 for our area, how do I now record tv programmes with my Bush VCR925NSILXI? On analogue TV the recording channel was Channel 9
Recording, amazingly, has nothing to do with your TV, it only monitors the playback or recording input of your VCR or DVD recorder - the Channel 9 you mention.
They have their own tuners, indeed DVD recorders have Freeview (or DTV) tuners so no need for a separate box at all - given that your TV has a DTV tuner too and if a recent flat screen type it will.
If you can afford it, this is a good time to drop VHS and get a DVD recorder. You'll find plenty on Amazon Electronics for a start.
Your Bush VCR will be redundant the moment the analogue service goes off, they haven't made a VHS VCR with a DTV tuner.
Depending on your area this is a few months off, even for the last area to change over anyway, here in London there's just shy of nine months left.
Sep 21, 2011 | Televison & Video
How do I connect my Sansui 6010B VCR with an analog TV and a DTV tuner?
two ways of connecting VCR with Analog TV with DTV tuner.
DTV tuner (RF) output to VCR (RF) input,VCR (RF) output to analog TV (RF) input.
turn DTV tuner on (VCR should have a TV\VCR switch that makes signal coming from tuner BYPASS VHS right into TV) note:: change channel FROM tuner.You should be able to record by placing a blank tape and pressing RECORD.
2ND. DTV tuner, VCR, should have a RCA in\out connections...Audio & video.You need a RF\RCA bypass switch. It has a INput with RCA connections to a RF signal out that goes to the RF Input of analog TV
Jun 21, 2011 | Sansui VHF6010 VHS VCR
I have an Alba 32880hdf freeview tv. I cannot record freeview programmes to my panasonic NV-FJ 780 vcr which has 2 scart sockets. I have no problem recording the teresteral channels. Can you help pls
Hi Victor,
You can't record the Freeview channels from the TV. It doesn't work that way. The reason you can still record terrestrial channels is because the VCR is still connected to your roof aerial with a co-axial cable and the VCR has its own built-in analogue tuner for recording terrestrial TV programmes.
To record the digital Freeview channels, you will either need to connect a separate Freeview set-top box to the VCR, or buy a VCR which has a built-in digital (DVB-T) tuner.
The VCR does not record programmes from the TV. It needs to be connected directly to the signal source, i.e. your aerial.
If you need any further assistance, please let me know.
Regards,
BElectric
Jan 15, 2011 | Televison & Video
I have a new digital tv in which i use an antenna to watch it. i hooked up the vcr to it but i cant get it to record the tv show i want recorded.
Your VCR most likely does not have a digital TV tuner. Therefore you must supply a digital TV input signal so you can record it. Unless your TV has a composite video output, you would need another box, namely a digital TV tuner/converter which would connect to the VCR's input. Select the channel to record on the tuner/converter and select on the VCR the input where the tuner is connected.
Aug 14, 2010 | Sony SLV-N71 VCR
Connect VCR without tuner to record from television
If it has a scart, you can get a scart lead to connect it to your TV. You would need to set the VCR to the Scart socket, IE: AV1 etc.. to record. You wouldn't be able to change channel on the TV, to watch another channel while recording though. If you had a set-top box, you could connect that up to the scart of the video then record, while you watched another channel on your TV.
Feb 06, 2010 | Televison & Video
Play & Record VHS through TV Tuner Card
You need to connect the ariel to the vcr, then the vcr to the card, using a male/female fly lead. Then I suggest putting an origional film tape into the vcr, press play on the vcr and then scan in the channels on the card. It should pick up the vcr's output of the film that is playing.
Jun 05, 2009 | HP Expresscard TV Tuner For Windows Vista...
Vcr/dvd combo recording problems
You can use a normal set top box, plugged into the AV inputs on the combo, you could even use a seperate VCR for this, as long as it's recieving the signal you want to record.
Apr 21, 2009 | Toshiba SD-V295
External Tuner Device for VCR/DVD player
Just pick up an old used VCR that has a tuner built in. Only the very new ones don't have them (due to the DTV switch coming up in February).
Sep 09, 2008 | Philips Televison & Video
VCR to TV
Your FIOS box is typically a Motorola Digital Cable Tuner. In order to record from the VCR your FISO will have control of the tuner, not the vcr. If your FIOS has two video outputs on it for video (av connections), one should be plugged into you tv set and the other should be plugged into the VCR input. Your cable tuner will have to be set for the channel you wish to record ahead of time while the VCR tuner has to be set to record the line input at whatever time you wish to record. If your FISO has one video output line (av connections), your VCR has to be set to channel 3 when you record (provided that is the channel your FISO box is set for when viewing TV over the coax cable) and you will have to attach the coaxial output from the FISO into the coax input of your VCR.
The only way around this is to get a splitter and split the coax line so that the FIOS is connected to the coax as it is now and the VCR is connected to a seperate line using the coax input, however using this configuration will prevent you from recording digital channels. If you have a cable ready VCR, it will probably only recognize channels up to 150.
If you really want to get it to record digital channels without the hassles find out if Verizon has a FISO box with DVR to it or connect a Tivo to your FISO. Tivo will tune the FSIO when it records and it's very user friendly to use.
Jul 28, 2008 | Sanyo DVW-5000 DVD Player/VCR
I can not record any tv programs because my vcr does not have a internal tuner so how can i fix this problem?
If the VCR has no tuner, you must have another tuner connected (such as a cable or satellite box) in order to be able to record anything. This tuner will then select the channel to be recorded.
Apr 21, 2008 | Televison & Video
Samsung VR8460 VHS/S-VHS playback VCR Logo
100 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
