Question about ASUS p4p8x-uay Motherboard
2 short 6 long beeps, whats the problem? nothing on screen, no other signs.
  • fkhouck
    fkhouck Dec 28, 2012
    2 beeps then 6.... then nothing. apparently the first check was for a faulty keyboad. who would have thought. removed the keyboard and everything was fine.
    Guru:
  • 126 Answers
Check your VGA Card it's properly connect and your memory module, maybe one of that is not functioning.
If still have that beeps then change temporarily your VGA Card with another. As long as you see some appears on the screen then it's good luck.
Please rate us!
Posted on Oct 05, 2009
  • 788 Answers
First check out the power supply connection,
besides that main power cord (20pin or 24pin), the 4pin 12V cord is also need to be connected.
If power connection is correct,
Please take the cpu cooler out, add some thermal paste to the CPU surface, then reseat thecooler back and keep the cooler tightly installed.
Then, please remove memory from the board,
and clear CMOS by:
1. Cut the power supply for whole system and open your case;
2. Take out the Cmos battery from the battery socket;
3. Install your battery with "reverse side" that means turn the battery 180 degree and put in into battery socket;
4. Hold about 30 seconds, then take out the battery and install it normally;
5. Plug the power cord and Power on.
If you can hear beeps, board maybe is still functional,
if no beeps from case speaker,
please test your CPU on another working board,
once CPU is tested OK, board should be dead.
I have checked all standard BIOS for the beep codes you have given and can't find anything close.
Start from scratch.
Look at your board and the power caps. for bulging or crowning.
Next, memory one at a time.
Good luck, hope this has helped
    New Friend:
Asus 2 beeps then 6 then nothing. Apparently the first bios check is for a faulty keyboard. Removed it and everything was fine.
Posted on Dec 28, 2012
  • fkhouck
    It didn't care thaat there was no keyboard, but it didn't like one that didn't work. If I have a problem like this again, I will unpug all external devices before I do anything.
  • 448 Answers
Before I did anything else, I would remove and reseat the memory chips (with the machine turned off, of course). 2 short beeps on a Asus typically means a memory problem.
    Problem Solver:
  • 9 Answers
Give the bios battery a good look to make sure it is not dead or not connected well. If that does not help then it is not happy with something plugged into it. pull the video card and see if the beeps are the same. then try each stick of memory one by one and so on till it makes a different sound.
2 Suggested Answers
gvctts
  • 103 Answers
SOURCE: asus p4p800-vm 2 beeps then 6 beeps
This is RAM problem, your RAM is not working well. please replace RAMs then check it will work fine..
Please dont forget to rank my answer
Posted on Sep 05, 2009
I'm hoping maybe you can help me! I have a Foxconn A79A-3 mobo and I'm getting the "beeps" I get nothing from my computer screens when powering on. It does 2 fast with not much time inbetween them,...
No beeps Short, no power, bad CPU or motherboard, or the CPU is not installed properly. One long beep, then two short beeps Video problem Continuous hi-lo beeps CPU overheating Repeated long beeps Memory error All other beeps Memory related error
Aug 26, 2010 | Computers & Internet
3 medium beeps on pc; repeating
Hi John. If you already swaped the Memory, it's the video card. I'm giving you what the beep means according to the different types of BIOS, because basically Ascent is a clone PC. I hope it helps.
(you will have to open the computer to see the BIOS type.)
BIOS AWARD
1 long beep and 2 shorts -- Video error
2 short beeps -- non-fatal error.
1 beep corto -- OK.
BIOS AMI
1 short beep -- Memory error.
2 short beeps -- ECC error.
3 short beeps -- Memory error.
4 short beeps -- change atery
5 beeps cortos -- bad processor.
6 beeps cortos -- bad keyboard.
7 beeps cortos -- video memory bad.
8 beeps cortos -- video bad.
BIOS PHOENIX
1-1-2 beeps -- Problem with cpu/motherboard.
1-1-3 beeps -- Cmos issue.
3-4-1 beeps -- Video issue.
BIOS IBM
1 short beep -- Post normal, ok!.
2 short beeps -- POST error, will show on screen.
NO beep -- CPU issue or Expansion card issue
1 long and 1 short -- motherboard error.
1 long and 2 shorts -- Video issue.
1 long and 3 shorts --EGA video issue.
3 longs -- Keyboard error.
Apr 29, 2010 | Systemax Ascent Pro A20 (988185) PC...
Asus p4p800-vm 2 beeps then 6 beeps
Sep 05, 2009 | ASUS P4P800-VM Motherboard
Turn it on it beeps cdc
You really aren't giving much info, so here are some beep - codes, also make sure nothing came loose on the motherboard or other components ( do this ONLY if you know how ) Safety first.
BIOS Beep Sound core list
AWARD BIOS
1 short(Beep) System booting is normally.
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM hasn't inset correctly.
Short(Beep) continuous POWER supply has problem.
AMI BIOS
1 short(Beep) DRAM Flash Error
2 short(Beep) DRAM ECC Check Error
3 short(Beep) DRAM Detect Fail
5 short(Beep) CPU Error
6 short(Beep) Keyboard Error
8 short(Beep) Display card memory Error
1 long - 3 short(Beep) DRAM Damage
1 long - 8 short(Beep) Display card or monitor connected error
Jul 16, 2009 | E-Machines T6520 PC Desktop
PC will not start
This sounds like a memory error, can you define the beeps. There is a thing called a "beep code" on all motherboards, the website for the motherboard defines what the beeps mean. For example: one long beep followed by two short beeps of continous spaced beeps without a break. chris http://www.motherboardsrus.net
Jun 06, 2009 | Dell Precision Workstation 670 PC Desktop
My dell dimension 2400 beeps morse code like and won't load
you have to follow the beeps very well to understand wat is the problem, each type of beep gives you sign for problem. so check if its one beep, two, or three, short or long, this makes very easy to you to define the problem.
Try to take out that parallel port if your pc works fine, this means this connector was not compitable to your board.
Best regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Feb 28, 2009 | Dell Dimension 2400 PC Desktop
Screen won't appear upon start up and I get 3 beeps but no screen
what you are hearing is a beep code, if its 3 short beeps then its the memory which has developed a fault and it may need to be replaced
Nov 16, 2008 | Acer Aspire 5100 Notebook
Beeps
Standard Original IBM POST Error Codes
Code Description
1 short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
For more info go here: http://pulonangka.web.id/software/beep-codes-error-codes
Aug 16, 2008 | Dell XPS M1530 Notebook
Dell dimension E310 crash
  • Bad video card - 1 long and 2 short beeps
  • Bad power supply - 1) continuous beeps, 2) non-stop short beeps
  • Bad memory - 3 short beeps
  • Bad Motherboard - 1 long and 1 short beep
  • Disk drive related problem / Video card problem - 1 short beep then nothing happens
May 02, 2008 | Computers & Internet
ASUS p4p8x-uay Motherboard Logo
1,107 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
