Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
Rotating bruch My vaccum brush will not turn. This happened after sucking up a cord that wrapped arou8nd the brush. I was able to pull the cord back out but now the brush will not turn. The vaccum does turn on an sounds like it is working with no soinning brush.
    Uploaded 5 video answers.
  • 152 Answers
Re: Rotating bruch
Take off the bottom cover where the roller brush is a few screws should be all it takes underneath cover should be roller and belt if belt is broke replace it lift up roller there is a slot for the belt to run in put other end should be the motor side put belt around pulley bar put it back the same way it came off.
hope this helps
Posted on Jan 06, 2008
0 characters
3 Points
The cord to my window blinds accidentally got sucked up by my Dyson DC07. Is there a way to get the cord out without cutting the cord?
Hi there, it's Jack at Dyson.
This would depend on exactly where the blind cord is stuck. If it's wrapped around the rotating brush bar you should be able to retrieve it by removing the soleplate and unwinding it - this should prevent you needing to cut it.
DC07's soleplate is quick and easy to remove - just use a coin to undo the catches which hold it in place for easier access to the brush bar:
I hope this helps, but if you'd like some further guidance from our experts you're welcome to give us a call. You can reach the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 02, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hoover windtunnel vacum..belt is rotating..brush is belt keep coming off
More than likely, there is hair or fibres caught up in the bearings binding them. There are usually 2 screws you can remove on the bottom of the vaccume that allow you to remove the plate. The back part of the plate usually locks in with tabs. Remove the plate, then pull out the brush. The bearing will come out of slots. Remove the bearings, and more than likely you will find hair or fibers wrapped around the shaft on each end of the roller. Remove the material, reinstall the bearings, roller and plate and you should be good to go! :)
Oct 07, 2012 | Hoover U6437-900 / U6439-900 Windtunnel...
Carpet brush not rotating
Did you check the drive belt for the roller? If not do so, the smell was the belt drive burning up.
Jan 16, 2012 | Kenmore Vacuums
Floor level brush stopped rotating after it caught
Look at the bottom and check a thread of carpet isn't wrapped around the brush, if so try pulling it off or carefully cutting it off. You'll probably see a collection of fluff etc above the brush that's stopping it from sucking up, pull this out, or it just may be that cause the brush isn't working its not picking up.
If this helps please rate me
Jun 20, 2010 | Bissell 6594 PowerForce Bagless Upright...
Stopped running
orecks have a plastic fan inside and everything you pick up hits it, sometimes things can get stuck in there or break the fan locking up the motor. With the machine off, poke around where the dirt goes into the motor, behind the roller and see if you can pull anything out.
Jan 12, 2009 | Oreck XL Ultra Bagged Upright Vacuum
it's likely wrapped around the brush
pull out the roller and un tangle it
Aug 12, 2008 | Dirt Devil M084600 Dynamite Bagless...
Vaccum has no suction
Here is what we did to fix the problem of our vacuum having no suction.
We unscrewed the three screws on the back and took the hose off of the vacuum.  Then we took the hose outside and put the water hose through the vacuum hose and turned on the water.  After about 30 second the water pushed through a dust bunny the size of a fist and a marker.  Basically, the vacuum did not have suction because the hose was clogged with dust, etc.  After reassembling the vacuum, it worked just fine.
May 11, 2008 | Kenmore 34923 / 34925 Progressive Bagged...
Kenmore Progressive Model # 116 25914507
I had the same problem with my vacuum. I called in for technical service and was told to push the "reset button". It turns out that there is a small red button right next to the dirt indicator light. I pushed the button, plugged the vacuum back in and started it up and it worked like a charm! :) Hope this helps!
Mar 25, 2008 | Kenmore 23913 Progressive PowerMate Bagged...
Dyson vaccume cleaner
Remove sole plate by turning 3 plastic screws to unlock then pull plate off.
Check belt has not snapped.
If your machine is all floors with clutch check that selector knob on front side of machine goes to (D) or drive when you pull the handle back.
Let me know how you get on.
Dec 09, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
132 people viewed this question
Top Eureka Vacuums Experts
Ryan S
Ryan S
Jim Parker
Jim Parker
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
