Question about HP Photosmart R927 Digital Camera
Processing pause After taking a picture I try to take another one and it seems to have a long processing pause so I miss good shots.  any suggestions
  • lisa kotti Jul 22, 2008
    As i got suggestion from this I removed red Eye option in the manaul ,It is better then before but not working as good as before
  • marietfemme Dec 21, 2008
    Seems to only happen when the flash has been used. It's generally ok if not though not 100%. We've tried reformattign the card, different cards etc but nothing seems to improve it. It never used to do it, only in the second year of having it.
Turn off the auto red eye removal option......you can manually remove red eye later. If the auto red eye removal is on, it will try and process each picture after you take it and slow down camera.
Posted on Jan 04, 2008
  • 38 Answers
Try calling the company See what happends.
Posted on Dec 22, 2007
I feel like the shutter speed is slow because i am missing pictures
You are probably rushing the shutter press. The first pressure on the shutter causes the autofocus to focus and lock on the subject. Then you press more firmly to take the picture. If you try to do this in one jab, you might get unfoccused pictures or fail to take a picture at all. Some cameras have a "sports" mode that is meant to speed up the shutter press for action shots, but this can be at the expense of good focussing. I suggest that you read the manual carefully about what may seem the very simple process of pressing the shutter button. There will be many different aspects to this in a complex piece of equipment like a digital camera.
Nov 03, 2010 | Canon PowerShot S51S Digital Camera
My lens will not focus or shoot a picture. It will on manual but will not focus but at least I can take a shot in manual. when its on auto the lens will do nothing. It won't focus or take a picture. Its...
I have the same problem. I can make it temporarily work by manually turning the focus ring until it is out fully. Then it will auto focus and take photos until I turn the camera off or it times out. Then I have to repeat the process. It's annoying, but at least it works for me. Try it and post to let me know if it works for you
Jan 03, 2010 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Every time i go to take a picture it says prossing it does this 2 or 3 times then lets me take the picture but by then i have miss the good shot
I'm afraid that's a built in feature of this model.
I've heard rumors that it's due to the Color Science Image Processing Chip, the exclusive Kodak Color Science Chip but don't know if this is true.
It will also occur sometimes when you move quickly from photo to video mode.
Dec 29, 2009 | Kodak EASYSHARE Z1285 Digital Camera
Can't get action pictures with S3000
The only trick I know is to pre-focus. The release button has a 2 step process on cameras like yours. Pressing the button halfway sets the focus. Soccer will be tough to do this with since you never know where the action will be. If you know the spot, you can hold the button down half way on that until the action occurs then take the shot. I have used this on baseball, but the batter doesn't move so that makes the technique work
Dec 07, 2009 | Photography
Cyber Shot DSC-T1, Possible CCD Problem
When ccd imager is defective, picture result on still image and video get bad in either cases.
Your camera problem is some thing different and hardware failure is possible like data processing IC but in any case, digital processing board has to be replaced and I'm sure its price would be above and over the camera worth.
You can give try by removing and plugging back the flexible wire board ( ribbon) of lens and ccd imager attached to circuit board. Be careful when handling as flexible wire board can be damaged easily.
Thank you.
Oct 06, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Pictures out of focus suddenly
Make sure the lens is clean and does not have greasy residue on it.
May 07, 2008 | Sony Cyber-shot DSC-H5 Digital Camera
Sony DSC-P100 won't snap picture.
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Dec 18, 2007 | Sony Cyber-Shot DSC-P100 Digital Camera
No Picture
1. If you are using TIFF mode for uncompressed images, the camera takes much longer to process the image because of the very large file size. It takes longer between shots and longer to play back a TIFF image. The TIFF setting on the camera Top LCD Display is 'No Stars' (One Star = Basic, Two Stars = Normal, Three Stars = High Resolution, No Stars = be patient for TIFF). Unless you are doing professional images, we suggest that you use the normal or high resolution JPG settings (Two or Three Stars / FULL) for good results. 2. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 3. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. 4. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Sep 15, 2005 | Toshiba PDR-M11 Digital Camera
No Picture
Sep 15, 2005 | Toshiba PDR-M21 Digital Camera
HP Photosmart R927 Digital Camera Logo
122 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
