Question about Canon F-502 Calculator
Decimal places i was checking out my calculator and pressed 2nd F FIX. Then realized that everytime i press the ON button i see this coming up, 0.000000. I want it to come off. What do i do?
To put the calculator back to NORMAL mode, try [2nd][FIX] then [ . ] (decimal point).
Posted on Nov 09, 2009
  • Canon Master
  • 8,016 Answers
From what I know of other calculators, the FIX feature displays results in floating point mode of the type 12345.6789 depending on the maxim number of digits that the calculator can display.
Howerer, when you use the FIX command, you are expected to enter the number of decimal digits you want the results to have. Appently, when you do no not specify that number, the calculator uses the default option.
I suggest you try [2nd][FIX] 3. If that does not fix the number of decimal digits then try 3 [2nd] [FIX]
Hope it helps.
Posted on Oct 24, 2009
  • k24674 Oct 24, 2009
    Just a thought. Pressing [ON] on a calculator that is in use, can for certain calculators reset defaults. So if you have no reason to press ON when the calculator is already ON, maybe you should not do it.
    OOPS. On line 6, should read Apparently instead of Appently
For calculator TI-30X II S My solutions only come out in the tenth's place if its a decimal. for example: 0.123 will only show as 0.1
Press 2nd [FIX] to bring up the display menu. You can select the number of digits after the decimal point, or "F" to select the floating decimal display.
Apr 28, 2011 | Texas Instruments TI-30X-IISTK Scientific...
How can i get my calculator to show more than just 4 place decimals?
Press 2nd [FIX] and then select the desired number of decimal digits to the right of the decimal point.
An alternative is to press 2nd [SCI/ENG] and then select "FLOAT".
Apr 12, 2011 | Texas Instruments TI-30 XIIS Calculator
How to change the decimal placement to more places? i currently only have 2 decimal places displaced
Press 2nd [FORMAT], type the number of digits you want after the decimal point or 9 for floating-decimal, then press ENTER 2nd [QUIT].
Mar 03, 2011 | Texas Instruments BA II PLUS Financial...
Have a TI BA11 calculator that isn't showing decimal numbers. How do I fix it
  1. Press the 2nd button.3
  2. Press the Format button. (This is the second function on the . button).4
  3. Enter the number of decimal places to show 0-9.5
  4. Press the Enter button.
Jan 16, 2011 | Texas Instruments BA-II Plus Calculator
How do i turn off "fix"?
All results are displayed to the FIX setting until you clear the setting by
either pressing [2nd] [FIX] [.] or selecting F (Floating) on the decimal notation menu.
Resetting the calculator also clears the FIX setting.
· After pressing [2nd] [FIX]?, you can select the number of decimal places in two ways:
- Press to move to the number of decimal places you want, and then
press enter, or
- Press the number key that corresponds to the number of decimal places you want.
· FIX affects only the results, not the entry.
Nov 25, 2010 | Texas Instruments TI-34II Explorer Plus...
My calculator is returning an answer with a 7 for division
You need to set the number of decimal places to 1 or more.
• Press [2nd] [MODE] and scroll to FLOAT.
• Press the right arrow key until the number of decimal places needed is highlighted.
• Press the [ENTER] key.
For 2 decimal places, 2 should be highlighted. All answers will then be rounded to 2 decimal places.
• Press [2nd] [QUIT] to return to the home screen.
May 03, 2010 | Texas Instruments TI-30X-IISTK Scientific...
How to change the decimal place in the '' financial Calculator BD-6760ARII????
Step 1: Press 2nd button funtion on top left corner
Step 2 :press "format" button at the bottom
Step 3: press the decimal place you want...like 0, 1, 2 etc
Step 4: now press "enter" button
Apr 22, 2010 | Texas Instruments BA II PLUS Financial...
How do you change the number of decimal places?
Mar 17, 2010 | Sharp EL-738 Scientific Calculator
I want to complete normal calculations. the default says it is set at D for angles in degrees or something I just want to balance my check book and everytime I put in the calculations I get a fraction for...
OK,do not worry. Press [2nd][MODE] to access tghe (SETUP) options. Then press 2 to select [2:LineIO]. from now on all your results will be displayed as decimal numbers. Do not pay attention to the D for degrees, if you are not doing angle calculations or trigonometry.
Another point. Since you only want to balance the checkbook, all your numbers have at most 2 decimal digits and it might be less tiresome for you if you configure your calculator to display just 2 figures after the decimal mark.
To do that
  1. Press [2nd][MODE].
  2. Enter 6 to select [6:FIX].
  3. Then enter 2.
Feb 18, 2010 | Casio FX-115ES Scientific Calculator
I was checking out my calculator and pressed 2nd F FIX. Then realized that everytime i press the ON button i see this coming up, 0.000000. I want it to come off. What do i do?
Howerer, when you use the FIX command, you are expected to enter the number of decimal digits you want the results to have. Apparently, when you do no not specify that number, the calculator uses the default option.
I suggest you try [2ndF][FIX] 3. If that does not fix the number of decimal digits then try 3 [2ndF] [FIX]
Hope it helps.
Comments: - Just a thought. Pressing [ON] on a calculator that is in use, can for certain calculators reset defaults. So if you have no reason to press ON when the calculator is already ON, maybe you should not do it.
Oct 05, 2009 | Canon F-502 Calculator
Canon F-502 Calculator Logo
792 people viewed this question
old marine
old marine
