Question about Canon F-502 Calculator
I was checking out my calculator and pressed 2nd F FIX. Then realized that everytime i press the ON button i see this coming up, 0.000000. I want it to come off. What do i do?
  • Canon Master
  • 8,073 Answers
From what I know of other calculators, the FIX feature displays results in floating point mode of the type 12345.6789 depending on the maxim number of digits that the calculator can display.
Howerer, when you use the FIX command, you are expected to enter the number of decimal digits you want the results to have. Apparently, when you do no not specify that number, the calculator uses the default option.
I suggest you try [2ndF][FIX] 3. If that does not fix the number of decimal digits then try 3 [2ndF] [FIX]
Hope it helps.
Comments: - Just a thought. Pressing [ON] on a calculator that is in use, can for certain calculators reset defaults. So if you have no reason to press ON when the calculator is already ON, maybe you should not do it.
Posted on Oct 24, 2009
Adjust screen brightness
Turn the calculator on, press and hold the 2nd button, then press the up-arrow button to increase the contrast or the down-arrow button to decrease the contrast. If you go too far, release both buttons, press and hold the 2nd button, and press the appropriate arrow button.
Sep 30, 2013 | Texas Instruments TI-82 Calculator
How do I get my calculator to stop rounding off
This function is FIX or FSE near the dot [.] or above it, so press [2nd] the the [FIX] where it located button [.] for example then the dot [.] him self: [2nd] [FIX] [.]
Jan 21, 2011 | Texas Instruments TI-30X-IISTK Scientific...
Everytime i turn my calculator on the screen is black it's a like a black rectangle. how can i fix this and get my calcualtor working normally again?
Adjust the screen contrast. Turn the calculator on. Press and release the 2ND key. Press and hold the down-arrow key for a few seconds to lighten the screen. If you go too far, repeat the process using the 2ND and up-arrow keys.
Dec 09, 2010 | Texas Instruments TI-83 Plus Calculator
Syntax error on TI-30XIIS calculator when i press enter = sign
I had the same problem and finally figured out how to fix it. You need to clear the memory. To do so, first press and release the 2nd button at the top left of the calculator. You will see "2nd" appear on the screen at the lower left. next press the 0 button (which 2nd function is "Reset"). The key to making this work is: do not hold the 2nd button while pressing the 0 button. You have to press it, release it, and then press the 0 button.
Sep 03, 2010 | Texas Instruments TI-30X-IISTK Scientific...
Everytime i turn on my ti-83 plus the black box covers the whole screen and wont operate no matter what button i press
This really sounds like a problem with the contrast. Try this: turn the calculator on; press the second key, and then press and hold down. This she reduce the dark contrast.
Good Luck
Jun 14, 2010 | Texas Instruments TI-83 Plus Calculator
TI-84 Plus Calculator: my calculator screen is black everytime i turn it ...
Turn the calculator on. Press and release the 2ND key. Press and hold the down-arrow key for a few seconds until the screen lightens.
Obviously, if you've gone too far, press and release the 2ND key, then press and hold the up-arrow key.
May 17, 2010 | Texas Instruments TI-84 Plus Calculator
My ti82 will not turn on. i have changed batteries
TI calculators have an annoying habit of dimming the screen when batteries are changed. Turn the calculator on (or at least press and release the ON button). Press and release the 2ND button. Press and hold the up-arrow button for five seconds or so until the screen becomes visible.
If this doesn't fix it, please post a comment and we'll go on from there.
Mar 06, 2010 | Texas Instruments TI-82 Calculator
Decimal places
To put the calculator back to NORMAL mode, try [2nd][FIX] then [ . ] (decimal point).
Oct 05, 2009 | Canon F-502 Calculator
Ti-83 Plus weird display problem (detail included)
Warning the following tip will erase apps and programs from calculator!
The following will run the self-test mode
Press mode then press alpha then press s then press enter
If you want to get out of the self test press the on button in case you want to attempt to save/transfer apps, programs, variables etc.
The calculator will start to test itself it'll countdown and display numbers on the screen. It can get better sometimes other times a replacement of both the cr1616/cr1620 lithium battery and the 4 AAAA batteries work. Also ensure that you've attempted to clear out all the memory and reset the calculator. To delete all variables, tables, graphs, etc: Press 2nd button then press MEM then press 2 then press 1.
To reset the calculator press 2nd button then press MEM then press 7 then press the left arrow then press 1 then press 2.
Jun 03, 2007 | Texas Instruments TI-83 Plus Calculator
Reset?
Okay, I did what the best solution did and worked with it.
"1. press 2nd F (left top corner)
2. ENG/FIX (the button next to 2nd F)
3. press 0 (if you don't want calculator to round off any decimals)"
In order to get your exact value of pi, in step #3, instead of 0, press the decimal [ . ]
This should give you no decimals when entering a number and give you 3.141592654... when you input pi.
Hope that works/helps.
Oct 17, 2006 | Canon F-502 Calculator
Canon F-502 Calculator Logo
213 people viewed this question
old marine
old marine
