Question about Nikon Coolpix L11 Digital Camera
It will not take a picture.
When ever I try to take a picture it displays af with green light but it will not take the picture
Kodak z7590 out of focus
It is almost impossible to not use the AF mode from the camera. Perhaps you managed to put the camera in Accessery lens AF, without any extra lens on the camera. Or perhaps only the pictures are blurred, because you zoomed in to far, without a tripod.
As long as I can't see a picture it is difficult to decide where the problem comes from.
While shooting a picture, just press the shutter release button half, till the green light goes on. Then press the button fully.
Success
Feb 14, 2014 | Canon PowerShot SD1000 Digital Camera
When i press to shoot a picture, the focus is moving back and forth. sometimes it will take a picture, sometimes it does not come into focus and will not take the picture. I have charged the battery...
Hi, check af mode settings in upper display ;set afs,central af area clean contacts of lens cpu and in body too. Set the manual focus mode and check in viewfinder if the focus indicator LED light no flashing.Can make focus your camera dont have problem ,the lens may need maintenance (clean) or repair.
Greethings!
Feb 19, 2011 | Nikon D80 Digital Camera
I try to take a picture in AF mode while the confirmation light in the viewfinder blinks, a picture cannot be taken, but in MF mode picture taken correctly what is the problem?..
It's attempting to tell you that AF has failed. I'd expect low light, low contrast, reflective subject like a mirror or chrome. A solid colour wall with no contrast will also cause a AF failure. Auto Focus relies on contrast. Switching to manual mode shuts off the system and you can take a picture with nothing in focus.
Nov 24, 2010 | Canon Rebel XT / EOS 350D Digital Camera
My Nikon Coolpix L4 camera won't take a picture.
Could check to see if is set to auto-photo-timer..; I have accidentally done that a few times
Aug 08, 2009 | Cameras
Kodak EasyShare C643 Digital Camera won't take picture
take your battery out for 5 mts then try it again
"Was this helpful?"
Apr 02, 2009 | Kodak EasyShare C643 Digital Camera
I bought digital Canon EOS Rebel XT two years ago, and I have really big problem with AF. I got one half of the pictures fuzzy. Sometimes the green light is on, I took the picture and it is fuzzy. Next...
Is the lens on AF mode?
Have you tried more than one lens to determine whether it's the lens or the camera itself?
You may want to have lens calibrated. Send in for service?
May 27, 2008 | Canon Cameras
Focus on a particular subject
Try the FOCUS LOCK feature. This feature allows you to focus on a subject roughly the same distance away from you, then re-compose your picture without losing that focus. Open the lens barrier fully. Look through the viewfinder at the AF Target Mark (the 4 lines in the center of the viewfinder). Position the AF Target Mark on a subject roughly the same distance away from you. Press the shutter button halfway until the green lamp lights. While keeping the shutter button pressed halfway, re-compose your picture, then press the shutter fully.
Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
Why doesn't the shutter button on my EasyShare digital camera work?
The cause and solution may include one of the following: The camera is not turned on. Turn on the camera. The camera is processing a picture; the camera Power ring light (on the Mode dial) blinks green. Wait until the light stops blinking before taking another picture. The card or internal memory is full. Transfer pictures to the computer, delete pictures from the camera, switch storage locations, or insert a memory card with available memory. The shutter button was not pressed. Depress the shutter button completely down. There was a failure in the focus and/or exposure. Press the shutter button halfway to set the Auto Focus (AF) and Auto Exposure (AE). When the AF/AE indicator turns green, press the shutter button completely down. The battery is exhausted. Replace or recharge the battery
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Nikon Coolpix L11 Digital Camera Logo
12 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
