Question about Leica Optics
The leica tps 1200+ does not have enough internal memory to handle the applications i have purchased for it. Initially it did but with firmware upgrades more memory is being chewed up and now the applications will not load on. Also i can not run roadrunner on the instrument as the data files lock it up when trying to load on, again lackm of memory! I am now having to run the instrument in geocom mode and load all the data on the RX controller just so it will work and it still takes about 5 mins to load the data files. when is leica going to do something about this oversite of memory? people have paid a lot of money for these instruments.
SOURCE: Coby MP-C756 Firmware upgrade issue
Screen blurs after showing name , when being turned on
Posted on Jul 09, 2008
SOURCE: SanDisk e130 - died after firmware upgrade failed
Hi there
Always make use of an XP Operating system when updating your Firmware. I tried several hours with Vista to no avail. Brain wave then came through me, and I tried an XP machine, woza, and fixed.
XP XP XP XPX XPXPX XPXPXPXPX!!!
Posted on Mar 18, 2009
  • 1111 Answers
SOURCE: roadmate 1400 locks during boot up
try the hard reset, if you tried that,did you happen to copy your files off the 1400 before the upgrade?
Posted on Jun 26, 2009
wireguy212
  • 1627 Answers
SOURCE: 2001 F250--Instrument panel lights don't work
check your operators manual under fuses and find the one for the instrument cluster,it may also feed the cruise.
Posted on Jul 29, 2009
SOURCE: Not Enough Memory to run Microsoft Office Excel.
Excel running on a 32 bit PC and using a 32 bit operating system can only address 2 Gb of RAM. If your machine has a 64 bit processor (these were being shipped over 5 years ago) it will be possible to install a 64 bit operating system such as Windows XP 64 bit or Windows 7 64 bit. It has been claimed that an Excel 2010 spreadsheet, running on a 64 bit machine and using Windows 7 64 bit, was able to load and use a database with 100 million records.
If you are unable to do this then I suggest that you examine what your machine is running at the same time as your spreadsheet and if any part of the spreadsheet can be off-loaded. By the latter I mean can any of it transferred to another Excel file?
Are you using any links on your spreadsheet, if so can the links be converted into data, e.g. a link to a lookuptable could be converted to data (copy, paste-special, value) and this remove a significant amount of processing load.
Posted on Dec 13, 2010
Good Morning, I keep getting a warning "unable to
This camera will only handle a 16GB capacity flash card the camera Firmware will not allow for larger cards. I ran into a similar problem (different camera) but solved the dilemma with updating the camera firmware. I can only suggest you check out your camera model on the Sony web site for updates if you purchase Memory Cards larger then 16GB. If you have cards under 16GB check make sure your camera is set for memory card and not reading from the Internal memory. Another crazy thing is make sure your clock is working (day date & time) and set correctly.
Jan 10, 2011 | Sony Alpha DSLR-A100K 10.2 Megapixel SLR...
I have the Leica CFR 1200 Rangefinder. Does this readout in Yards or Meters and can it be changed?
There are two different sub-models of the CRF 1200. The 527 reads in meters while the 523 reads in yards. This is not something that can be changed by the user.
Oct 30, 2010 | Leica Rangemaster 1200 40527 Rangefinder
Built in memory full on leica d-lux3
You can either use a compatible memory card or transfer the images to a computer and format the internal memory.
May 13, 2010 | Leica D-lux 3 Digital Camera
I purchased a Sony cybershot DSC- S930 and inserted the Lexar memory stick (supposedly compatible with a sony camera) and upon turning the camera on there is an error message stating there is not internal...
The camera does not recognize the card because
1. Card not compatible
2. Camera cannot handle such a large capacity.
3.Card not inserted correctly.
Maybe a recent firmware update can address the 2nd limitation.
Hope it helps.
Sep 11, 2009 | Sony DSC-S930 Digital Camera
Leica disto A3 button broke
Mike,
Leica does not sell replacement keypads, if the unit is less than 2 years old they will cover it under warranty. Contact the dealer you bought it from and they can handle the warranty exchange. If it is over two years old, it is out of warranty, but they offer a "repair" option, which will replace your damaged A3 with a new D3 for about $215. If you bought it from a reputable dealer, you shouldn't have any problem.
Hope this helps,
Greg DeTray
www.distagage.com
Sep 09, 2009 | Leica DISTO A5 Rangefinder
Alternative to Leica Laser Locator
Leica locator with DGPS capabilities? Leica still manufactor advanced military systems under the Swiss brand name of Vectronix which is part of the Leica group. Are you after a laser locator or a rangefinder such as the discontinued 7x42 Geovid. The Geovid is still available but no longer has the electronic compass. The original never did connect to a DGPS PC only the Leica Vectronix Vector could. None of these models will locate a laser only use a laser to calculate distance. Current Geovids range to 1200 meters and the Vectronix 21 will range to 12 Kilometers. Unless you are a certified government customer the Vectronix 21 you will not be able to purchase. Newcon have models that allegedy exceed 2000 meters that are made in Russia and depending on the model can be had for a few thousand dollars. The Leica Geovid 8, 10 or 15 power can be had for around 2.5 thousand to 3 thousand dollars and is an excellent robust unit. It will not connect to a PC for GPS sync though.
Mar 12, 2009 | Leica Laser Locator Binocular
I want to accsess the internal memory of my Leica D-Lux 3
Your camera uses only SD cards which is a removable memory only.
Aug 11, 2008 | Leica Cameras
Optics Logo
107 people viewed this question
Top Leica Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
woodzowl307
Tom Chichester
Are you a Leica Optic Expert? Answer questions, earn points and help others
