Question about Dishwashers
No washing action form the dishwasher
Water fills up and drains but there is no agitation from the spray arms. there are no obstructions to the arms
    Problem Solver:
  • 4 Answers
Sounds like you have a broken wash pump or if there is a humming sound instead of water splash/spray noise ,something is jammed in pump impellors
Posted on Oct 05, 2009
Why doesn't my dishwasher spray?
Wash motor may be faulty or the wash arms are clogged.
But if it simply fills and drains continuously then the flood switch has triggered. There could be water leakage which floods the base. Turn the dishwasher off form mains power. Pull out and tilt to one side to get water out. Then after a wait of few hours to allow things to dry, reconnect and see.
Apr 23, 2014 | Maytag MDB6769AWS Stainless Steel Builtin...
Water fills the bottom of dishwasher, lower spray arm still seems to turn/spray but no movement or water coming out of uppoer spray arm. We took apart the lines to see if there was blockage -- none.
If there is no blockage, your pump may need to be rebuilt or replaced. If your machine uses a solenoid valve to control weather the pump is washing or draining. The drain valve may be stuck somewhat open, diverting wash water down the drain. Or the wash valve may be not opening fully. Different machines work in different ways.
Nov 09, 2013 | Dishwashers
My dishwasher is leaving hard specks all over the dishes after they are washed. I tried cleaning out the spinners but that didn't work.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps...
Daniel
Apr 22, 2011 | Dishwashers
My dishes don't seem to be getting rinsed. They come out "gritty" and none of the food particles are being washed away.
Hi
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Mar 26, 2011 | Whirlpool KUDC03FVSS Builtin Dishwasher
Not washing properly, it's leaving residue on the plates and glasses
Hi
Daniel
Feb 09, 2011 | Dishwashers
Dishes not clean after they go through the washing cycle
Hi
Jan 24, 2011 | KitchenAid Dishwashers
Spots are left on the dishes after washing. Dishes don't look clean
Hi
Daniel
Nov 26, 2010 | Kenmore Washing Machines
Dishwasher is not draining
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Thank you !!
Jun 04, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
My kenmore dishwasher model 587.1414 does not
Check spray arm for obstructions and if it is clear the motor impeller could be slipping or water system may need a good cleaning with CLR.
Eric
Jan 14, 2010 | Kenmore Dishwashers
Dishes in upper tray coming out not so clean!
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 09, 2009 | Kenmore 24 in. 16332 / 16334 / 16339...
Dishwashers Logo
74 people viewed this question
Top Dishwashers Experts
