Question about Samsung TXL3676 36" TV
Is the Samsung Txl-3676 an interlace or progressive scan?
  • 10,515 Answers
Progressive Scan!!
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 05, 2009
Stuck on progressive scan
This is a common issue with this brand of player. While the unit is on, and without any discs inserted, press and hold STOP button on the front panel (not the remote) for 10 seconds, then release. This should turn the progressive scan function off and revert the video output of the player back to normal interlace.
Zenith, Samsung, Magnavox, and Goldstar DVD players are notorious for progressive scan headaches, but it's easy to correct.
Apr 16, 2011 | Zenith Televison & Video
My memorex combo dvd & vhs player is not working right. can you help me? the vhs player works fine, but the dvd player display's a split screen on the tv with a large yellow box with the word PSCAN....
PSCAN is a short form for Progressive Scan - a line scanning format used for High Definition TV. Standard TVs use Interlaced scanning. On your DVD/VHS player, the VHS is an analogue signal recorded in interlaced mode so is fine for a standard TV. The DVD is a digital signal and cazn be processed for progressive scan output in order to produce a better picture on a High definition TV (or a TV capable of handling progressive scan). If you cannot to your TV via the HD outputs then you should be able to set the DVD player to output interlaced instead of progressive scan.
Mar 05, 2011 | Memorex MVD4540 DVD Player/VCR
Hi, I've a small problem cocerning this dv-363 player. I accidentally set it to 'progressive'. Now I cannot undo. I tried holding the buttons on remote and on machine itself, still not working, can you...
Progressive Scan is a menu option relating to video output of this player. Assuming you have the original DVD remote, this should be easy.
* From the user manual (pages 50-51 of the pdf document):
About progressive scan video
Compared to interlace video, progressive
scan video effectively doubles the scanning
rate of the picture, resulting in a very stable,
flicker-free image. Progressive scan video is
available only from the component video
output.
If you connect a TV that is not compatible
with a progressive scan signal and switch
the player to progressive, you will not be
able to see any picture at all. In this case,
switch everything off and reconnect using
the supplied video cable (see Easy
connections on page 14), then switch
back to Interlace. Switch the player to
standby then, using the front panel
controls, press STANDBY/ON while
pressing 'back to Interlace.
Hold these 2 buttons together for about 10-15 seconds or so, but only while the player is in standby mode. *
If you have lost the manual, you may be able to download the user guide (as an adobe reader (pdf) document) from:
http://www.retrevo.com/support/Pioneer-DV-363-K-DVD-Players-manual/id/385bh937/t/2/
(it will ask you for an email address prior to downloading - use a blank address if possible and enter the security code in the fields then save the document)
If the above suggestion does not switch it back to interlace, you will need a TV with progressive scan function to enable you to access the player's on-screen menu and in 'Initial Settings' 'Video Output' 'Component Out' section, select 'Interlace'. and press OK from remote as required.
Either way, it should NOT require a workshop service, and is simple enough to do at consumer level with the right TV type.
Mar 05, 2011 | Pioneer DV-363 DVD Player
Split screen on DVD player
This sounds like a progressive scan issue (unit in P.Scan Mode) here is a C&P from the manual
Set "Alt Video Out"
Highlight "Alt Video Out", then press the RIGHT button to select
one of the following options:
• S-Video - Select this if you are using the S-Video OUT jack on
the rear panel to connect to a TV.
• Component - Select this if you are using the COMPONENT
VIDEO OUT jacks on the rear panel to connect to a
Progressive(480p) or Interlaced (480i) TV.
• See your TV owner's manual to determine what type of TV you
have.
- Interlace : Interlaced Scan mode will work.
- Progressive : Progressive Scan mode will work, and Video
and S-Video will not work.
• Press the Progressive button on the front panel if you have a
Progressive scan TV only. Otherwise, the picture will be
disturbed.
Feb 04, 2009 | Samsung DVD-V3650 DVD Player/VCR
Denon dvd player is in progressive scan-need it in interlace
used single composite video plug to get back to setup.all is good again
Dec 25, 2008 | Denon Televison & Video
Television display
In basic terms TV images are made up of hundreds of horizontal lines, with interlaced scan it will display in order line 1, 3, 5, 7 and so on and once it reaches the end it will fill in the missing lines 2, 4, 6 and so on until it starts again.
For progressive scan it will display the lines in order 1, 2, 3, 4, 5 etc.
cheers
Jan 21, 2008 | Televison & Video
DVD recorder: Changed the settings, now
we could go through the setting like, you can see the monitor. using the remote do the following steps:
Step 1. press set up button.
Step 2. press down arrow once. ( playback)
Step 3. press OK.
Step 4. press down arrow once. (video (selection))
Step 5. press OK. (progressive scan)
Step 6. press OK, again.
Step 7. press down arrow once. (progressive scan off)
Step 8. press OK
you have now turned progressive scan off.
Dec 19, 2007 | Philips Magnavox MWR10D6 DVD Recorder
No progressive scan from component input
Sanyo DS27930 does not support progressive scan
DVD player must be set to interlaced scan
Nov 24, 2007 | Sanyo DS27930 27" TV
Split screen from DVD player, cable is fine no problem
It is not clear where you say input is from cable, do you mean the Scart input to your Sony TV? Do not use Progressive scan(p), as this is not interlaced. The normal TV requires an interlaced(i) picture of 50 half frames per second giving 25 complete pictures per second to reduce flicker. Some TVs and projectors and all monitors accept Progressive scan.
Oct 15, 2006 | Sony KV-32S25 32" TV
Interlace Scan (IS) mode and the Progressive Scan (PS)
The Interlace Scan (IS) mode the camera uses a mechanical shutter with shutter speeds up to 1/640th second. It also uses the maximum resolution that is possible with the CCD (5.0 MP). In the Progressive Scan (PS) mode the camera operates with the electronic shutter with shutter speeds up to 1/4000th second and a 1/18000 second shutter speed (1/18000 in Shutter or Manual Priority modes only). In this mode the resolution is reduced in half (2.5 MP).
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Samsung TXL3676 36" TV Logo
59 people viewed this question
Jerry Greenberg
Jerry Greenberg
