Question about Maytag Atlantis MAV6451 Top Load Washer
My Maytag Atlantis washer keeps intermittently filling with water, whether the load is going or even when the machine is on the ''off'' position. Each fill is about a minute apart, and lasts about 7 seconds. I replaced the inlet valve, and checked the pressure switch/tube, and they seem fine. The water does not keep filling until it overflows... it just fills on and off until it reaches the point of a normal wash load, then stops. When I unplug the machine it stops. Any ideas?
docjohn174
  • 943 Answers
SOURCE: Maytag Atlantis MAV6451 Waterfill keeps filling
hi todd it looks to me that the problem with the water level control or the small level control hose hard water &lint can sometimes clogg this hoe up remove hose from switch and blow into it hard if its clogged you will not be able to blow clean it and try if it does not work after its clean replace water level switch thanks the appliance doc
Posted on Sep 17, 2008
  • 117 Answers
SOURCE: Maytag Atlantis Washing Machine always runs warm water.
Sounds like it may be a faulty temperature selector switch
Posted on Mar 02, 2009
  • 27 Answers
SOURCE: Maytag Atlantis MAV7600AWQ Washer. Delayed fill
ALL WASHERS COME WITH SCREENS AT THE
WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
NEEDED AND GO FROM THERE.
Posted on Mar 07, 2009
  • 236 Answers
SOURCE: Maytag Atlantis screeches @ end of spin cycle,
may be something stuck in the drum or a segment raised on the motor. to test either remove the belt and spin the drum if no noise then the motor is faulty. if a noise then there may be a bra wire between the drum/tub.
Posted on Mar 16, 2009
  • 212 Answers
SOURCE: Maytag Atlantis won't agitate
possible bad control board.
Posted on Jun 20, 2009
Maytag atlantis washer water won't stop filling with water even when power is off.
water fill valve have a particle of trash or deposit from water.replace water valve and problem solved.
Jan 31, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Water won't stop running in at end of cycle, keeps filling up and overflows
This is symptomatic of an intermittent water control valve- sometimes closes too soon (its physical fail position is closed) or sticks open too long.
It needs replacing! Service call ;-0(
Good luck,
John C
Mar 16, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Feb 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washer is over filling.
Hi, Does water enter the machine when there timer is off or even if the machine is unplugged? If this is the case, the inlet valve needs replaced. If the water stops when the timer is turned off, there is a problem with the water level switch. Please let me know so that I can assist you further. Thanks
Vic
May 23, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Mar 07, 2009 | Maytag MAV7600 Top Load Washer
Maytag Atlantis MAV6200AWW Washer Problem?
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
Feb 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Does complete cycle
When would the washer stop?
Is there water in the washer when it stops?
Feb 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Fills with water than nothing!
Most likely it's the lid switch, part number 22003804.
Remove the back of the console to gain access.
Jan 22, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Water fills but does not agitate or spin
THIS UNIT HAS A DOOR SAFETY SWITCH WICH ALLOWS WATER TO COME IN BUT NOTHING ELSE TO HAPPEN IF THE DOOR IS OPEN I WOULD START BY CHECKING THIS SWITCH.
Nov 29, 2007 | Maytag Atlantis MAV6260AWW Top Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
71 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
