Question about Car Audio & Video
I am trying to install the xo1931 in a 97 chevy s10 and when i try to wire it im getting power to the head unit but no display on the screen... any suggestions?
    Problem Solver:
  • 6 Answers
There should be a wire on the unit that says to hook it to the emergency brake. It has to be hooked up before the display will work. You can also just ground it to any ground and it will work that way also. It's designed so you can't watch it while driving down the road but just grounding it will solve that problem. Hope this helps..
Posted on Oct 24, 2009
Auto wiring diagram
Absolutely not. You'll need to either map out the wire harnesses from the two vehicles or swap the harnesses. Either way you will also need the computer from the engine you are installing.
Aug 30, 2014 | Ipcw Chevrolet S10 / S-pu 1998 1999 2000...
1998 chevy s10 Head unit and dash display not working
You may have damaged the instrument cluster. The PCM has to receive a code from the instrument panel to start. Its part of the security system. Beyond checking fuses you are going to have to take it to a qualified mechanic with the proper diagnostic equipment. It sounds like you wired something incorrectly
Jan 18, 2014 | Cars & Trucks
2005 chevy cavalier after market radio has no power, im installing a pioneer head unit in my car, i bought a wairing harness connected it to the wiring harness for the new radio, im getting power to the...
No, make sure the vehicle key is in the aux or on position. If this still doesn't work, recheck the wiring. Also, make sure you have a good ground.
Sep 03, 2011 | Car Audio & Video
JVC KD-G140 Chevy s10 problem
Your headunit is getting constant power (yellow wire). You most likely have no switched power (acc red wire). You can be certain by testing the red wire w/ a 12 volt test light when your ignition is on. If there is no power to this wire then you probably have a blown fuse. The radio fuse should be a 10amp fuse located in the drivers kick panel.
May 28, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Pcv location on 2002 s10
it is a tube connected to the valve cover. So there really isn't a valve.
May 15, 2009 | 2002 Chevrolet S-10
Digital display cluster
Chevy is known for using a cheap grade of wiring harnesses that corrode over time and short out. my 93 s10 blazer had a bad wire in the transmission harness resulting in only 2nd and 3rd gear and wouldnt shift by itself, i dont know if im right but something to check into.
Aug 08, 2008 | 1993 Chevrolet S-10 Blazer
1991 Chevy Blazer S10 window motor installation
http://www.a1electric.com/s10motor.htm. This link has pictures and step-by-step instructions. I found it and have both sides to replace. Hope this helps.
Aug 08, 2008 | 1991 Chevrolet S-10 Blazer
06 cobalt stock system hook up
I cant really assist in this matter but I can let you know that I have a system in my 2006 Chevy Cobalt and that I have an aftermarket cd player installed. I had to pay $130 for a special adapter for it to be wired into the system because GM's newest idea of installing the stereo and airbags on the same wire scheme, is kind of a dumb idea.
Jul 02, 2008 | 2006 Chevrolet Cobalt
Deh-15 no sound
the only thing i can suggest is to make sure that your positive and negative wires on the speaker wires are connected right and if they are then the radio is bad, i would try a different stereo and see if you have the same problem.
Mar 18, 2008 | Pioneer DEH-15 CD Player
Car Audio & Video Logo
201 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
