Question about Magic Chef Refrigerators
Clicking noise every few minutes - Magic Chef Refrigerators
  • 1,606 Answers
The overload/relay , mounted on the side of the compressor , is defective . This piece , has 2 or 3 wires going to it . You can easily replace , with pt # 8201786 . Installation instructions , come with the part . If you have an amp meter , after replacing the part , check the compressor run amps . If 3.0 or higher , then not much compressor " life " left . Also , dirty coils under the refrig , will also cause the amps to rise . Be sure to make sure they are clean .
Posted on Oct 07, 2009
  • 3,600 Answers
The thermal switch is going bad it is a easy fix unplugh the refriderator and buyt this part from this online store http://www.appliancepartspros.com/Appliance-Parts/FRIGIDAIRE-Puresource2-water-filter--wf2cb--item-number-AP2538969.aspx
or you may need the thermal switch on the pump but need model number to find a replacement for it.
Posted on Oct 05, 2009
My ge dryer dvlr223eeoww is making a loud noise when you turn it on it will work fine for a few minutes if a lot of clothes are in it then after a few minutes it sounds like it is going to fall apart.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 04, 2011 | Dryers
Knocking noise coming from bottom of refrigerator
check the compressor for operation adn check the fan in the back of unit to make sure it is running...whirlpool units are notorious for compressor relay failure normally they click in and out every few minutes... if it is a knocking noise and continuous make sure compressor is not trying to start and sitting there shaking... normally it will stop after a few minutes and then start again....
Jan 25, 2011 | Whirlpool GS6NBEXRS Side by Side...
Clicking Noise Coming From Engine
oil pump may have to be replace or clean the oil pump strainer must remove oil pan
Apr 12, 2010 | 2001 Dodge Stratus
My 53564 side by side refrigerator seems to be
good catch........
pull the unit out and listen to the back and bottom
that click is more than likely comming from the compressor electriacal connection
it could be just loud, but if you have not herd it before its probaly going bad
Oct 14, 2009 | Kenmore 53562 / 53564 / 53569 Side by Side...
Buzzing and clicking sound every few minutes
Compressor start relay - white plastic part - sitting right on the compressor, disconnect it shake it - u'll here it if it's damaged. :)
Oct 01, 2009 | Jenn-Air JCD2389G Side by Side...
Our fridge makes a clicking noise. this clicking sound happens every few minutes. can you help?
does it still makes cold or not but the noise you are hearing is the compressor clickson going on and cut out. try to change the clickson
May 13, 2009 | Refrigerators
Weird clicking noise and computer freezes.
Laptops have very few moving parts. Your problem is more than likely either a fan or your hard drive. Remove the hard drive, start the computer up and just let it run for awhile. If the clicking noise never comes up then thats your problem. If it does, its probably a fan.
Disregard anything on the screen itself, just let the PC run. It sounds like after the hard drive has been spinning for a minute a motor starts to die.
Jan 29, 2009 | Acer Aspire 5100-3357 Notebook
Makes loud squeaking noise, cuts off after a few minutes
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Open Questions:
Refrigerators Logo
166 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
