Question about Kenwood KDC-319 CD Player
If I pull my radio out were will i find it - Kenwood KDC-319 CD Player
  • 2 more comments
  • iceeye5 Oct 05, 2009
    I took my kenwood kdc 319 out and diconected the bat now i dont remeber the code y22-9150-15 no 20518149
    I disconected the bat now i forgot my code to input into my stereo to make it play i have a kenwood kdc 319 modely22-9150-15 serial no 20518149
    diconected bat now my kenwood kdc 319 will not work without the code can you help y22-9157-15 no 20518149
    you said if i pulled the radio out i would find the code i dont see it on the radio wise guy
    President:
  • 2,976 Answers
I don't understand your question. If you pull your radio out, you will find it either in your hands, on your lap, or on the floor.
Posted on Oct 05, 2009
  • 10,515 Answers
The only way now would be to Reset your code. Let me provide you with a link that might help you to reset :-
http://www.tech-faq.com/reset-kenwood-security-code.shtml
If the problem persists, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Do accept the solution, if 100% satisfied with my service!!
  • 3,051 Answers
Hello there:
can u tell me what are you trying to find
regards mike
Remove radio
Remove any media that may be in the radio.
Put your car in park, set the parking brake and remove the negative battery cable (the black cable) from your battery's terminal by loosening the bolt on the clamp, with an adjustable wrench.
Remove three Phillips screws spaced across the bottom of the radio's trim panel. This is a large panel on the dashboard that surrounds the radio and the instrument cluster. OBD365
Remove three Phillips screws from the top edge of the the trim panel.
Pull the trim panel off by pulling firmly towards you, starting in the center. This will release the clips holding the panel in place.
Remove two 3/8-inch bolts holding the radio in place.
Pull the radio away from the dash and unbolt the metal strap attached to the back. It's held in place by a 3/8-inch bolt.
Unplug the wiring plugs attached to the back of the radio by pulling them firmly away from the back of the radio chassis. Remove the radio from the car.
Foxwell NT630 AutoMaster Pro ABS Airbag Reset Tool
Sep 19, 2014 | 1997 Ford Explorer AWD
Factory stereo not working and needs replaced. how does dash come apart to do this
REMOVAL
  1. Disconnect and isolate the battery negative cable.
  2. Remove cup holder.
  3. Remove trim panel above cupholder by pulling straight out.
  4. Remove center instrument panel trim panel.
  5. Remove screws holding radio to instrument panel.
  6. Pull radio rearward to gain access to the back of radio (RADIO). CAUTION: Pulling the antenna cable straight out of the radio without pulling on the locking antenna connector could damage the cable or radio.
  7. Disconnect the antenna cable by pulling the locking antenna connector away from the radio (ANTENNA TO RADIO).
  8. Disconnect bolt holding ground strap to the radio (if equipped).
  9. Disconnect the wire connectors from the back of the radio.
Nov 19, 2013 | 2002 Dodge Grand Caravan
How do i remove the factory radio on my 1983 cadillac fleetwood
Locate and remove two (2) phillips screws that secure the top of the plastic panel that surrounds the radio. The plastic dash panel will pull off once the screws are removed as shown in the photo above.
The front of the radio is held in with two (2) 7mm bolt screws at the top of the radio. Remove the 2 bolt screws.
There is a hidden radio that secures the rear of the radio and is located under the radio. Pull the ashtray to its extended position. You will need to lay on your back or side and look behind the ashtray, up to the bottom of the radio.
Once the ashtray has been pull to its extended position, you should be able to locate and remove one (1) 7mm bolt screw as seen in the photo above.
Once all screws have been removed, the radio can then be removed. Pull firmly on the radio to remove it from the dash. The radio will most likely resist pulling from the dash. The antenna cable which plugs into the rear of the radio is very short and gives the radio resistance when trying to pull the radio out of the dash. Continue to pull firmly and the antenna cable will unplug itself as the radio is pulled from the dash.
Unplug (1) blue, (1) white, and (1) black wire harness connector(s) from the rear of the radio. There will also be wires extending from the rear of the radio with a plastic connector attached to the wires about 4 inches from the rear of the radio. Unplug this small connector. The radio can now be completely removed from the dash. Set it aside. You will need to remove the plastic brackets attached to the top and bottom of the GM radio. This will be shown in detail in the "Mount New Radio" section.
Hope these helps....
Jan 23, 2011 | Cadillac Fleetwood Cars & Trucks
My radio quit working, how do I go about replacing
remove cup holder remove two philips screws and pull face plate off remove two 10 mm (wrenchsize) screws from radio pull radio out and unpluge wires (face pulls off it has clips )
Oct 24, 2009 | 2001 Dodge Caravan
Removing the Radio for Lexus Rx300
take the woodgrain cover off around shifter, it pops off. next pull out the small panel just below the radio, pull it straight out towards you, set it aside. there are 4 bolts holding the radio in, you will need a light to see the back 2. remove these bolts and carefully pull radio straight out.
Sep 23, 2009 | 2000 Lexus ES 300
How do you take the radio out of a 1995 bonneville
You need to pull the plastic cover that runs all along your dashboard, a/c heater controls,and radio. You don't have to pull it out completely just enough where you can unscrew the 4 screws that hold the radio in its place. Just take a flat head screw driver and gently pry the plastic cover off around the radio area. You also might need to pull (with your fingers or flat head again) the cover by where the a/c vents are. Pull out as much as you need so you have room to stick a screw driver in. Once you unscrew the screws (bolts) pull the radio out slowly and begin to pull out the wire harnesses and antenna cable from the back of the radio and there you have!! If your going to replace your radio you will need a single din and you have to buy the adapter piece to put it in. A double din radio will not fit. Good luck.
Aug 31, 2009 | 1995 Pontiac Bonneville
I have a 2000 chevy tahoe that I need to unlock the radio
You can call the dealer with your VIN# and the serial# from the radio, but that means you have to pull the radio first. Not ******* your vehicle. First pull out your cup holder on the dash as you would to use it. Second, turn on your key and put the vehicle in first gear, all the way down. Tilt your wheel all the way down. Dash panel will pull out easily, no screws just clips. Pull firmly, but not too hard, straight out all the way around the panel. BE CAREFUL NOT TO BREAK THE HAZZARD SWITCH. VERY EXPENSIVE. Push the hazzard switch down and gently pull the panel over it. Disconnect any wire harnesses on the radio side so that you can tilt the dash panel away from the radio. The radio will also just unclip from the dash. On either side you will see clips on the radio that you need to push straight down and then just pull straignt out. There you go. Good luck.
Jan 06, 2009 | Chevrolet Tahoe Cars & Trucks
Cannot get the radio out
Getting those radios out can be a pain! I worked at Ford/merc/lincoln for some time in the past and knowing what I was doing still broke the special tools to pull them out. Assuming your tools are the correct ones and in good condition put them in til you feel them in place and pull them to the side away from the radio and I would rock the radio up and down a little while trying to pull the radio out at the same time. You may want to try to push the radio in first as you pull the 'tools' to the side hopefully relieving pressure of the clips that are holding the radio in then start rocking the radio as you pull the radio out. The clips that hold the radio in is the problem and not being able to see what your doing hoping the tools are doing its job releasing the clips is quite aggravating, I remember all so well. I wish you luck, hope this helps
Nov 06, 2008 | 1991 Lincoln Town Car
Kenwood KDC-319 CD Player Logo
97 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
