Question about Jenn-Air JGS8850ADS Gas Kitchen Range
Clicking noise on burner
One of my burners has a clicking noise while on. How can I fix this? Thank you
  • onemulligan Jan 06, 2008
    Thank you for the reply. I just cleaned out the holes and the spark part next to the burner and it stopped the clicking.
  • alibaby3 Feb 17, 2008
    I have a Jenn-air cooktop. When you try to turn on one burner, they all start clicking...and don't stop. They are sparking like they are trying to ignite, even though I am not turning on the other burners. How can I fix this??
You'll need to replace the Spark module in the back of the stove. Remove the back panel, and there is a blue Spark module. You can find them on-line for about $65. There are only a few wires to un-plug, it only took me about 15 mintues to replace.
Posted on Jan 06, 2008
When one of the burners on the stove is in use the stove makes a repetitive clicking noise and one of the rear burners sparks in rhythm with the clicking.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
Jun 30, 2011 | GE Ovens
Hi, My GE Monogram ZDP30N4HSS range is making a
First I would replace both front igniters thier about $20 a piece this should fix the clicking. They keep clicking because they are not sensing the flame. The front burner assemblys will need to be thoroughly cleaned. There are very small orfice holes that need to be spotless. Also the burner cover, the top piece that pulls off. Make sure the bottom lip is very clean. Use a fine wire like a paperclip to clean out the holes in the burner assembly. For diagrams or illustrations enter your model # at
Sep 08, 2010 | Whirlpool RF364 Electric Kitchen Range
Back burner makes periodic clicking noise and flames increase
This clicking noise would be an indication that the burner is 'burnt out'. Burners have individual ports that release individual flames to create one big flame.
If the burner has a hole in it or the burner's internal baffles are burnt out the burner will make a 'popping' or 'clicking' noise.
Also, heat makes metals expand and when metal expands it makes a clicking noise. The increase in flame could be because the burner has a large hole in it or the holes are increasing in size as they expand, thus throwing a larger flame.
Just a thought.
Ben Gaetani
Tanks 2 You Propane
Mar 20, 2010 | Weber Genesis Silver B Grill
I have a gas stove that one of the burners is making a clicking noise.
Raise the cover and see if the ignitor is the cause of your clicking noise. You should be able to see a spark in the burner if this is the case. If this is the case, follow your manufacturer's recommendation for replacing the burner control.
Nov 02, 2009 | Cooktops
Igniter keeps clicking, intermittent
There should be a little switch that slips over the stem of each burner control. Very common.
Jun 02, 2009 | Viking VDSC307-4B Dual Fuel (Electric and...
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Riello oil burner
i have a reillo oil burner that fires up from cold no problem reaches the set temp and cuts out, when it tries to kick back in it keeps clicking the lockout light is not coming on and the fan is still running any ideas?
Oct 08, 2008 | SySTOR Systems (400S52) Burner
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Cd burner
1. go to device manager / right click on cd drive / uninstall driver / reboot and windows will reinstall driver 2. go to My computer right click on cd drive properties - check digital cd playback recording - check enable cd recording on this drive driver - update or uninstall reboot your computer 3. go to look for the EXACT model of your toshiba notebook a) download latest BIOS b) download the cd driver Goodluck!
Sep 25, 2006 | Toshiba (SD-R2412) for Satellite A10, A15,...
Gaggenau clicking
Sounds like the spill got into one of the burner switches. This is not a big problem. Once it drys out it should return to normal. However if it keeps on clicking it could mean that one of the switches shorted out and will need to be replaced. The switches are located under the burner control knobs on the valve. Hope this helps. Catriver
Jul 27, 2006 | Gaggenau 23 in. KG 260 Gas Cooktop
Jenn-Air JGS8850ADS Gas Kitchen Range Logo
330 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
