Question about Samson Audio Players & Recorders
How do i get my mic to record louder its a C01U USB Studio Condenser
PBandJ
  • 29 Answers
SOURCE: C01u PROBLEM PLS HELP ?!
That's the way it's supposed to work. It's a mono microphone, so there's only one signal to record.
Set up your recording software so that it only records the Left channel. It describes how to do this on the Samson FAQ page and in the Owner's Manual:
"In your digital audio workstation (DAW), create a mono audio track, and set it to the Left channel of the C01U (the Right channel should be ignored). Arm the track for recording, and adjust the input gain by using the software control in your computer's operating system"
Don't try to alter the pan so both sides are the same; that will just screw up the levels and noise.
Posted on Mar 01, 2009
SOURCE: sound quality not good at all
open up the sound icon on control panel...select recording......select samson mic....make sure set to default.....go into properties ...and boost main volume slider....most mics after install are set quite low and you have to go in and adjust the vol input level
Posted on Apr 25, 2009
  • 5603 Answers
SOURCE: whistling background noise with Samson C01U USB condenser mic
Welcome to the world of STUDIO microphones. Super quality BUT you must have a studio to use them. You can't have any local speaker playing into them. You often use headphones lest your monitor speakers will feedback. At the high frequency capability of these mics, you can fry your amps with oscillations above what you can hear!
Posted on Sep 30, 2009
SOURCE: Cannot setup C01U Microphone with Adobe Audition2.0.
Try to disable your laptops build in mic through the recording options on your computer. It worked for me
Posted on Oct 10, 2009
  • 1138 Answers
SOURCE: how do i get my computer to recognize my usb
Here is the detailed manual for MAC and Windows:http://s3.amazonaws.com/samsontech/related_docs/C01U_ownman_v4.pdf There are explanations and diagrams.
Posted on Oct 23, 2009
Hello, I just purchased the C01U USB mic and whenever I test or record with it I get this really high pitched noise. but when I tap the Mic is goes away and then slowly fads back in after a couple of...
1. Try the microphone on another USB port and check.
2. If not OK, try the microphone on another computer and check.
3. If OK on another computer, re-install it or recover the O.S. from a backup.
4. If on another computer the same problem exists, the microphone could have a internal control defect.
Aug 20, 2011 | Samson C01U - USB Studio Condenser...
My mic won't pick anything up. it's plugged in, the recording software is set to line in. how do i adjust the mic settings?
If you are using a condenser microphone, it's need phantom power (48v) to activate the mic. Hope this helps
Apr 05, 2010 | Samson C01U - USB Studio Condenser...
I have connected the samson mic to my computer. input not detecte
A condenser mic. requires "phantom power" usually supplied by a mixing desk. Without this, there will be no output signal from the mic.
Jan 12, 2010 | Samson C01U - USB Studio Condenser...
Whistling background noise with Samson C01U USB condenser mic
Sep 28, 2009 | Samson C01U - USB Studio Condenser...
SAMSON CO1U recordings sound like they're underwater on my MAC
The behavior you describe suggests that the mic is not getting power. Since it is a condenser mic, it requires what is usually called "phantom power". This should be provided thru the USB port. Check to be sure that the USB port is supplying that power. Check with another port for example. If that fails, you may have a defective mic.
Keep us posted.
Dan
Feb 10, 2009 | Samson C01U - USB Studio Condenser...
Jan 08, 2009 | Samson C01U - USB Studio Condenser...
Sound quality not good at all
Jan 03, 2009 | Samson C01U - USB Studio Condenser...
No good sound quality
ARE YOU RECORDING IN STEREO OR MONO
Sep 01, 2008 | Samson C01U - USB Studio Condenser...
267 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
PBandJ
PBandJ
Level 1 Expert
 Grubhead
Grubhead
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
