I bought a dlink n router 655 yesterday to replace my old belkin router. When i connect the modem to the n router and try to setup with the cd, it wont detect the internet. The modem i'm using is westell 6100. I had to bridge the modem to connect to the old router in order for it to work on that one. The new router i cant get it to work no matter what i do. I tried resetting the modem back to its default, and it didn't work. So i bridged it again. I even followed the router setup instructions that i found on the verizon forums and did the clone mac off the modem. i really need help with this.
  • Computers & ... Master
  • 2,263 Answers
I Think you ISP must be DSL.
Your internet is working with the old router when it is in bridge mode.
Check the IP address of your computer when it is connected directly to the modem and NOT in the bridge mode. Suppose the IP address is 192.168.X.Y. After that connect your computer to the ethernet port of the router. DO NOT connect the modem to the router. check the IP address of the computer again. Suppose the IP address of the computer is 192.168.A.B. Now make sure that both the IP addresses are not in the same range that means X is NOT equal to A. If they are same, then open the set up interface of your router and change the Local IP address of the router. that will help.
For More information Click Here
Posted on Oct 06, 2009
Testimonial: "it worked perfectly, however your a little late because i called my internet company and they said the same thing. i appreciate the response though."
  • Prashant M
    Prashant M Dec 04, 2009
    Click Here for Easy Set up Guide for step by step instructions.
    It will guide you with simple steps to resolve the problem in your network.
There's no CD, so how do I install dlink router dir-655?
1. set u all the possible wiring between modem and the router'
2.switch it on.
3.now open the any Browser like Opera, chrome,
4. Type the default gateway address descriptive at the back of your router (generally 192.168.0.1/192.168.1.1/192..... something) ;in the address bar of your browser and press enter.
5.now the popup message will ask for username and password .
6. now the default page of the router will get opened .
7. now run the quick setup and follow the further instructions.
8. each information should be entered properly and Your WiFi router will start working .
If any help related to Dlink Router then You can Contact us at Dlink Tech Support
Dlink Tech Support Number
Feb 13, 2014 | D-Link Wireless Router 3 Antenna Xtreme N...
Order dlink 655 router and it has arrived, but
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the
router ad the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 04, 2010 | D-Link DIR-655 Wireless Router
I lost my setup cd for my dlink dir-655 wireless router. how can i find the software and drivers?
You can set up your router manually, without the
CD.
directly through the modem.
modem, that means the modem is working fine.
You will need to connect the computer to the
router and the modem to the router.
Click Here for more information about the routers
and network
Jan 22, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Win OS 7 does not work with my new ASUS MOBO / MA4A78T-E regarding my Ethernet drivers (I assume)as I cannot get my PC to connect to my Dlink-DIR 655 Wireless Router. Keep getting messages that my IP is...
If you are getting a message that your Dlink is out of range, your drivers are being loaded correctly and you have a hardware issue, not a driver issue.
Try running a hardwire to your modem and run the setup wizard for internet connections.
Now at least your modem and router is making connection.
Next, install your software for your Dlink DIR-655 and run setup.
All should be a walk in the park.
Good luck.
Nov 26, 2009 | Computers & Internet
Can not connect to internet
My first guess is that your Dlink ADSL modem is really a modem router, so you are getting double routing. Sometimes this works just fine, though, so I'm not confident that's the whole explanation.
You'll need to setup your IP plan carefully
set the D-Link modem(router?) to bridging mode & the DLink wireless router does the login to Exetel.
DLink wireless router WAN side: DHCP + login to Exetel
DLink wireless router LAN side: 192.168.0.1
Subnet 255.255.255.0
DHCP on: range 192.168.0.10 to .20
DNS Servers: 220.233.0.3, 220.233.0.4
with PC's wireless adaptor set to DHCP
so picks up eg:
IP address: 192.168.0.10
Gateway address: 192.168.0.1
Aug 03, 2009 | Computers & Internet
I am unable to connect to the internet with my dlink
Just connect my dlink 615 to a new dell computer on the vista page for the Network and internet the broadband connection is disconnected. What can I do to connect it? When I switch the dlink network back to the old computer everything works fine.
Aug 03, 2009 | D-Link Xtreme N DIR-655 Wireless Router
There is an Excellent signal but it's not connecting
That´s because of the ip assignment you have to set the ip of the router in the same net work ip scale of you modem that connects you to your isp example if ip modem is 192.168.0.10 then the ip you must set on the wan port mustbe 192.168.0.100, also check that you are connecting the out of the modem to the wanport on the wireless router.
Hope it helps
Jun 25, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Conect the router?
1. Unplug your DSL modem’s power supply.
Find the cable connecting your modem and computer.
Unplug it from the modem and plug it into the gray port
on the Belkin Router.
If you are replacing an existing router, find the cable
connecting the computer and old router. Disconnect it from
the old router and plug it into the gray port on the new router.
2. Connect the new cable (provided in the box) to the yellow
port on the Router.
Plug the other end into the modem.
3. Plug in your modem’s power supply. Wait 60 seconds for the
modem to start up.
Plug the Router’s power supply into a wall outlet, and the
other end into the black port on the Belkin Router.
As the Router wakes up, lights will come on; recheck your
connections if the “power” and one of the “wired” lights
are not lit up in green after 20 seconds.
4. Locate the CD in this guide and insert it into your computer.
The Setup Assistant should appear automatically.
If it doesn’t, open the CD in My Computer and double-click on the
“Setup Assistant” icon.It will guide you through he rest of the setup.
If you need more help please post back,If this help please rate as a fixya.
May 17, 2009 | Belkin (F5D72304F5D7000) Router
Setup DIR-655 w/ Westell 6100 USB DSL Modem
First check if your computer can get on the modem with an Ethernet ( This is to find out if your router will work with your modem) If you cannot get on give your ISP a call to have them configure the modem for Ethernet connection. If you do get on then connect the router to the modem and your computer to the router. You can run the CD for the router or do the connection manually.
Jul 27, 2008 | D-Link Xtreme N DIR-655 Wireless Router
Computers & Internet Logo
263 people viewed this question
David Payne
David Payne
