Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
How to set carborator adjustment on Poulan Wild Thing 2375?
Hello,the starting point for adjustment screws is 2 turns out.turn in til lightly seated so as not to damage them. there are 2 or more style carbs used on saw,some have plastic caps that need to be removed(a small metal screw used as a corkscrew or pry off) or you need a special tool -splined.set high spped til runs good and back off an 1/8-1/4 turn so you dont burn it up. fine tune low spped so it accelerates when trigger squeezed and re check high speed adjustment.single screw is for idle spped-raises or lowers-if chain turns while at idle back off screw.
mowerman33@verizon.net
Posted on Oct 05, 2009
Poulan Wild Thing bar oiler adjustment
there is no adjustment for the oil flow i find the screws that hold the pump on loosen up and then leak oil
Jun 09, 2012 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My poulan wild thing 2375 bogs out when throttle
Make sure that the air cleaner and muffler are not plugged. Check the carburetor screws and nuts for tightness. After turning both needles CW to stops (lightly), back them out CCW 1-1/2 turns each. Start the engine and allow to warm up. Open the throttle and adjust the H needle CW somewhat until the engine speeds up, but is 4-stroking. Correct adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L CW till the engine runs fairly smoothly, but allows the engine to 'follow the throttle'. Set the idle speed screw so that the chain doesn't turn, but the engine keeps running. Hope this helps!
Apr 15, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Carb adjustment for a Poulan Wild thing 2375
Start at 1.5 CCW from lightly seated then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Feb 19, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing starts great but as soon as I try to cut it die
The carb low idle needs to be adjusted this is fairly common among the Poulan chain saws. Once you adjust the low idle from factory setting it will work
Feb 16, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Runs to fast
You need to adjust the idle and high speed screw settings on the saw. Consult your user manual for tuning the engine.
Feb 13, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Gas Oil Mixture
USE 50 TO 1 RATIO BETTER MORE OIL THAN LESS WORST OUT COME A BIT MORE SMOKE RATHER THAN SEIZURE
Nov 15, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
2375 ''wild thing'' poulan saw hard starting after carb rebuild
Through trial and error on fairly new Poulin Pro, found that the usual 3-half turns for both high and low was too much (flooded) (Used to be good starting point on weed eaters years ago. So, turned both all the way in, and only backed out 1-full turn. (2-halves) Saw fired up perfectly, and ran wide open just fine. Try that.
Nov 13, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
626 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
