Question about Motorola Mobility TracFone® V170 Cellular Phone
Invalad sim card need phone reset - Motorola Mobility TracFone® V170 Cellular Phone
Mobile phone with vietnam imei number says imei invalad on screen how do i get phone to work?
Hi Sean
Are you inserting a local SIM into the phone? It's locked to the Vietnam network... You have to unlock the phone to put any SIM in it. Take to any small mobile shop where they unlock phones and they will assist you.
Feb 29, 2016 | Samsung Cell Phones
When i power on my lg ce0168 cell phone it does not have the networrk of my location service provider service and try to fix this problem by reseting to factory reset and by changing the sim card but still...
abera, the sim card doesn't tequnically control your network. It is basically storing your info like contacts, and rights to use a phone with a sim card. You might need a factory reset, or even a flash to your service provider. I.E. if you are using Virizon, take it in and have their technicians reprogram the phone. The most important part of the phone, is your sim card. Mainly, because you can take it between other phones that use sim cards, and take over that phone for free or no reprogramming needed.
Jul 19, 2014 | LG CE0168 Cellular Phone
Sim card rejected
Contact your Sim Card Provider to issue new sim with same number.This is the only way.Thanks for visiting fixya
Aug 06, 2011 | Nokia 1600 Cellular Phone
My samsung SGH-E251 is saying simlock but i want the reset code for is
for a phone to display simlock, means that it is not a phone problem, but a Sim problem and does not require reset code.
The Sim card has been blocked and it need to be unblocked.
You need to contact the service provider for the Sim card you are using so that the Sim card can be unblocked.
And the interesting part about this is that the call is free.
Take care.
Mar 22, 2010 | Samsung SGH-E251 Mobile Phone - Black
Reset my cellphone
If the display says "Insert SIM," it means that the phone has no contact with your subscription card (SIM card) that is inserted in the phone. We recommend that you remove the battery and the SIM card, and clean the connectors on the SIM card and the phone with a soft brush, cloth or Q-tip moistened with any type of unflavored colorless alcohol.
At the same time, check that the card is not damaged or worn in any way, in that case, the connector may not align with the connector in the phone. Please contact your operator / carrier for a new SIM card.
Sep 21, 2009 | NEC L1 Cellular Phone
I frogot my password to unlock my samsung omnia
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your phone is locked and you don’t know the password, you can try resetting the phone. Resetting the phone will erase everything on your phone, if you agree to reset it please follow the steps below:
  1. Please remove the sim card on the phone.
  2. Place the battery back in without the sim card.
  3. Enter *2627*3855#, wait until you see “Insert Sim” message, then place the sim card back in. Hope this will work, but if not the phone needs reflash.
Jul 26, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Blackberry from USis unlocked now with UK sim I get invalad sim
First thing you need to check wheather you're Blackberry Handheld is unlocked or not.
Secondly please check with the other sim card in your Blackberry handheld if it works then there is a problem in the orange sim card you need to contact the orange service provider.
If in case none of the sim card is working in you're Blackberry Handheld, you need to get in touch with those people from where you have bpught the Handheld.
Jul 10, 2009 | RIM BlackBerry 8700c Cellular Phone
I have a T-mobile sim and I need to unlock my Samsung SGH-D407.
WOW! what a process! I don't know how you kept track of all that but , good job! Try this. It's a maybe, but better than nothing,
TEMPORARY UNLOCK:
Put a non-accepted SIM Card and turn it on. Type *#9998*3323#. Press Exit. You will get a new menu. Select Malloc Fail.
In newer phones:
#*7337#
Jan 15, 2009 | Samsung SGH-d407 Cellular Phone
Sim Card lock to Samsung phone
the phone need to re format the software .. you just need a technician to re programmed the unit.. so that all the original file or data be reseted
Mar 28, 2008 | Samsung SGH-U600
Motorola Mobility TracFone® V170 Cellular Phone Logo
177 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
