Question about Sansui DTV2760 27" TV
Describe your Sansui DTV2760 27" TV Problem Loss of picture. A very thin line goes across the screen.
  • 2,005 Answers
Vertical line = bad horizontal output transistior
horizontal line = bad vertical output transistor
Posted on Oct 05, 2009
  • alexisdel Aug 04, 2011
    you have a problem in the vertical section it cause by bad capacitor or vertical IC, if you need more tv repair tips visit this sitehttp://www.servicetron.com
Hi there My Sansui TV screen started showing thin white horizontal lines across the top of the screen. All of a sudden the screen starts condensing the picture into fine lines across the middle of the...
It is an indication that you have a problem on the vertical section on the main board. The faulty parts is the electrolytic capacitor which affect the linearity of the screen that's why you encountered that kind of problem.
I've advice you to send it to repair shop or look for a qualified technician to isolate the faulty electrolytic capacitor and do re-soldering for some dry joints on the main board.Once replaced the capacitor your unit will back to normal again.
thanks for using fixya...
Jan 07, 2011 | Sansui TVS2750 27"
THe tv is showing just a line straight across the tv
Vertical Ic collapsed need to be replaced
May 27, 2010 | Sansui DTV2760 27" TV
Screen goes to a thin horizontal line
You have bad grounds on the vertical IC and bad cap at 35volts 100mf. Resolder the IC and replace the cap. Also there are two other caps you should look for...50volts 1mf, they need replaced too!
Oct 03, 2009 | Sansui DTV2760 27" TV
Thin line across the screen
The vertical control IC has failed, this is high voltage you might need a pro to do it . Julio
Aug 03, 2009 | Dynex 20" Digital TV
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Blue streaks across picture
Can you describe in a little more detail what the symptoms are? Are the streaks thin lines or are they large thick swashes of Blue? Is yur video still visible? Sounds like it may be the blue convergence amps or the resistor tied into the amps. is there anyway you can post a picture of your screen distortion?
Jan 26, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
No picture
hi, the problem is in the vertical ossilation.. let me know
Dec 18, 2007 | Sansui DTV2760 27" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Sansui DTV2760 27" TV Logo
258 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
