Question about Microsoft Xbox 360 Console
Screen went blank and 2 rings on left side started flashing red what do i do?
  • 767 Answers
It's over heating . Does it do-it with in 30 sec of turning it on?
and does the fan rev up to full speed? If you answered yes to
either of these questions . Then the problem is the heatsink for
G.P.U or C.P.U has become dislodge ,and broken the thermal
seal , this can happen if the box takes a little fall.
The Fix is to open the unit up and press down evenly and firmley
on the G.P.U. and C.P.U s heatsink to re-seat it that should resolve
the problem.
Rob
Posted on Oct 05, 2009
Sony 55HX823
You have a bad power board most likely, replacing it should fix the set, if your quite electronically inclined you could repair it yourself generally for a couple dollars.
Dec 03, 2017 | Televison & Video
TV stopped working
Your description suggests a power supply problem
Feb 23, 2013 | Televison & Video
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Plasma tv stopped working
hi i have a pioneer plasma tv pdpro4e all it doses is flash green red green red and on the mediar reciver as well tv dont come on help please
Dec 31, 2009 | Televison & Video
During game screen went blank. flashed red ring on 1 and 3
That means your console is overheating. Make sure you are providing proper ventilation (atleast 12 inches in the back and 3-4 on each side minimum) Also make sure that your power brick is not sitting in the carpet as this can cause it to overheat.
Lay your 360 horizontal to give it better airflow and reduce heat in the future.
Dec 25, 2009 | Microsoft Xbox 360 Console
LG 26LG30 screen suddently went blank. Light flashing blue/red
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 14, 2009 | LG 26LG30 26 in. LCD TV
Xbox360 2 flashing red lights left side of ring
Call 1800-4myxbox
They should repair it
This is a defect that should be covered by warranty.
The soldering has come loose on the CPU.
Jan 15, 2009 | Computers & Internet
Heard a pop and screen went blank - won't come back on.
Your Lcd Projector Lamp/DLP Television Lamp went out
its about $165-$200 to replace if not under warranty
Nov 28, 2008 | Hitachi Televison & Video
TH-50PX60U Panasonic Plasma - Flashing red light (now, reset, apparently) - and, missed what code was. Now, left half of screen blank. Right half normal. I managed to get it back, briefly, and while it...
This is either a logic problem or a connection problem within the display controls. I have sen this with a power suppy problem as well. Since the picture was fine before the outage, it is unlikely to be the panel. Anything else should be covered under the extended warranty.
Dan
Sep 03, 2008 | Panasonic Televison & Video
360 issues
Two Red Lights
The two left quadrants of the Ring of Light flash red on the front of the Xbox 360 console
This behavior occurs when the internal temperature of the console exceeds the acceptable limits. You may think of this as too hot, overheating, and so on. Make sure the fans are operating and the system has adequate ventilation.
Since you've been inside it's possible that a heatsink or some other part of the cooling system is not working properly or is loose. Check all these!
Good Luck!
Nov 17, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
50 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
