Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424
Temperature doesn't stay constant, ranges from 4 to 34 degrees
No matter if I put the temperature setting at maximum or at minimum, the temperature of the freezer cycles from 4 to 34 degrees.
  • 1,869 Answers
You need to replace your cold control
Posted on Oct 05, 2009
I have a freezer bosch log/xx model dc125e12raw5r600 tempretureis only -5 is this normal
Hello;
My name is Peter. I am a retired field service refrigeration technician.
The ideal temperature range for a freezer is -2/+2 degrees F. This temperature range can very depending how full the freezer is. If your freezer is jam packed -5 degrees is good. If it is half full, +2 degrees F. is a good setting.
Too high of a setting such as -20 degree F. will cause freezer burn (bone dry your food).
Your compressor will kick in and cycle until it reaches the temperature setting. You can save on your electrical bills based on your evaluation of the necessary temperature setting.
Oct 19, 2014 | Bosch Freezers
Chest freezer suddenly stops working then will start again later
This is normal if your freezer is in good working condition. If your compressor runs constantly then there is a problem. Once the unit reaches the set temperature the compressor shuts down. The set temperature should be between -2 & +2 degree F. The set temperature also depends on how full the freezer is. There will be a time when the freezer like refrigerators will shut down. This is relative to the term, "Frost Free". The unit will shut down for about 10 minutes. This occurs ever 8-10 hours. The heater turns on to defrost your freezer coil. It sounds like you are in good shape.
Apr 18, 2014 | Westinghouse Freezers
Is there an ambient temperature range outside of which the freezer won't work well? Will it go down to zero degrees?
It seem ambient temperature will not affect so much inside temperature since any freezer has good insulation. Normally freezer will go down to below zero degree
Oct 10, 2010 | Frigidaire 5 cu. ft. / 142 liter Chest...
Unsure how the temperature dial goes. Is it l. or r. for colder?
Hi Normally temperature dial has at left maximum temperature while right is minimum temperature.
You can feel ( hear ) actually the sound of motor/compressor when it is run. Running motor will produce low temperature. By this you can decide where the set point should be made
Sep 09, 2010 | Danby 3.6 cu. ft. / 102 liter Chest...
I have a Frigidaire model GLFU206FWA upright freezer. The temperature control won't go above 10 degree F. This causes freezer burn on some foods after a period of time. Is there a way to regulate the...
Good day,
Manufacturers of freezers do not give the option of running the machine much above that temperature. Normal operating temperature for a freezer is about -2 to about 8 above F.
Otherwise people could accidentally set the temp too warm and cause a loss of food.
Some appliance parts houses carry universal thermostats that could possibly cover the temperature range your looking for, but 30 degrees is far to warm to preserve frozen food safely.
Jun 21, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
My wife and I bought a Kenmore chest freezer (14.8 cubic foot) about 6 weeks ago. It is made by Frigidaire for Sears, and the model number is #253.165.42105, serial # WB94341279. It has been working OK. ...
This is well with in factory specifications. Hot air rises and cold air drops. Because a chest freezer does not have a fan to circulate the air it is normal for the basket to be warmer than the bottom of the freezer. The bottom of the freezer is used for food you want to keep for a longer period of time.What you store in the basket is food you will freeze for a short period of time. Ice cream should not be kept in the basket. As you fill your freezer with food you will find that the temperature will equal out because the frozen food will take up the place of the frozen air which will give you a more stable freezer temperature.
Try your test when you have it full of food.
Dec 29, 2009 | Frigidaire 14.8 Cu. Ft. Chest Freezer -...
Proper temp. range in freezer
Hi dgh1,
The freezer should stay within 5 degrees of 0 while in operation. While in defrost the freezer may reach as high as 20 to 25 degrees. If any higher temperatures are reached your food will spoil as they are defrosted and refroze everyday. If you find that the temperature is allowing your food to defrost you may want to replace your defrost thermostat. This device is located on top of the evaperator coil inside the back of the freezer. It is made to turn the heater off when a temperature of 55 degrees is reached. One other possible problem could be your defrost timer is taking to long to restart the cooling cycle after defrosting. I hope this will help you and please send any other questions you may have, I am happy to help. and dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 28, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Upright freezer
if its running all the time there is a system fault it strugles to pump gas. you will need a system tech to repair this. if it has r12 on the label afraid to say it is then scrap
Feb 06, 2008 | Candy Freezer CIF125
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424 Logo
166 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
