Question about Gestetner Copier
Gestetner 3222 The display "Add Toner" is on and the machine will not copy even though I put a new cartridge in?
  • 417 Answers
When you put a new cartridge in I take it you have removed the black cap that sits on top of the toner bottle (if you haven't remove it) The machine as default allows a 15 second gap from when you open the door and put the cartridge in to when you close the door. If you are too fast at changing toner open the door wait 15-20 seconds then close the door . Machine will then show on the control panel that toner is loading. If this does not work repeat two more times if still does not work then the drum unit (Photo Conductor Unit) is not accepting toner you will have to replace it.
Hope this works
J
Posted on Dec 26, 2007
Wat does it mean if the machine is saying toner cartridges not set properly
the main reason for this could be when you replaced the toner cartridge you have either not put in correctly or an incorrect toner put in. Check the other cartridges to see if when you remove one you get the same error if this is the case you could have a faulty toner. Is the toner an origina Gestetner toner you may need to return it...K
Jun 03, 2011 | Gestetner DSc224 Copier
We've loaded a new ink cartridge, but the printer doesn't recognize it. The model is a 3222
Hello!
You have a very old machine...
Assuming that you are putting the right bottle... It could be several problems.
Faulty clutch.. faulty toner supply unit... faulty drum Unit...
The best advise i could give to you is to call a technician...
See you
May 04, 2011 | Gestetner Copier
"Toner not set" persists, even though new
Hey!This happens a lot!Take out all of the paper,Open the cover,take out toner,put it back and add paper!!If this does not work then the toner sensor might be faulty!Good Luck!!
Nov 03, 2010 | Canon imageCLASS® MF4150 All-In-One Laser...
After installing an off brand cartridge for a Gestetner copy/fax machine, it only printed half pages and the printing was poor. They said the brand name cartridge was no longer available. please...
There are many different companies that sell compatible toner, and the quality varies greatly. You should try getting your money back from the company you bought that toner from, and find a new supplier if you can't get it from Gestetner. Premier is a company that sells compatible toner for many different machines, and they usually get pretty good reviews.
Aug 05, 2010 | Gestetner DSm620d All-In-One Laser Printer
How much is gestetner 3222 worth
This machine is made by Ricoh and the same as a model Aficio 220. Pretty old and not worth much. If it runs and makes nice copies then $300 to $400. If it does not work or makes poor copies then next to nothing. I specialize in buying/selling used refurbished copiers and am very familiar with this model.
Good Luck and Thank You for using Fixya.
Apr 01, 2010 | Office Equipment & Supplies
Printer wants toner cartridge replaced, though not empty
unfortunately the drum within the cartridge has reached end of life so changing to a new drum cartridge would resolve this issue.
Mar 25, 2010 | Panasonic KX-FLB801 All-In-One Laser...
I am totally lost on how to add more toner to the
You can go here and download the manual. Even though it's a Gestetner...it cross references to a Ricoh Aficio CL2000. Ricoh builds all of their machines. Look for it under "printers"..."color":
http://www.ricoh-usa.com/downloads/manuals.asp?tsn=Ricoh-USA
I don't know if this will solve the "blue ink everywhere" problem
*Please rate me :)
Mar 14, 2009 | Gestetner Office Equipment & Supplies
Will not add toner
Reinsert cartridge and restart it by unplugging or powering off
It should refresh the memory
Good Luck
Jan 29, 2009 | Gestetner DSm515pfd Digital Copier -...
Gestetner 3222
Open the front door and close it and check if the display reads loading toner. Try this for 3 times.
If Add toner indicator is still there, check that you had removed the black cap of the toner, before you replaced the toner bottle.
Remove the bottle from the holder and check inside the neck of the holder if there is something blocking the toner supply. (sometimes the inner plastic cap of the previous toner is stucked in the neck).
Check and clean the toner bottle holder unit.
Another problem can be worn gears in the lower development unit and within the dev. bias roller.
Good luck and please rate me, thanks.
Jan 27, 2009 | Gestetner DSm622sp Digital Imaging System
Gestetner 3222 toner
I take it that you removed the black cap on the toner bottle OK thats out of the way open the door remove the toner as you would to replace. Remove the toner bottle look inside the bell behind the green handle and check that you can see a claw type thing if you cannot remove obstruction. Refit the toner close door and wait until machine stops and see if toner light goes out. If not open door wait 15 seconds close door and machine will start loading toner again. You may have to do this 5-6 times if it doesn't work after this then likely thing is the toner motor faulty and will need replacing
Thanks J
Nov 27, 2007 | Brother HL-2040 Laser Printer
173 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
