Question about Acer Aspire One PC Notebook
Acer Notebook Keyboard
This evening when I turned on my computer i tried to type in my password and found out that the "j" key was stuck. so i plugged in a keyboard, when I unplugged the outside keyboard i come to find out that on my notebook there were several keys stuck on the notebook, such as "a,k,l,j,s" but then most of the others are working just find. How can i fix this??
  • 408 Answers
Replacing the keypad should fix the problem
Posted on Oct 10, 2009
Acer aspire one D270-1824
I think it's an hardware issue.Remove your keyboard and reconncet the cable if this doesn't work check to see whether it works with an external mouse and keyboard if you have one.
Jul 13, 2014 | Acer Aspire 5315 Notebook
How do I unlock my acer aspire one nav50 keyboard?
try a usb keyboard, that might let you type.
May 12, 2014 | Acer Aspire One PC Notebook
I have an acer aspire one and the keypad is not working its typing the wrong letters any suggestions why. It is not a year old yet
This is either a keyboard or setting problem. If the operating system is told the keyboard is a different type or the wrong location (language) you get weird results. Can even be a stuck key or even a function setting. Laptops use the FN-F7 key (usually) to turn on the numeric pad that is in the keyboard. That will also give you strange results.
If the keyboard doesn't have a stuck key and actually is the problem then it can only be replaced.
If its just a setting then you need to look under control panel for the keybaord setup and make sure it is set to the correct location language and type. A standard laptop keyboard is a 84 key and I believe the ones with number pads are 101 key.
Nov 08, 2010 | Acer A2909.001 Aspire 1800 Aspire 9500...
When I turn my computer on, I get a loud alarm
I had the same problem - almost took it apart and tried to get to the HD, but then realized it was a stuck key.
Try tapping the keyboard, maybe one key at a time, just to be sure that there isn't a key that the computer is registering as pressed. Then try rebooting.
Hope that helps!
Oct 05, 2009 | Acer Aspire One Netbook 8.9" Notebook
Keyboard letter not working
Disabling just a single key on Windows is possible, but it is highly unlikely that a computer technician could have gone to Control Panel to remap the keyboard.
More likely, one of the keyboard switches is broken, and the A letter is not working anymore. This happens quite commonly, and when the problem occurrs, the keyboard will be replaced.
You can find out if problem is hardware or software going to CMOS settings, and chosing to set a password. Then setting BIOS password AAA. If the A letter works in there, then the problem is software, and it can be fixed reinstalling Windows, if A key does not work in BIOS settings, then the keyboard must be replaced.
The keyboard for an Acer 5315 is not an expensive part, and can be purchased for less than $20.
Acer Aspire 5315 Keyboard Laptop Notebook replacement $15
Acer Aspire 5315 Keyboard Replacement
If a repair job had recently been done, and the laptop came back withthe keyboard problem, try calling back the repairman, and insisting for having the repair done at a reduced fee.
Sep 16, 2009 | Acer Aspire 5315 Notebook
Keyboard doesn't respond
This world be a issue with the main board if you get nothing but neeping on both inputs, how about trying a usb keyboard to see if that shores it up if not you going to need service on this Acer..
May 22, 2009 | Acer Aspire One PC Notebook
I restarted my computer and keyboard not working
It sounds like you might have accidentally turned on the laptop number lock. I am assuming you are seeing that characters are being typed, but the password is not accepted. If this is the case, try turning off the num lock by pressing the FN key (usually found by on the lower left by the CTRL and/or ALT keys).
If this doesn't work, trying entering the BIOS when starting the computer (usually by pressing F2 repeatedly when you see the DELL logo). In the BIOS look for an option for the numlock and turn it off.
Last shot - I have seen a few times where num lock is remembered when an external keyboard is used and then stays enabled on the laptop after it is disconnected. If you used a plugged in keyboard and/or use a docking station, you may want to try plugging in the keyboard again, disable NumLock (above the number pad on the right) and then shut down. Remove the external keyboard and I suspect the laptop won't have this issue.
Hope this helps,
Chris
Mar 23, 2009 | Dell Inspiron 8600 Notebook
Sticky keyboard
You can carefully take off the keys and pop them back on. Use alcohol to wipe up any stickiness.
G'luck
Oct 24, 2008 | Acer Aspire 5100 Notebook
Keyboard not working on Acer TravelMate 2350
Yes but you still wont be able to enter your passwords etc Your key board is faulty
Sep 13, 2007 | Acer TravelMate 2300 Notebook
Acer Aspire One  PC Notebook Logo
112 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
