Question about Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024
Plugged in freezer after standing 3 days unplugged compressor ino
Freezer was transported to or house on its side.
We let it stand 3 days with door open and to clean.
Plugged it in and had a sizzle sound no compressor doesn't kick on.
Fan and light work
    Problem Solver:
  • 4 Answers
That sizzling noise i suspect is either the compressor overload or start capacitor burning out .
You need to look in connection box on side of compressor,the relay should just pull off once cover is off.BEWARE even with the freezer unplugged there is a charged capacitor connected inside this box and will give you a nasty shock should you touch it! with insulated pliers touch all terminals to each other and earth to make sure capacitor is discharged .You should be able to get astart capacitor and overload from local repair shop there not expensive if this doesn't fix it the compressor is possibly locked up and will need replacing
Posted on Oct 05, 2009
When i moved my kic chest freezer model kc0021-Aa, I heard an light explosive sound and now the freezer does not go on.
The following is the GE moving instructions. If you have started before the 24 hour rest period and the unit had been rotated from vertical have the compressor inspected.
FREEZER MOVING INSTRUCTIONS Please use the following steps when relocating an upright or chest freezer:
  1. Disconnect the power cord from the wall receptacle.
  2. Remove the food, defrost, and clean the freezer.
  3. Use blankets to protect the freezer finish from scratches.
  4. Place the freezer on its side for moving only if you have no other choice.
  5. When transporting a freezer, keep it in an upright position. If transporting it in an upright position is not possible, lay it down on the compressor side of the unit. Be careful to secure the door to prevent it from opening.
  6. If it has been transported on its side, set it right side up in its final location and allow the freezer to sit for the same amount of time that it was on its side (24 hrs max.). Do not plug the unit into the electrical receptacle without allowing this settling time. The unit can be damaged if it is plugged in prematurely.
If the unit was transported in an upright position there is no waiting time required.
Hope this helps?
Apr 07, 2017 | Freezers
Product thawed to cold in freezer...
If you had the door open for that long you will need to unplug and allow the ice buildup that happens when door is left open to thaw. After this you need only to plug the refrigerator back into the power source.Let me know what happens It is not going to work correctly until this is done. Sea Breeze
Jun 15, 2013 | Frigidaire 20.6 cu. ft. / 583 liter...
A church member donated a freezer to our church, I had to lay in down to transport it. I plugged it in , the light came on but after five days it did not cool ,one bit. Did harm the unit by laying it down?
You pluged it back in after you laid it doun. You needed to let it stand back up to let the freon to get to the condencer. You can try to unplug it for 2 days now to see if the freon will go back down or you might need to have it serviced now.
Good Luck
Aug 14, 2010 | Frigidaire 13.7 cu. ft. / 388 liter...
Yesterday, my dad brought me a working GE upright freezer from his house, transport time about 45 minutes. The freezer was working fine before he left his house, he did tip it little bit to load, unload...
You should try to un-plug the freezer and let it stand up-right over night to re-settle the freon back down inside of the compressor.
The compressor should normally get hot if it is doing it's job right, and there is a starter for the compressor motor (usually it looks like a large capacitor) that could have failed, or the defrost timer (if it has one) could be stuck, and you should be able to see the small dial on the defrost timer slowly turning, and if it does not turn, then replace the defrost timer.
Jun 07, 2010 | GE 13.7 cu. ft. General Electric Upright...
How to move a whirlpool freezer on its side
You can lay the freezer on its side to move. If it is on its side for over 30 Min's though you will need to stand it up for 24 hrs before you plug it back in to the power. You need to do this so the freon settles back to the compressor.
It is always best to move them standing up.
Apr 23, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Briefly unplugged and now when plugged back in freezer wont turn on?
fairly unusal but ...posibly vapour locked.... people transporting fridges and freezers laying them down or chest freezers standing them up in a truck or trailer (taking them to the cottage) have this problem all the time unplug it for 24 hrs should cure it Good Luck
Oct 12, 2009 | Frigidaire 13 cu. ft. / 368 liter Chest...
Freezer defrosted and the motor won't start back up.
From what I can gather, you have a self defrosting freezer and the "motor" you speak of is the fan inside the freezer. If this is correct, do this:
Unplug freezer. Unload all food into coolers or other freezer space. Leave freezer door open for a day to allow it to manually defrost. Plug freezer back in after minimum 24 hours and confirm fan running and cooling before loading back up with food.
Mar 28, 2009 | GE 16.7 cu. ft. Upright Freezer FUF17DTR
Kenmore Upright Freezer compressor running 6 seconds every minute
Usually the compressor runs pretty warm anyway. However if you think it's too hot I would start with the condenser coils located either under the unit or on occasion they are located on the back. The air flow across these coils as well as the airflow around the compressor must be maintained. I forgot to ask if the condenser fan is running. Check and make sure that the Fan is running and the air flow is good. Also, When you transported the unit did you move it standing vertically like it normally stands or did you lay it on its side. If you transported the unit on its side you must wait a minimum of 24 to 48 hours prior to start up or the unit could be ruined permanently. The refrigerant has to be utilized through the compressor as a gas. If the unit is on its side liquid refrigerant could be introduced into the compressor and can cause permanent damage. If this is the case I recommend that you turn the unit off at once and wait the 36 hours for the Refrigerant to settle then try it again. This transportation rule applies for any appliance That uses refrigerant, Air Conditioners etc. These units are not that hard to diagnose. The only other item that is usually a problem is the defrost timer. It is not very expensive and can also cause some of the same symptoms that you are eluding to. The defrost timer allows the freezer to periodically shut down to prevent the buildup of frost or ice on he evaporator coils and on the inside the unit. If it is defective, then the unit will either run all the time and cause the evaporator coils to freeze up or will not allow the compressor to switch on and it will not freeze like it should.
Nov 12, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore upright freezer
It is best to unplug the unit, open the door fully and let stand 24 hrs. to thoroughly defrost. Empty the drain pan if so equipped.
Wipe out interior with a dry cloth, then locccck or otherwise secure the door so that it cannot open. Place a moving cart on the non-hinge side to transport it, and never lay it on its back.
Jun 16, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Noisey fridge freezer
Please check the fallowing:
-Loose flooring or floor not firm.
- Cabinet not level.
- Tubing in contact with cabinet, other tubing or other metal.
- Drip tray vibrating.
- Fan hitting another part or worn fan motor bearings. Unplug the unit and rotate fan manually by your finger.
- Compressor mounting grommets worn or missing; mounting hardware loose or missing.
- Free or loose parts causing or allowing noise during operation
- Check compressor it may contact with tubing or other parts.
- Check the body of your unit is not touching the wall or other object
Jan 25, 2008 | Freezers
Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024 Logo
175 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
