Question about Whirlpool GHW9400 Duet Washer
I am having the same problem, should this be a recall.
It seems like a lot of people are having this same problem. Right after the warranty ends this F6 error accures. What can I do, I boight thus pair to replace my Harvest gold units, What to guess how old they were?? well after just over 2 years and the money I paid for these machinesm I wouldnt think they should be breaking already,, Is there any help out there??
  • 304 Answers
F06 - Drive motor tachometer error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Replace failed component
The link to the service manual is below but I might suggest calling in a Service tech as being wrong could be VERY expensive.
Duet Service Manual
Posted on Oct 05, 2009
Has anybody had trouble with the automatic transmission in a 2012 Ford Focus
Check dealer for recall or TSB. Seems there is a problem with the valve body.
Jan 01, 2015 | 2012 Ford Focus
Kenmore elite fridge recall
I could not tell you without a specific model number. You might try doing a web search for your refrigerator's model number and the word "recall." I assume the refrigerator's warranty has expired, or you would not be asking about a recall.
In the meantime, talk to your Sears service manager and see if they will make an accommodation for you on the ice-maker repair. Sometimes companies will give a courtesy extension on a warranty if the problem occurred during the warranty period, but the warranty expired before repairs were done. However, since you do not mention requesting repairs to the ice-maker before the end of the warranty, you can't expect much joy there.
Sep 09, 2014 | Refrigerators
I have a 2005 Jeep Grand Cherokee with 36k miles.This morning I got stuck in the snow and was going from to reverse to drive numerous times trying to get out.The transmission light came on.The level of...
There is a recall on your tranny take it to a Jeep dealer and tell them you waant the tranny recall done ours did the same thing, there is some seal that goes bad.
Also, I quote this comments form other owners with this problem:
Our 2005 grand cherokee had tranny poblems at 30,000 mi. It was a bearing in the trans. They rebuilt it under warranty. the symptoms: when you shift from park to drive and step on the gas there was a delay and it would bang onto gear. They said this was a problem on a lot of Laredos. Now at 50,000 more tranny problems. not shifting right, the engine light is on and it lights up around all of the tranny indicators on the dash PRND will all be lit up. After several trips to the dealer it is the Trans Control module or TCM at a cost of 400.00 and of course not covered in the 70,000 mi warranty.
Them, I suggtes scanned the TCM for any stored codes there.
Good luck.
Jan 27, 2011 | 2005 Jeep Grand Cherokee
2007 Impala. shifter locked up right after warranty was up. Had is replaced at the dealership. 13months later, 1 month after the warranty shifter locks again. Why does this keep happening? Got to the...
The dealer has the power to goodwill warranty something that is out of the 3yr/36k warranty,but if you go into a dealership and are all crappy with them they won't do ANYTHING for you.Call GM yourself and explain to them your problems.The number should be in your owners manual.Don't get crappy with them,just explain your concern of having to fix this issue several times and you are not happy.Also tell them you are looking for another car and even though you want to buy another gm product you are reluctant to do so because of all the problems with this one. REMEMBER to be tactful as this will usually get the best results.
Dec 17, 2010 | 2007 Chevrolet Impala LS Sedan New Cars
GE Model GSH25JSRF SS is clicking non stop, the click comes from a small panel on the back right of the fridge. Started out that the water and ice dispenser didn't dispense. Then the clicking just came...
Is it still cooling? I had an issue where there was a clicking noise from the back panel and the fridge did not cool. Pulling off the panel the noise seemed to from a box on the circuit board. Turns out there was a problem with the controler board and after some research I found that the board was covered under a recall. GE ended up sending a guy out to replace the board at no charge. Pretty cool being that if was after the warranty had expired; but I guess it makes sence since there was a recall. Good luck.
Dec 10, 2009 | GE GSH25JFR Side by Side Refrigerator
Broken subframeon my esteem. Is there a recall or any compensation. The car was in good shape and now it seems to be worthless. This doesn't seem reasonable.
hello everybody,
I had the same problem on a 2000 suzuki esteem and I checked with the dealer. it looks like there are a lot of problems with the subframe, so suzuki extended the warranty to 12 years or 288 k. I know is a late answer, but might help somebody.
Oct 27, 2009 | 1999 Suzuki Esteem
Slimline if on, but won't boot up and there is no signal being output to the monitor
HP had a lot of problems with these PCs, the video card is on-board and seems to be failing a lot. They even had a recall on these, but unless it is still under warranty you are out of luck. I am currently working on one right now that has the same problem. I installed a low profile ATI 4600XT video card and still nothing. I went into the BIOS and somehow navigate to the right spot to tell the PC not to use the on-board, but instead use the PCIe. It was a real pain when the screen is having a sync problem and everything looks funky. But even after that it still tries to boot using the defective on-board. Hope this helps.
Sep 29, 2009 | HP Pavilion Slimline S3123W Desktop PC -...
FRONT END JUST DOES NOT SEEM RIGHT. SLIGHT GRINGING WHILE TURNING INTO OR OUT OF PARKING. ONLY HAPPENS OCCASIONALLY. ON TURNS NOTICE A VERY MINOR CRUNCHING.
There's a problem with the steering shaft coupler. Ours did that and made a thunking sound too. Dealer covered it under warranty and put in a better shaft. I don't think a recall has been put out, but if you still have warranty, tell them to replace the steering wheel shaft while you can...
Jul 13, 2008 | 2005 Buick LaCrosse
Insignia LCD26 26 in tv
Unfortunately I know mine's already out of manufacturer's warranty so I know they're going to just tell me to upgrade or let me know that I should've purchased additional warranty when I bought it! I know it sucks & yes a LOT of people seem to be having issues with this monitor but that's the cost of buying the cheap stuff! We get what we pay for in the end...
Jun 19, 2008 | Insignia LCDTV26 26 in. Television
Washing Machines Logo
177 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
