Question about Refrigerators
Is it possible to change door to open other side?
Is it possible to change doors to open other side?
  • Jyackle5
    Jyackle5 May 11, 2010
    Can we get make and model #.
    Problem Solver:
  • 4 Answers
Yes if there are screw holes to mount hinges on the other side and the handle is removable. this is not the case on all fridges but most you can .consult with your local dealer or handbook to be sure
Posted on Oct 05, 2009
How do I switch the door opening to the other side? I would like to change the dryer door opening from the left side to the right side. By looking at the dryer it appears this is possible.
Hello, Frazer -
Without knowing the make and model of you clothes dryer, it is a challenge to provide you with the precise directions for changing the swing of your dryer door. With that being said, this YouTube video may prove helpful to you: https://www.youtube.com/watch?v=VW9183PsCLc .
How did I find the YouTube video? Using Google I entered the following search statement, with quotation marks, as indicated: "clothes dryer door swing" .
This web page with written directions may also prove helpful:
http://homeguides.sfgate.com/change-dryer-door-left-right-66754.html .
Best wishes.
Dec 17, 2017 | Dryers
Why wont my 1994 acura legend car door open right after changing tire ?
possible jacked the car in the wrong place and the door sill has bent up into the door opening
take it to a panel repair shop for a proper diagnosis of the problem
Sep 18, 2016 | 1994 Acura Legend
Is it possible to reverse the opening of the door on my LG WM2487HRM The door is hinged on the left side. I would prefer the hinge on the right side
Unless the fixing holes are already on the other side, and the door is the same internal shape UPSIDE-DOWN (as it would have to be if it were changed over to the other side), the answer is no. I would expect the manual to have the appropriate information if the washer was designed to have exchangeable door opening positions.
Sorry- know the frustration- ask my wife ;-0(
John C
Mar 29, 2011 | LG Washing Machines
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
REVERSING DOOR SWING
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
I have a Maytag Refrigerator Bottom freezerMBR2556KES2 with a left hand opening can i change the opening to open from the right? gary
it doesn't appear that this is possible with this unit, typically anymore you can't change the doors on refigerators as there are too many services (ice, water, freon) going through the door, and yours has a permanently attach tag at the top right and there are no holes on the other side of the door for the handle. some would think that you could turn the door over and that would put the handle on the other side, but i am betting that it will not work
Jun 15, 2010 | Maytag MBR2256KES / MBL2256KES
Fridge door does not close on it's own. possibly missing spring.
There are no springs to assist refrigerator doors to close.
The fridge doors can be made to close themselves by adjusting the height of the feet of the fridge. "Pitching" the fridge slightly away from the hinge will accomplish this. If the foot on the hinge side of the fridge door is slightly higher than the foot on the handle side of the door, the door will usually want to close by itself. If the fridge is a side-by-side type and this is done, one door will close by itself and the other will want to remain open (or open fully). In this case, it's best to have the fridge as close to level as possible.
I hope this was helpful.
Nov 28, 2009 | Amana Refrigerators
Drivers side door not working
You need to change the power door regulator on the doors , to make sure they are not defective please check the power door fuse ,if they are blown out please change them if they don't open then you need to change power door
regulator on your car...
Good luck..
Apr 26, 2009 | 1996 Toyota 4Runner
MAYTAG MDBO880AWB LEAKS FROM LEFT SIDE DOOR ONLY SOMETIMES AND
If the door is sprung in a manner that one side is flush and not other then most likely the hinge has been bent outward by the weight placed on it.the best solution would be to replace hinge,the spring only adjusts the tension for door closing. There is a slight possibility that either the frame or the door has bent in this manner so before buying hinge check frame and door for damage,after doing repair would suggest adjusting front legs of unit to raise front up a bit to ensure leaking wont continue
Apr 21, 2009 | Dishwashers
Rear passenger side door will not open
the problem would be the wiring on the door, possible a break in the wire, therefore the window and the central locking isnt working, possibly the earth wire is broken, open the front passenger door and u should see a sleeve connecting to the rear door, that is where the wiring to the door is, check ! also i would check the fuses. thanks
Feb 15, 2009 | 2005 Jaguar X-Type
Windows stopped working
Open the drivers door and look between the door and the door pillar(just above or below the hinge) you should see a black rubber ribbed covering. This has all the wires for the door locks,power windows, etc. in it. Good possibility that there is a wire or wires broken in there from all the door opening and closing of the door over the years.
Nov 11, 2008 | 1994 Chevrolet S-10 Blazer
Refrigerators Logo
119 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
