Question about Samsung LN-T5271F 52 in. LCD Television
I have a samsung 52 inch lcd tv and it takes about 10 to 15 minutes before picture will come on. During that time it is just showig color bands. Picture is perfect once it's been on for about 1/2 hr. What's up.
  • Anonymous Mar 26, 2014
    I have a 5 year old 52 inch Samsung LCD TV (LN52A630). When the TV is first turned on it has about 3-4 horizontal lines or bands and it has a ghost effect where the words/images are doubled. These usually clear up after 10 minutes (however the time it takes to clear up keeps getting longer). Yesterday when I turned it on it had a black blob that kind of floated around the screen. Also, the picture/words on the right side of the screen where lower and much bigger than the other side of the screen. These problems also cleared up after a few minutes and the picture is fine for the rest of the day. Does anyone know what could be causing this and how much it costs to repair? Thank you in advance for your reply.
  • 934 Answers
T-con or timing control board is defective or the syscon link board that feeds the panel itself... For that problem you'll need to take it to a shop - the whole Tv has to come apart to get to the T-con so it can be properly tested...
Good Luck!
William Rayburn, CET
Premium Technologies
Posted on Oct 05, 2009
SOURCE:
My samsung 52
go direct to samsung and post ur complaint to them, first of all was there a warrenty? and if u do go to samsung there more likely to help u, the others r out for money
Dec 23, 2011 | Samsung LN52A650A LCD TV
I got multiple thin colors on the middle of the screen
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display issue (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further updates will be on my Facebook page.
Aug 17, 2011 | Toshiba REGZA 52RV530U LCD TV
2/5 of the screen has vertical lines multi colors. Is this a fixable problem?
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further resolution updates will be on my Facebook page.
Jul 24, 2011 | Toshiba REGZA 52RV530U LCD TV
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
My 52 inch samsung flat screen has a black picture. the tv is on and you can hear it fine, but no picture.
u may have a bad lcd panel or s/t-con board , but first check power supply for bad capacitors
Apr 10, 2010 | Samsung 52 in. Flat-Panel LCD HDTV
I have an 8 inch wide yellow vertical band in the picture of my 52 inch LCD Samsung TV, what is this? I just moved into my new house a couple of weeks ago and purchased a new 52 inch TV, We are without...
If the band is there within the menu then the screen has a fault. If not then possible signal ghosting issues and a proper aerial should fix that.
Jun 30, 2017 | Televison & Video
Reccomended settings for Samsung 52 inch LCD tv
I have recently posted a question regarding my Samsung 52 inch LCD hi def television. After doing some research online and reading some others experiance I have adjusted my settings in the menue of the tv to provide the best picture.
May 30, 2008 | Televison & Video
Samsung LN-T5271F 52 in. LCD Television Logo
784 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
