Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
How to install dlin router
How to install
  • D-Link Master
  • 32,281 Answers
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Posted on Oct 05, 2009
Nstallation cd is missing for DIR-600...Hello, If you don't have the installation disc anymore, you can...
open the setup page of the router and change the settings manually.
Like other routers, you can install wireless router without installation CD also,
Read how to setup router without installation CD
Jul 04, 2012 | D-Link DIR-600 Router
Wrt120bn wireless router cd installation
Are you trying to setup Linksys router?
You can run the installation CD to setup Linksys router or you can do it without installation CD also.
Connect the computer to the router with the Ethernet cable.
Open the setup page of the router.
Change the Internet connection settings.
Create a new wireless network.
Connect to the network.
I will suggest you a website that you can try to setup your Linksys wireless router without installation CD.
May 21, 2012 | Linksys Wireless-G WRT54G Router
I lost my belkin installation cd
You do not need the installation CD to use the router. Check this link to download the user manual and quick install manual. As well you can download an updated firmware for your router along with installation instructions.
Good Luck.
May 06, 2011 | Belkin F5D8236-4 Router
New to wireless networking, never used before. Purchased a dlin dir615 router for my home and also to be able to connect our new archos 101 tablets at home. I followed the setup disk to connect the router...
Have you updated your firmware on your Archos 101? If you can get to a public wifi hotspot like at a McDonalds or Starbucks you should be able to download the latest firmware (you can force the tablet to check for it by going to Settings - About Device - Firmware Update).
The latest firmware included several fixes for WiFi issues that previous firmware versions struggled with.
I would try that, attempt to connect again at home, and if it's still not working switch your troubleshooting focus to the router itself.
Feb 24, 2011 | Archos 101 Internet Tablet
I do my ipconfig and i have 169.xxx.xxx.xxx, how can i change this? my dlin product is an dwl-g710 version bx
Often a 169 IP address indicates a modem issue, or IP resolution issue. When I see this, I always begin by powering down my modem, waiting a few secs, then powering back up. This will restart the modem-to-router IP lock, and you should be back up pretty quickly. If that doesn't work, or at least doesn't the very first time you try it, then power both modem and router down, wait about 10-15 seconds, then plug 'em both back up, router first by about 5 seconds.
Feb 15, 2011 | D-Link DI-704P Router
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
I have DI-604 in line between Windows Vista computer and cable modem. Works fine. Bought DIR-615 (wireless). Several places instructions say, ""Insert the DIR-615 CD into computer and click Install Router....
Contrary to the many warnings not to install the router before starting the installation with the CD, I got the installation to complete only AFTER I installed the router inline thusly:
1. Power everything off.
2. Remove DI-604.
2. Install and connect 615 router to computer and to modem.
3. Apply power to router and modem.
4. Apply power to computer and wait until Windows loads.
5. Insert 615 installation CD.
6. Follow the directions.
Nov 22, 2009 | D-Link DIR-615 Wireless Router
Can I install my belkin router without setup cd?
Setting Up Belkin Router Is Easy With Right Steps -
How to Install Belkin Router -
Dear Friends Setup Your Belkin Wireless Router With Instant Steps -
1- Connect The Modem With Router (Make Sure Router Is Powered On )
2- Open the Default Gateway with 192.168.2.1 and Configure The Router As You Like .
for more visit
How to Install And Setup Belkin Router Belkin Support
good luck
Sep 21, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I cant install a router
If you are installing the router between your ISPs modem and your PC, first you will need a ethernet network adpater that installs in your PC, you will need two crossover ethernet cables, one to install between the modem and the router and one between your network adapter and the router, once the cables are connected, turn everything on, first your ISPs modem, then the router and then the PC, once the PC is up, insert the CD that came with the router and follow its instructions and that should work!
Apr 03, 2009 | Linksys WRT54G2 Wireless Router
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
340 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
