Toshiba SD4000 DVD
I've had the signal working so the actual hookup is probably right, I mean with the red white yellow connections, but I can't remember how to get the TV set to use the signal. The store guy said use remote and press aux several times and it will look for the new device and get going. But that didn't happen
  • Dennis Renner
    Dennis Renner Dec 22, 2007
    It's an RCA F27649, Chris. Are you still there
  • 372 Answers
Hi.
What Make of tv do you own ?
http://dc07.atspace.com/
Chris..
Posted on Dec 22, 2007
What if the Seiki Tv do not have the white plug in? Please show details I do not know what a 1019 is u miss under stand the ? I ask how to hookup a DVD player to the Seike Tv that do not have a white...
You seem to think you are talking to someone you have spoken to before? This is not the case.
Do you not have an HDMI socket? The model number of the television is always useful in questions such as yours. I could find the instruction manual for it.
The connection is called Composite Video, using three plug, one is for the video signal and the other two are for left and right audio.
In home applications, the composite video signal is typically connected using an RCA connector (phono plug), normally yellow. It is often accompanied with red and white (or black) connectors for right and left audio channels respectively.
Look for any markings around your
red, yellow, red, like LEFT and RIGHT or L and R. That is the audio.
Oct 07, 2017 | Televison & Video
How to connect dvd red white cables
several types of connections possible:
A unit with yellow, red and white is yellow is video, red and white are left and right audio.
This is called COMPOSITE as all video/color are on yellow and red and white only for sound or audio.
If the DVD has RED,GREEN, and BLUE the hookup must be to similar connections on the set---this is called COMPONENT and green carries the video and red and blue the information for those colors.
Let me know if issues or questions as I am here to help you
Mar 13, 2012 | Sansui COM311AD 13 in. Combo
My screen will not work with the cable, can get sound but all imputs seem not to work.
did you mean the dvd cables,remember you have to make the right connections. use the colour codinng to guide you , the red cable to the red terminal, white to white and yellow to yellow. the red and white mostly are for sound output while the yellow one is meant for video signal.
Sep 18, 2011 | Hitachi Televison & Video
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
I am trying to hook the dvd player up to my old tv and am only getting sound, I am using the red, white and yellow cord.
I hope this will clarify things, you have 3 connections on each end.
DVD
  • Yellow Cable goes on Video Out (Yellow)
  • White Cable goes on Left Audio Out (White)
  • Red Cable goes on Right Audio Out (Red)
TV
  • Yellow Cable goes on Video IN (Yellow)
  • White Cable goes on Left Audio IN (White)
  • Red Cable goes on Right Audio IN (Red)
the coaxial audio connection does NOT need to be connected.
I hope this helps,
Magoo
Mar 10, 2011 | Toshiba SD4990 DVD Player
I have a toshiba D-VR610KU combo. Cannot get the
ACCORDING TO THE TECH AT TOSHIBA: THE UNIT MUST BE CONNECTED TO THE TV BY AN HDMI CABLE FOR THE DVD PART & (ON THE BACK-RIGHT HAND SIDE OF THE COMBO) YOU NEED TO CONNECT A SET OF THE RED/WHITE/YELLOW CABLES FROM (VIDEO) "OUT" OF THE COMBO & "IN" TO THE RED/WHITE/YELLOW TV(AV-1) PORTS FOR THE VCR PART TO WORK.
Oct 15, 2009 | Toshiba D-VR600
I have a new element hdtv and a magnavox dvd/vcr. i can't seem to hook the two together. please help
Greetings, Simple hookup would be connecting analog output from DVD/VCR player to your TV. To do this, use the Audio-Video cable which has 3 terminals at both the ends and each terminal has RED,YELLOW and WHITE pin. Your DVD/VCR player would have analog output socket where you would connect one end of these 3 pins, make sure yellow would go in "VIDEO Out, WHITE would go in "LEFT Audio Out" and RED would go in "RIGHT Audio Out", you can easily identify them cause these sockes would also have the colors on them. Now connect other end of the cables to TV, this would be input to your tv. On the back left hand side of the TV, you would see 3 sockes with YELOW, WHITE and RED colors. These are located between "Coaxial" and "S Video" labels. Connect yellow pin to yellow socket which is "Video In", connect RED pin to RED socket and White to white. Switch on the TV, play any dvd on your player. On your TV remote, press INPUT button which is located on the right hand side top corner on remote, press it and if you get the dvd player video and audio, you should repeat the button press to see the video, this button selectes one by one signals given to TV, so your dvd player input might be on the 2nd,3rd or 4th press, so go through till you get the video signals. Hope this helps !!! --Sandy.
Jun 07, 2009 | Toshiba DVR3 DVD Recorder/VCR
Hook this dvd player to an hdtv
You are confused regarding how to connect your DVD player to your Samsung TV. There is no such thing as "5 composit hookups". Your DVD player most likely has right audio (commonly red), left audio (commonly white), and video (commonly yellow) outputs which should be connected to corresponding inputs on the rear of your TV.
Dec 15, 2017 | GE 5803P Multi-disc DVD Player
Hookup
very simple , just made sure dvd output hooked to the input of your tvs and same color ,jack to jack,you know, yellow to yellow,red to red ,white to white.But I suggest you use a s-video jack(all black). instead of the yellow composite ,or RCA jack,which give you a better picture,and if you have a the component jacks (red, blue , green)on both machine , that will give you the best picture, but remember , you still have to connect the red(right channel,+))and white(left channel,-)cable to have sound coming out from your tv.You will need a s-video cable or component cables for those option I suggested.
Nov 17, 2007 | Sony DVP-NS55P DVD Player
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
