Question about Directed Dei Valet 561r Remote Start/Keyless Entry
Valet 561r won;t start car anymore. door locks still work so i don't believe it is the remote, but remote start feature no longer works. what could be causing this problem
  • 102 Answers
Is the valet switch turned off? most common problem.
do the lights on the vehicle do anything when you try to start?
Posted on Nov 15, 2009
I lost my keyless for my remote started valet 561r now i bought the keyless and i don't know how can i program it can you help me with that....??? Thanks you....
turn the key to ON, then press and release the valet/program button once, then press and hold. The 561R LED will begin to blink. While you're holding down that button, press and release lock on the remote. Turn ignition off and try it out.
Mar 06, 2011 | DEI Valet Keyless Entry System
I have a Valet 562T remote start in my Ford F250. It will start like it should off remote but only run for about 15 to 20 seconds. It worked correctly untill I had a new oil pan installed. Garage...
You need to relearn the tachometer signal. Actually they probably did not hook up the tack wire when they put the new engine in. The tach wire is usually run to the non-common wire on one of the fuel injectors. Hope this helps
Jan 17, 2011 | Directed Dei Valet 561r Remote...
Have had a Dei valet 561r remote on my Honda van for several years. Worked flawlessly. Recently, it began working intermittantly. Did not work for several days. Then worked for about a week. Then nothing....
sounds like your car battery was also replace or it die
believe it or not the remote start needs to be reprogram again
find the valet switch, this what you are going to do
make sure ac radio and any other accesorie are off
start the car with the key within 2 seconds or less press and hold the valet swith, and way until the
led turns on and the parking lights on the vehicle flash about 12 seconds
no turn off the car close the door and start the vehicle with the remote good luck
Nov 19, 2010 | Directed Dei Valet 561r Remote...
Lost Transmitter
I had a remote that didn't work and I found the 561r complete remote start system on ebay for $32.00 including shipping so I bought that and within 2 minutes had the new remote programed and now I have the main unit in case mine goes out also.
May 16, 2010 | Directed Dei Valet 561r Remote...
I have a 561r that was professionally installed and working fine for about a year. Now all of sudden my van will not fire or start the engine. The theft light continues to blink. I cant start the van with...
Try disconnecting the alarm putting in a valet mode and start the vehicle with the car key. If you don’t know how to put in a valet mode, check your alarm manual. After if the car start them the problem is the car alarm, make sure all the doors, trunk, hood are close if still not working check if the hood, trunk switch are working properly.
Jan 01, 2010 | Directed Dei Valet 561r Remote...
I want to have my valet model 561r removed it is malfunctioning my car is reviving up and dying on turns it also will no longer start the car
Not possible. The DEI's brand Valet has nothing at all, anywhere close to or connecting to the accelerator or acceleration of ANY VEH.
Oct 11, 2009 | Directed Dei Valet 561r Remote...
04 Escalade w / Valet Starter, all works but door locks
Hello 7suds,
Well, I'd go back and tell them about the doorlock problem. I know that 2 years is a little late to start complaining, but it's most likely a really easy fix.
The most probably causes are that the power doorlock output was either not programmed, programmed incorrectly, or it's not connected or improperly connected to the vehicle servos. Have the installer check the programming, especially the doorlock pulse duration. It's also possible that the remote is simply not sending the doorlock signal. Could just be a bad button. Have them switch the doorlock function to the right "AUX" button temporarily and see if that works. But in any case, the system needs to be tested to find out exactly what is causing the doorlock failure.
Hope this helps.
Jul 16, 2009 | Directed Dei Valet 561r Remote...
Vehicle lost fire
the security system doesn't disable spark, it works by not letting the fuel pump run or not allowing the starter to work, but never does it affect spark or fire as you call it.
Jun 16, 2009 | Directed Dei Valet 561r Remote...
Valet 561r remote starter wont start my 2004 gmc sierra
You should not have to... Just start it with a key first.... What are the symptoms, please be more specific..
Jan 16, 2009 | Directed Dei Valet 561r Remote...
Directed Dei Valet 561r Remote Start/Keyless Entry Logo
1,537 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
