Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Programming remote, unit will not flash.
Liftmaster security+ pro 1/3HP garage door opener 41A5021-1D front light not working and light in back will not flash while trying to program remote. 41A5021-1D unit has red button on back that won't flash to program remote which has yellow light. Remote was working before I messed with it while I was trying to program car remote (built into car) :o( Successfully programmed first remote on door #1. HELP
    President:
  • 3,197 Answers
The easiest way to program is to hold the button on the remote while you press and immediately release the smart/learn button. If it worked before there is no reason for it not to work now unless it totally failed.
Posted on Oct 05, 2009
Thanks for your useful comments
Posted on Nov 20, 2012
We have a Liftmaster garage door opener. I bought a new remote control for it - a Liftmaster security plus. I have tried to program it by pressing the button on the garage door opener, then pressing the...
YOU NEED TO MAKE SURE YOUR REMOTE IS THE SAME FREQUENCY AS THE EXISTING UNITS.
IF YOU LOOK ON THE BACK OF THE REMOTE THERE SHOULD BE A FREQ# IF THEY ARE NOT THE SAME YOU NEED TO EXCHANGE THE REMOTE.
HOPE THIS HELPS
Mar 26, 2011 | liftmaster Chamberlain Garage Door Opener...
I have a chamberlain liftmaster professional Formula 1 Garage door opener that has been working for 5 years. Now will not go down unless you hold the main button. Sensors blink when it hits within 3...
Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. They each have a small light that should be lit, both should be the same brightness and not flickering ever so slightly. If not tweak them a bit. If both lights will not come on you have bad sensors.
Sep 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Homelink wireless remote is stuck on fast flashing red light. I can't seem to clear my remote to program any of the buttons to my garage door opener. This is the second one I purchased, I had no...
Try this.
HOMELINK PROGRAMMING
  1. Clear out anything previously programmed into the in-car system from the factory by holding down on the 2-outside buttons simultaneously, until the in-car LED starts flashing rapidly. This may take up to a minute (in most cases, the key should be on auxilary, and/or the car door must be shut).
  2. Decide which button you want to make to be your in-car garage door transmitter. Hold your transmitter up near the selected button, pressing both the garage door remote and the selected in-car transmitter button simultaneously. Hold down on the buttons until the in-car, LED light flashes rapidly. This sets the in-car remote transmitter to be your garage door openers make transmitter, but you are not done. You now need to make this in-car transmitter your personal transmitter.
3. Go to the Learn Button on your garage door opener. The button is usually next to the area where the floppy antenna is connected to the motor head. With Genie it is most often behind the light lens, and an indicator light flashes red when pressed. With Sears or Liftmaster (Chamberlain) it is near, or part of, the terminal screw board, and is a red, green or purple square button with a green, amber or purple indicator light. Press this learn button momentarily. The indicator light will turn on and blink if Genie or otherwise stay lit. For Genie systems, go back to the in-car transmitter button you programmed and press this button 3 or 4 times, or until the door starts moving. This should set your in-car transmitter to your garage door opener. For Liftmaster, Sears, or Linear Megacode press and hold the in-car button you programmed until the garage opener light flashes. Your in-car is now programmed to operate your door.
Nov 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote control 139.53681 to Garage door opener model 139.53663srt2 stopped working. Changed battery but still does not open door. Are there any other steps we need to do to configure the remote to open the...
You can try programming it but if you have another remote that works and this one doesn't it probably just quit on you. To try programming it hold down the button on the remote and then press and immediately release the smart/learn button on the back of the motor unit.
Oct 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
When i push remote control, the green light flashes on the back of the unit, but garage door doesn't open.
The flashing LED shows that it is receiving the radio signal but the code may need to be set. Try programming the unit and see if that works for you.
Jul 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not work up or down,light is on.
take off console )disconnect wires). if remote works, get new console.
Dec 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door only opens with wall unit
a component in the wall unit is failing , that makes the conection happen when the remote signal is recieved , ( it is recieving the remote signal but not sending it out to the control circuit for the motor )
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage Door only opens with wall unitq
The unit is in the lock mode, push and hold the lock button in for about two seconds and the green LED should stop flashing. Your remotes should work.
Trouble changing passwordon model 940CB wireless keyless entry
easyer then that , you die! Open your garage door, take out the step ladder, a chair or get up on *********** in law's back, (here's your chance to be on her back for a change) press the read button of your unit (motor) a led should light up and on the key pad, key in the new 4 digits code and press enter, the light of the unit should blink javascript:; Post Solution
May 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,180 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
