Question about Jenn-Air JGR8875QDS Gas Kitchen Range
Jenair oven valve knob
The knobs are "chrome" foil covered plastic. Which have peeled/wrinkled from the heat of the oven. Is there a metal replacement available
  • 3 more comments
  • Anonymous Aug 20, 2008
    Yes, and they want $14 a knob to rel\place!
  • pissed in OC Oct 13, 2008
    I purchased this range in December of 2005. I even purchased the extended warranty.
    We have gone through 3 sets of knobs (very cheaply made) and 3 sets of stove top grates (the enamel finish burns off where the pots sit)!
    Up until this past month, the warranty people replaced the items that we "abused or used incorrectly"! Now they are playing hardball and won't replace/repair the problem! (and the warranty expires 12/09)
    The foil on the knobs peel or shrink, each time after they are replaced.
    Go figure!
  • fcgalegal Dec 31, 2008
    Similar problems with same this model ending RDS. The knob fell apart. I am sure it won't be the last problem as this thing is very cheaply made and certainly not what I expected from Jennair or for the price I paid. It is total ****. Part of the PLASTIC knob problem is a result of the fact that the oven seems to have NO insulation. Pots plates, dishes left on the stove top while the oven is on become too hot to touch. A bowl of dough which was left nearby to rise while the oven was on started to bake! No wonder the knobs nearly melt. This is totally unacceptable. Mine is near new.
  • Anonymous Mar 06, 2009
    Same problem with the knobs. Not at all what I expected from the Jenn-Air name. Let me guess - it was purchased by yet another (foreign?) conglomerate who figured they could make a killing by using the Jenn-Air reputation while selling **** under the name.
    Bought the stove in 2007. Third knobs purchase now.
    They need to redesign the backside of the knobs where the "D" connector is to handle the heat and stress (fat chance.)
    Jenn-Air/Maytag ought to be ashamed. Never again in MY house for ANY of their stuff.
    I'm going to order a couple of the $12 chunks of **** and when they get here, I'll coat the backside of the things with a thick layer of high-temp epoxy to try and hold it all together a bit longer.
    Unbelieveable...
    To those who think they want metal knobs, think again. You wouldn't be
    able to touch them without gloves once the thing got to work.
  • stellamarie Mar 14, 2009
    Jenn-Air 2007 Gas Range knobs melt. We have a new Jenn-Air 2007 GasRange. The knobs are made of plastic and melt from the heat. Obviousdesign/engineering error. I'm sure if we get metal knobs - it will getto hot to touch. Jenn-Aire needs to solve this problem or replace theentire range. This is unacceptable.
In less than 6 years of normal use, 4 burner control knobs on my Jenn-Air free standing gas range, Model JGR8875QDS, have either broken or melted.
If you want to continue to buy Jenn Air knobs, no problem - several suppliers will be glad to provide them for  $10-15, each (USD). Whirlpool's part number for the factory Jenn Air knobs is 74009148, and you can get them from repairclinic.com (#1035396), or PartsSelect.com (#PS2086597).
If, however, you want to try a different set of knobs, hoping to find some that are less prone to break or melt, then it gets a lot more complicated.
Jenn Air/Whirlpool will be no help; they will tell you the only knob that will work is the Jenn Air OEM knob. Parts suppliers won't help you either - no specifications or interchangeability data exists - and they are unable or unwilling to take measurements.
I can tell you the following 3 knobs will work on your Jenn Air range, model JGR8875QDS. By "work" I mean they will fit your burner controls, operate the burners just like the factory knobs, and the markings on the knobs for "Off" "Lite" and "Hi" will be in the correct positions, similar to the factory knobs. (Exception: The last knob listed has markings somewhat different than the Jenn Air knobs.)
The following knobs do NOT look like your factory knobs - all three are made from black plastic rather than the (fake) silver metal look of the (plastic) OEM knobs. What I cannot tell you is if the following knobs will be more durable than the factory knobs - but then it's hard to imagine how they could be much worse.
-------- Burner control knobs known to work on the Jenn Air JGR8875QDS gas range --------
1. Whirlpool part number 74008850, made for some Amana gas ranges, will fit the Jenn Air. RepairClinic.com calls it part #1035119, and PartsSelect.com calls Item #PS2086316; it sells for $6-7 (USD). You can see a photo by entering the appropriate part number in the search box of either of the two websites mentioned above. The Amana knob is about a quarter-inch larger in diameter than the OEM knobs, but that does not cause any problems. Of the several knobs I tried this is the only one that tells me what it's made from - "PBT" - or polybutylene terephtalate, a thermoplastic which has a melting point of 430 degrees F and a maximum utilization temperature of 330 F.
2. Whirlpool part number 74009094, made for some Maytag gas ranges will also fit the Jenn Air. RepairClinic.com calls it #1035342, and PartsSelect.com calls it #PS2086544. It sells for about $9 on both sites. You can see it here:
www.repairclinic.com/Appliance-Parts?s=t-74009094-%3d%3d
Like the Amana knob, the Maytag knob is about a quarter-inch larger than the OEM Jenn Air knob.
3. A third knob worth considering is available from AmericanStoveParts.com for $7 each. The front of the knob looks much like their OEM Replica Burner Knob 1104-B (but don't order #1104-B - it won't fit). The knob that will fit the Jenn Air is AmericanStoveParts #1214-025-B. You will have to order it by phone or email because it is not shown on their website. (As of October 2009, none of the knobs shown on AmericanStoveParts.com will fit the Jenn Air.)
Notice the markings on the 1214-025-B are not quite like the Jenn Air markings, with the "HI" and the "LITE" positions being reversed. Also, the 1214-025-B knob I received did not have the white dot at the "OFF" position nor the white ring around the periphery as shown in the photo of the 1104B knob. The total diameter of the the 1214-025-B is 2" - the same as the factory Jenn Air knobs.
While I don't think the front of 1214-025-B looks quite as nice as the Amana or Maytag knobs, the back of the knob appears to be much more robust than on the others. The extra plastic MAY make this one more durable.
Posted on Nov 10, 2009
Very cheaply mad plastic parts, I have to replace one ever several months. Found them on Amazon but they are @$11/ea.  What a rip off..  Looking to replace with something sturdier but keeping with the ss look.  Hope someone can help !
Posted on Aug 23, 2008
My oven wont turn off from the knob it keeps turning
You didn't say whether you have a gas or electric oven, or oven & stove. I'll assume you have a stove, just to cover all bases.
First, you should shut down the oven: a gas stove will have a valve on the gas line behind the stove. The valve will either have a red handle or a flat stem that usually has a hole in it. Turn either valve 1/4 turn to shut off gas, use a wrench on the flat stem. An electric stove should be shut off by flipping off the double circuit breaker for it in your electric panel. Do not unplug an electric stove when it is on; this can damage the plug &/or electrocute you.
Most likely the inside of the knob has stripped out. Look at the knob for a hole that has a setscrew in it: a small allen wrench or screwdriver will loosen the setscrew, most knobs don't have them and will pull off. Be careful to use even pressure on two sides of the knob; if you can't pull it off, use two butter knives or flat screw drivers to pry it up enough to get a grip on it.
Look at the center stem on the back of the knob, it will likely be cracked or stripped. Some stems have a D-shaped metal insert that strips out inside the plastic stem. If you have one, pull off a burner knob and compare the stems in the back, if they are the same size, put the burner knob on the shaft for the oven control, and use that knob to turn the oven control off.
If the burner knob won't fit, use your fingers or a pair of pliers (gently) to turn off the oven control shaft. If the shaft stops normally, you can turn the stove back on using either the gas valve or the circuit breaker. If you have a gas stove that doesn't have electric ignition (a clicking noise when you turn on a burner) you may need to re-light the pilots for the burners. Lift the covers off the burners to re-light the pilots.
If you have succeeded in turning off the oven, you need a new knob -- you can get one at an appliance parts store or maybe a hardware store. If the oven control did not turn off normally, I would leave the oven/stove turned off: the control itself will need to be replaced by a qualified repair person.
Mar 03, 2013 | Ovens
All the knobs on my lg gas range need to be replaced. the plastic part in the middle of the knob jst did not last and the replacement for all five knobs is at least one third of the total cost of the...
I have a $1.50 per knob solution: 1. Buy a 1/2 x 5/8 x 1 spacer at Lowe's ($1.50 each - get 5 pieces) 2. Clean knobs, remove back cover of knob and connect broken plastic parts with glue (liquid form). Make sure little metal inside the plastic is on front end. 3. Apply glue (gel form) around plastic then slide the metal spacer over. Add more gel glue to fill up space between plastic and metal. Might want to wait 30minutes then apply more glue if there is still space or gap. That's it! I recommend waiting 24 hours to let glue cure until putting it back on range. Now you can put cap back on but would need to make the whole a little wider using a grinder.I used a small flathead screwdriver and a hammer and just chip off small pieces until metal sleeve would fit. However, I think u can do without the cap if you have strong glue. I have pictures. Feel free to contact me for questions: cbraza@yahoo.com My wife is very happy, saved her a lot of money coz new ones cost as much as buying a new range itself! The knobs are very sturdy right now. Wide says it's actually sturider than when we first got the range.1_25_2013_5_53_38_am.jpg1_25_2013_5_54_22_am.jpg1_25_2013_5_54_47_am.jpg
Sep 02, 2011 | LG LRG30855ST Stainless Steel Gas Range
Chrome knobs, can't read them. substitute?
Pain isn't it? Finding compatible knobs is a problem... often they are odd shaft sizes and reaches.
CONSIDER this... remove and paint them with flat black paint and then paint a stripe where the original black on is... guaranteed compatible fit, and you can get the job done in a couple hours for paint to dry. You MAY have to lightly sand the knobs to get paint to stick but that shouldn't take long... try one first as chrome doesn't take paint very well.. If the knobs are metal thoughout, you can just take a hacksaw blade to cut where the line is to expose the metal as the pointer line. The knobs are probably sputtered plastic though...
Feb 06, 2011 | Peavey Bandit 112 Guitar Amplifier With...
Knobs wrinkle on my LG LGR30855ST range.
The plastic shaft on the knobs split and loosen. I have the solution for that, but I need one metal insert that goes over the gas valve shaft and into the knob. For those that have the split knobs. This a bit of work but it works great. Remove the two screws from the back of each knob. Go to a hardware store and find the thin brass tubing that most have. Pick the tube that just about fits over the plastic shaft. It will fit over the tip but will not slide down the shaft all the way. Now pick a brass washer that the tube almost fits into. (You have to do a bit of tooling on both the washer and the plastic shafts. What you will end up with is a brass tube soldered to the washer that fits over the plastic shaft and is screwed to the metal insert in the knob from the inside. First take the tube and file across the top of the tube to make teeth. Now slide the cutter tube down each shaft while rotating it. This cuts the shaft to exactley fit the tube. Drill the washer to also exactly fit tube and cut or file the washer to fit into the knob at the bottom of the shaft. Cut the tubes to length, press fit them into each washer (this should be very tight and solder each washer to the tubes. Place the soldered unit on to the plastic shaft of the knob. Drill two number 4/40 size screw holes into the washer. One on each side of the shaft. Just start the drill into the metal insert. Do not drill through now. Remove the metal insert. (take a small screw driver and put it into the space on either side of the metal part of the knob. Not between the metal and the plastic knob though. that may break the plastic. The metal insert comes out fairly easy. Once it is out finish drilling the holes with a 4/40 tap drill. Tap the drilled hole with a 4/40 tap to make threads. Screw the tube and washer assembly to the metal insert. The screws should be flush with the back of the metal insert. Place the metal insert back in the knob. You now have a sleeved knob that will never break again. This is how it should have been made in the first place. I did this in a few hours on a Sunday afternoon. The parts including the 4/40 drill and tape were about $13. It is not as hard as it reads. LG has a quality issue, but does not want to step up to it.
Oct 19, 2009 | LG LRG30855ST Stainless Steel Gas Range
Coating is peeling off my microwavww handle????
How nice of them!
Often it is caused by the use of hand cremes affecting and tarnishing the metal coating or the plastic pigments.Many items suffer from handremeitis
including the letters on keyboards car door handles, AC knobs etc etc.
Unfortunately it is the way of life that is associatedkin care and vanity.
Sep 02, 2009 | GE JVM1630 Microwave Oven
Ge profile range knobs melt
Same problem as well. Hoping to buy universal fit parts as GE wants $16/piece (x6) to replace the knobs. They WILL NOT cover under warranty.
HORRIBLE SUPPORT, POOR QUALITY PRODUCT!
Jun 13, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
OSTER TOASTER OVEN --- TIMER TWIST KNOB BROKE
you can get on amazon for sure. take a look here Thanksgiving essentials from the Oster brand. p.s. take a look on seller reviews. I hope this was helpful. cheers
Jan 19, 2009 | Oster 6232 / 6233 1500 Watts Toaster Oven...
I need metal replacement stove knobs.
I was able to find online some metal knobs that MIGHT work, but the prices ranged from $30 to 60 EACH, and I needed 5 - too costly for me!
The following 3 plastic knobs will work on your Jenn Air range, model JGR8875QDS. By "work" I mean they will fit your burner controls, operate the burners just like the factory knobs, and the markings on the knobs for "Off" "Lite" and "Hi" will be in the correct positions, similar to the factory knobs. (Exception: The last knob listed has markings somewhat different than the Jenn Air knobs.)
I have installed the Amana knobs (#1), and I will report back if it proves unsatisfactory.
Dec 20, 2008 | Jenn-Air JGR8875QDS Gas Kitchen Range
Broken plastic knob Durabrand toaster oven
Are there multiple knobs that are the same size? If yes, then you could try pulling off one of the other knobs (gently) and putting it in the broken knob's place. You're probably just turning a metal piece under the knob, so you can switch the knobs back and forth.
Jan 26, 2008 | Kitchen Appliances - Others
Oven bakes unevenly and burns food
When foods are burned, soggy, or baked unevenly, it generally means heat isn't being distributed evenly throughout the oven, its escaping out the door or the controls are out of adjustment. 1) Remove any aluminum foil from racks or the bottom of the oven. 2) Check the door gasket and, if necessary, have it replaced. 3) Be sure nothing is obstructing the vent. 4) Reposition the oven racks so baking pans aren't too close to the heat sources. 5) Check your baking pans. If they're dark, they may be burning your food. Reduce temperature by 25 degrees F when baking in dark metal or glass pans. 6) Recalibrate the controls.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air JGR8875QDS Gas Kitchen Range Logo
1,198 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
