Question about Nakamichi Audio Players & Recorders
While playing a CD, my Nakamichi Receiver 2 made a ''pop'' noise and lost the signal, with some smoke coming from the top vent near the front. It was in a confined area, and I believe it overheated and ''blew a circuit.'' I unplugged it but in later plugging it back in get a flashing power indicator light, the cd/tuner/cassette indicator light still works, but no sound. I would appreciate thoughts on nature of problem and cost of repair.
  • 4,234 Answers
The output section has a problem. The receiver is in "protect" mode and wioll not turn on the speakers. This unit needs service. In all likelyhood, one or more of the output transistors has shorted and hte smoke came from a resistor that fried. This is a relatively simple repair for an audio repair shop. Figure around $40 for parts for this repair.
Dan
Posted on Oct 05, 2009
Smoking and expelling liquid
Hello, that looks like your vent system had a rupture somewhere on the front near the motor its better you take the car to a workshop garage.
Thanks
Nov 22, 2013 | 1995 Pontiac Grand Am
Nakamichi CD400 stopped playing CD-R's
you may check the lens it may be damaged so it may read some cd's and the others not , also the problem may be from the burned ones the software that burns it may have some configurations that make the cd readable in some places and in other places not
Aug 23, 2012 | Nakamichi CD400 Sound Quality CD Player...
When, I am walking around with either a guitar plugged in or a lavaliere microphone. I continue to get pops and static surging sounds. Is there a way to fix this.
Hello
Although it has 2 antennae the AT201 is a single channel transmitter and receiver. As you move the transmitter about in relation to the receiver you are finding 'dead spots' in the room where the signal is reduced or even drops out completely. You can reduce the impact of this somewhat by doing the following things.
  1. Make sure there is a clear line of sight between transmitter and receiver.
  2. Move transmitter and receiver closer together
  3. Do not locate the receiver near large pieces of metal or near other electrical equipment, particularly things that have strong magnetic fields like transformers (including amplifier power-supplies) CD or DVD players, hearing loop amplifiers and loop cables.
  4. Turn off mobile phones and any other radio operated equipment that is not needed
  5. Turn the trim control on the transmitter to the maximum output that you can without causing distortion. The stronger the original signal from the transmitter the lower the related noise will appear to be (called signal - noise ratio)
  6. Turn the squelch control on the receiver up a bit to suppress noise - however doing so will reduce the strength of the output signal a bit so don't over do it.
  7. Use good quality screened cable between the receiver and your amplifier. Unfortunately the AT201 only has an un-balanced mono jack socket so this cable will be more prone to pick up radio interference than a twin core plus screen (balanced) cable.
  8. Make sure that your signal cable does not run parallel to, and close to, any mains electricity cables. If the signal cable needs to cross any mains cables it should do so at 90 degrees and the cables router well away from each other.
However the only real solution to this sort of problem is to use a full duplex (2 channel) transmitter / receiver system which will automatically switch to whichever channel is carrying the stronger signal. Typically these cost about 70% more than single channel units but they often use balanced cable outputs (stereo jack or xlr) which further reduce the propensity for noise due to interference.
Feb 02, 2011 | Audio Technica (ATW-T201-T2) Microphone
I have bought an used Nakamichi AV1. The unit powers up and the display is fine. The problem is that there is no sound output from any source (Tuner, CD, Phono or tapes) to the speakers. I get speaker...
From the initial posting of this question. (Please only update one.)
There is a switching IC inside this unit that may be the problem, but without seeing the actual unit and signal tracing, this will be near impossible to diagnose. If you have an oscilloscope, place an input signal on one of the inputs and trace the signal to the IC. It will be a TA9263 or something similar. You should see the signal on 2,4 or 6 pins. If you see the signal only on 2, then the IC is likely to be defective.
That would be my first attempt. Also check the power supply to that IC.
Keep us posted on progress.
Thanks,
Dan
Aug 17, 2010 | Nakamichi AV-10 Receiver
I'm trying to program my Dish Network remote to my Nakamichi AV-8 and can't seem to make it work. I know I'm doing it correctly because I've tested it with another receiver. Any ideas on which code I...
We would be happy to help with that. Here is a list of someof the codes that we have for your Nakamichi Receiver: 671, 748, 750, and 649.
Press and hold the AUX mode button until all mode buttons at the top of theremote come on, then release. Enter the number 2 then one of the codes for your Nakamichi Receiver provided above. Press the pound (#) button, the mode light should flashthree times. Check that the code works by trying several different functions onthe remote to make sure it will properly operate your Nakamichi Receiver. Keep in mindthat some codes may not be compatible with your equipment. If this is the case,please try the other codes listed for that device until you find one that iscompatible with your equipment.
We hope this helps you, and thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Service Representative
May 27, 2010 | Nakamichi AV-8 5.1 Channels Receiver
Rotel Receiver RX-950 AX popped and then quit
there would be life in the old girl it just depends how much you love her and how much you are willing to spend to get her fixed ?? some old rotels are still fetching good money so it might be worthwhile getting a quote
May 26, 2009 | Rotel RX-950AX Receiver
Our Nakamichi CD player has frozen up on us. Our Nakamichi Cassette Deck door won't close and prior to that it tangled a cassette tape and quit working. Both were purchased in 1991 along with a...
The CD player muigt be able to rescue by a reset top factory settings, mostly available in your manual, the cassette deck i think needs to be repaired.
Aug 05, 2008 | Nakamichi CD-35z CD Changer
Nakamichi TA-4A receiver no sound
HAI,AMP WORKS FINE , CONNACT ANY OTHER TO AMP(CD,DVD,COMPUTER,MOBILE,TV) IN BACKSIDE INAUDIO OR PRE_AMP .THEN SELECT  PLAYER TO IN MODE YOU HAVE INSAERTED.THE SOUND IS OK
Jun 26, 2008 | Nakamichi AV-10 Receiver
Nakamichi R 1 receiver
My owner's manual is long lost, what do you need to know?
I don't know what problem you have, but mine, which Iv'e had since circa 1988, suddenly developed a failrly loud whistle from the speakers. I opened it for a looksee, and by chance spotted a dry joint on teh PCB. It had never been soldered properly. After soldiring that joint, the whistle is gone.....
Lukas
Jun 09, 2008 | Nakamichi Audio Players & Recorders
CD Error
return it?
my first CD-500 had problems too. i just returned it and got a new one and the new one works perfectly.
it seems these stereos are hit-or-miss. i believe they are made in Malaysia now, not Japan, and that Nakamichi is not really 'Nakamichi' any more.
but i still love my CD-500.
Aug 28, 2007 | Nakamichi CD-500 CD Player
212 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
