Question about Maytag Neptune MAH5500B Front Load Washer
Washer wont drain or do anything else now. did read nd on display now it will not drain just hums a little when you try to do spin only or anything else you set it to do. This happened while doing a quick wash cycle.
    President:
  • 1,304 Answers
Your pump is clogged
it can be cleaned out easily
go through the back panel
Posted on Oct 05, 2009
Washer wont spin or drain
Yes, you can check the LID switch as it needs to activate the program to move forward. If the water fills up and there is no wash cycle, check if the motor hums, if so check the capacitor, check the friction on the spindle/drum. If the spindle does not agitate with movement the assembly must be reset.
Jan 23, 2013 | Washing Machines
Customer states washer will not drain/also reads ND on screen. Washer will spin when set to spin option. When set to regular wash the washer will not proceed with full wash stops and screen reads ND
the ND stand for NO DRAIN the filter on the pump is clogged,or the pump itself is clogged,the washer will not spin till it is drained,remove front panel by removing door and the screws that are opposite if it were hinged on othe side pop off front panel and check filter/pump for blockage
Aug 08, 2011 | Maytag Neptune MAH5500B Front Load Washer
When time to drain pump drains water then just hums and it wont spin, get error code f01. when i turn dial to drain and spin pump just hums drum might turn a little but it never spins. i have emptied...
f01 is main controller (board) failure.
Replacing it is the only solution.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My amana front load washer wont spin and is showing an "nd" error message. what does this mean and how do i fix it?
Hi
Thanks for using FixYa. From what I understand the error code ND means “No Drain issue”. You’ll need to check for any restriction in pump assembly. It can also be due to a restricted drain hose or loose wire at pump. If after cleaning the drain hose the issue is not resolved then it means the pump has gone bad and unfortunately needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | Maytag NFW7200TW Front Load Washer
What does the code nd stand for?
this is a no drain error or slow drain issue you need to check for anything that would or is restricting the water from draining out of the tub.
if the water will not srin then you can use a wet dry shop vac and attach it to the end of the drain hose to remove the water.
then check all your hose to and from the drain pump
Apr 13, 2010 | Amana LWA40A
Our washer wont spin fast and shuts off saying ND code. what does that mean
ND means that it is Not Draining. Does it make the same water-pump sounds that it used to make at that point in the cycle? In my machine, it sounds like a low-pitched loud hum when it's working.
It might be that your water pump needs replacing. If there is any strange sound (such as grinding) then there might be a coin or something stuck in the pump.
Sep 29, 2009 | Samsung WF337AA Front Load Washer
GE commercial washer wont spin or drain
If your washing machine is 20+ appliance years old, it's probably due for replacement.
Jul 15, 2017 | GE WNRD2050DWC 3.5 Cu. Ft. Commercial...
Washer will not spin; displays nd error
(nd) stands for no drain check the pump,and drain hose
for clogs
Dec 24, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
108 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
