Question about Whirlpool Microwave Ovens
Need to remove microwave over the range whirlpool model mh1141xmq0
  • Whirlpool Master
  • 9,098 Answers
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes if you need to send it in for service.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 06, 2009
Replacing a door switch on a whirlpool microwave
On most over the range models (you didn't mention your model number) you can access the door switches for testing after removing the grille and control panel assembly.
It would likely be the primary door switch, but that varies by model.
Also, on some models, this is caused by a blown TCO / thermal cutout / thermostat on the magnetron.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 16, 2011 | Whirlpool WMH1163XVS Microwave Oven
How to change bulb in whirlpool gold microwave
If your owner's manual does not address it, it's not meant to be user-accessed, so you will need to remove the outer cover to access and change the bulb.
If it's an over the range model, you may have to remove it from the wall.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Dec 15, 2011 | Whirlpool Microwave Ovens
Need install manual for my whirlpool wall mount microwave model#mh1170xsqo ser# trr1628838
At our Web site, we have a video available showing how to remove a typical over the range grille and control panel assembly in under 5 minutes.
You can download Whirlpool owner's manuals and installation instructions here.
Dec 03, 2010 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Need vent grille for Whirlpool MH2175XS
Go to www.partselect.com and type in the model # you will find it there.
Mar 10, 2010 | Microwave Ovens
I need to uninstall my whirlpool model mh7130xeq1 what is the best way to do this and do I need two people?
I'll assume this is over the range. If uninstalling alone please move the range out of the way. Pad the floor nearby to have a place to put it down when it comes off the wall. Be careful of the floor when moving it. Empty the microwave compartment. There should be 2 bolts or screws through the bottom of the upper cabinet that thread into the top of the microwave, these support the front and a back plate that is fastened to the wall that supports the back. Unplug the unit loosen the front support bolts, be ready when they release you'll catch about 50-60 pounds on the front. Tilt the front down and pull the cord out of the bottom of the cabinet. Grasp the microwave with both hands keep it tilted down in the front and lift the back slightly to remove it from the back plate. Set it down on the padding and celebrate success. Good luck. Yes one person can safely remove the microwave.
I found these instructions at Whirlpool they may help. Different model, same concept. Take link for instructions.
http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/WMH2205XVS_Installation%20Instruction_EN.pdf
Dec 03, 2009 | Microwave Ovens
Have a Whirlpool microwave oven, model MH3185XP. Just stopped wor
In some Whirlpool models, there are more than one fuse, and two or more thermal devices which can interrupt power to the oven.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
Please write back with more details if you need further help.
Feb 28, 2009 | Whirlpool MH3185XP Microwave Oven
I need install instruc. for a Whirlpool wallmount microwave.
sears should be able to get you the installation instructions and maint manual for this also, get on line go to sears.com and look up uour microwave part number like you did and look for the manuals
Dec 08, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Fuse keeps blowing.
couple questions -
what else is on the circuit,
and what current does the oven need
there are whirlpool over-range models with
1200watts of microwave,
1500watts of convection power, a
60watt bulb and a
375watt fan
over 15amps -20amp circuit needed
if you inadvertantly replaced a higher current fuse with a 15amp fuse, it will blow every time.
the install guide http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/8206589.pdf reccommends 20amp
not a solution, something to check,
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
167 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
