Question about Camco Boating
Power surge resulting in no oven
Hi there, we had a power surge and it resulted in wrecking some of our belongins, one of them being our oven. Our stove top is still working, it is on dials, but our oven, which has a electric touch pad, is not. Also the built in electrical outlets on each side of the oven are not working. We changed the 15 amp fuses in the top and that didn't change anything. Our Home Hardware guy said we might need to change our relay(?!) I don't know what it is, where it is or what it looks like. The stove model is GRSR3920SM-1, Serial TR 266546 V. Do you have any suggestions or ideas? Val
  • 65 Answers
SOURCE: electric surge turned off the clock,oven but the stove top works
do you have both legs of the 220v? on the board see if you have 120v at L1 and L2. if you do then you have a bad board.
Posted on Feb 19, 2008
  • 8 Answers
SOURCE: stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Posted on Oct 11, 2008
SOURCE: Frigidaire stove
I believe the oven it has a power surge protector within the appliance. Try to unplug it and plug it back in. It should solve the problem.
Posted on Dec 20, 2008
SOURCE: I have a Jenn Air 'slide-in' electric
The unit has a bad touch pad
Posted on Mar 05, 2010
SOURCE: Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
Posted on Aug 07, 2010
How can I get my oven temperature to come on? A power outage caused the "lock" light to flash and no temp is appearing.
Are you sure that you have 220 volts to the oven. It is possible for a breaker to go bad and conduct power only on one leg and some things on the appliance will still work.
Electronic controls on ovens can be damaged by power surges caused by lightening strikes. That could be the problem but after looking at the circuit diagram of the panel it doesn't look like there are electronics that should be damaged by a surge.
Here is a link to the user manual.
Download Manual Pdf
Link to Maytag Same as Whirlpool
Search Results for Appliance Models matching CWE4800A
Good Luck.
Sep 20, 2014 | Maytag CWE4800A Electric Single Oven
Power 100 code
you must try this:God bless you
If you are unable to adjust the power level, there may be a defective triac or a problem with the circuit board.
  1. Controller is confusedA power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switchesThis can result in the controller thinking the door is open and ignoring you.
  3. CleaningCleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
Nov 14, 2013 | Kenmore 66469 / 66462 / 66464 Microwave...
Hi Guys Neff oven/microwave coming up with an
make this: God bless you
Nov 02, 2013 | Microwave Ovens
Hi getting an error 4 on a Neff oven/microwave. any ideas out there
make this and fix it. God bless you
Nov 02, 2013 | Neff H7871 Convection/Microwave Oven
Power Surge - GE Microwave
see this steps and fix it. God bless you
Jul 12, 2013 | Microwave Ovens
My Tappan OTR microwave, model TMV151FB, runs but does not heat anything.
Sorry to read about your problem, I hope this helps you out.
Here is a small list, of things that could be wrong with your unit
  • Bad interlocks switches or door misalignment causing fuses to blow or no operation when the start button is pressed. Locate and replace defective switches and/or realign door.
  • Arcing in oven chamber: clean oven chamber and waveguide thoroughly. Replace carbonized or damaged waveguide cover. Smooth rough metal edges. Touch up the interior paint.
  • Blown fuse due to power surge or old age: Replace fuse. On rare occasions, the main fuse may even be intermittent causing very strange symptoms.
  • An MOV, probably on the controller, may have shorted due to a power surge blowing the controller fuse. Remove remains of MOV, replace fuse and test, replace MOV for future surge protection.
  • Erratic touchpad operation due to spill - let touchpad dry out for a week.
  • Bugs in the works - the controller circuit board is a nice warm safe cozy place to raise a family.....
Careless troubleshooting of a microwave oven can result in death or worse. Experienced technicians have met their maker as a result of a momentary lapse of judgement while testing an oven with the cover removed. Microwave ovens are without a doubt, the most deadly type of consumer electronic equipment in wide spread use.
The power supplies for even the smallest microwave ovens operate at extremely lethal voltage and current levels. Do not attempt to troubleshoot, repair, or modify such equipment without understanding and following ALL of the relevant safety guidelines for high voltage and/or line connected electrical and electronic systems.
I will not be responsible for damage to equipment, your ego, county wide power outages, spontaneously generated mini (or larger) black holes, planetary disruptions, or personal injury or worse that may result from the use of this material.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Tappan Kitchen Ranges
The temperture pilot light will only come on when the oven door is open.So therefore in the oven will only heat up when the door is open. close the door and the temerture pilot light goes out The clock has...
Problems like this are almost always control board related and are the result of a power surge/spike....
Replacing the control board should solve your problem...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Dec 26, 2010 | AEG B8139-4-M Electric Single Oven
Power surge fried Frigidare FEB24S2ASB
The electronic oven control has gone bad. The repair is a lot less expensive than the replacement of the whole stove. Part number is 903091-9051 at about 165.00 retail. You can fix rather than replace whole stove. Hope this helps.
Mar 04, 2010 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
Kebs208d THE DOOR WILL NOT UNLOCK
HI, this is a major control fault. you will need to replace the Oven control asap if possible. It has failed.
Possible causes--
*Power surge
*Failed logic(IC)
*Oven Temp Sensor failuer that has resulted in extreme temps that has overheated the board.
Jun 07, 2009 | KitchenAid KEBC207 Electric Double Oven
Oven won't work after power cut.
The power outage may have been a result of a power surge or included one. Check the surge protection, breakers or fuses, most likely found inside control panel. Of course turn power off to stove before opening up the panel. Breakers should be pushed all the way off before being pushed to the on position.
Nov 05, 2007 | Ovens
Boating Logo
114 people viewed this question
Top Camco Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Camco Boating Expert? Answer questions, earn points and help others
