Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
My belking keeps losing connection during games?
While trying to play on xbox live, my new belkin wireless internet router keeps losing connection during the game but still keeps me in the game. Its weird. If u play halo3, it keeps putting me to black screen for about 30 seconds or so then im back in the same game. Ive noticed that im pretty sure it will do that every 5 minutes or so. Its not just in game play either. If im searching for a game and every1's talking, it will go silent for a little bit then i can hear them talking again after a while.
    Problem Solver:
  • 12 Answers
If your wireless you probably need to change broadcast channels on the router ( to the last channel) if its hard wired, you probably need to port forward the ip address for the Xbox
Posted on Nov 24, 2009
Rj 45 wall connection in my room for internet. i want to go wireless mac,ipad xbox etc .can i use belkin n150
You can assuming all your devices support wireless. (Black XBox does). You may only get B or G wireless unless your devices support the N mode wireless. I will warn you that wireless on XBox can cause issues of lag while playing heavy network usage games on Xbox Live such as FPS's like Call of Duty. With the N150 you should also have wired ports in the back which would still let you connect wired devices.
What is providing internet to the RJ-45 Jack in your wall. If it is a college they may have port security turned on in their network which will not allow other Hubs/Routers to be plugged into the network.
Sep 12, 2011 | Belkin Connect N150 Wireless N Router
I have a belkin router and 2 xbox 360 connected to xbox live. whats the settings to have on the router which allows both of us to play multiplayer on games? at the moment one computer kicks us off live...
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
X-BOX
On the x-box you will need to connect to the wireless network now.
Open the main Interface of the X-Box.
1. In the Xbox Dashboard, go to My Xbox and open System Settings.
2. Select Network Settings, Configure Network.
3. On the Basic Settings tab, select your wireless settings.
4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
5. If your network has wireless security, enter your WEP or WPA key.
6. Try to connect to Xbox LIVE again.
Trouble connecting to the internet on X-box ,Play station or WII ?
You can try to reduce the MTU settings on the router. if the MTU on the router is set to 1500 then change the MTU to 1365. Also you will need to open the ports on the router.
For X-box port numbers are - 53, 80-88, 3074 .
Jan 23, 2011 | Computers & Internet
I'm trying too get connected to xbox live but it's
This mainly depends on your internet modem, I use linksys when I play xbox live. Also I use wireless adapter, sometimes an ethernet cable as well to plug straight from my xbox to my modem. Make sure your modem is connected to the internet, and that if your xbox has a signal, or properly connected to it.
Hope this helps a little. Good Luck!
Jan 02, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Change NAT to open
maybe instead of nat, set you xbox as a DMZ host. This would be done on the router itself. It will allow the Xbox to bypass the firewall and nat on the router/gateway, and at the same time keep your computer safe.
Apr 16, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belking g plus mimo 928995 NAT open help
when you solve the issue you have can I borrow a guru to help upgrade from my 2wire modem to my Linksys wireless Router?
Jan 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
XBOX 360 NAT Moderate Problem
Step 1 : Check the IP Addressof the Xbox And take a note of it
Step 2 : Open RSP By typing 192.168.2.1 on the Address bar of the internet explorer
Step 3 : On the left side Click Firewall
Step 4 : Leave the Password blank and click Submit
Step 5 : Disable it And Apply Changes
Step 6 : On the left side Under Firewall Click DMZ
Step 7 : Add the IP Address of the XboX in DMZ
Step 8 : Click Apply Changes
Step 9 : Restart the Router
Step 10 : Test the Connection
Jan 08, 2009 | Belkin (F5D9230-4) Wireless Router...
Wireless signal keeps dropping/dissapearing
Check my tip
Using Router and Wlan adapter from different brand (Dynex + Belkin) is sometime calling for trouble: you must configure both to be sure to be on same standard (or change Both).
I'm using Netgear + Belkin and tune is not easy
On router config check radio power, reduce the used standard (B/G A/N) to the only one used by Belkin adapter (N).
Be sure you removed Windows zero wireless configuration (= use windows to manage my connection= OFF)
edit your belking wireless networking utility to automatic reconnect:
try downgrading to G standard from router side
Check your network connection plugging your laptop to router via lan cable.and check network params (DHCP DNS etc.).
Then check wlan connection near router, if you experience wlan drops only when far from router, find any possible interferences source (Microwave, cordless, remote) remove it or be ware you cannot have wlan when your wave is working.
Dec 13, 2008 | Dynex Enhanced-G Wireless Broadband Router
Belkin F5D9230-4 router with xbox live
I was having troubles with a belkin router as well. i called belkin tech support and they never helped as they would not accept that the router was the problem. i found i could connect the xbox directly to a modem and it would work fine but when i connected it through the router it would always disconnect from games or not allow me to join a game, only host them, with no one else joining. no matter if i forwarded the appropriate ports, put the specific ip address into the dmz or even turn upnp on (i've tried different combos of each, all on at same time, to even setting up manually) and nothing would change. I found that the router had an option to turn off NAT which belkin told me would render the router useless.  I decided to go against them, turned it off and set the ip and dns to go with the modem. Now everything works fine as the router just acts as an expensive multi plug and wireless system. all the computers in the house can connect to the internet at the same time and access eachothers hard drives and i can access xbox live fine with no problems. there is also no lag when playing gtaIV multiplayer with 15 other players.  i hate belkin tech support and i will not pay for another expensive multi plug connector from belkin... ever.
Mar 06, 2008 | Belkin (F5D7230-4) Router (587009)
Hooking up xbox live
Well, it's very possible if you are using a wireless router that your connection may not be strong enough. XBOX Live and most online gaming requires a steady. strong, high bandwith connection. A weak singnal, OR someone else using up the bandwith (i.e. someone downloading music on another computer connected to your router) can cause the problem.
If you're using a wireless connection, try moving the router and wireless game adapter closer to each other.
If you're using a hardwire connection from one of the routers outgong ports then make sure other's aren't on the internet (Or at least aren't using alot of bandwith) while XBOX Live is being used.
Please remember also that if you have a wireless network and you haven't implimented wireless secruity (i.e. WEP or WPA encryption) then your network is "Open" and anyone within range can connect and use up your bandwith,
Feb 24, 2008 | Belkin (F5D7230-4) Router (587009)
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
434 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
