Question about Danby DDW1805W Designer Series Free-Standing Dishwasher
I have a Danby countertop dishwasher. Today the sprayer arm has stopped completely. The dishwasher does everything as usual including pumping water in and out but the sprayer will not work at all. If the sprayer arm is not motor operated then how do i fix it? Anybody have any ideas/ suggestions? Thanks. If the sprayer arm,
Two things that you have to check with this dishwasher.
1) The float box occasionally has to be taken apart and cleaned, otherwise the dishwasher does not sense when it is full and it overflows and then throws the error code and it drains.
2) There is a plastic line that runs from the rack area on the stainless steel wall to the pump. Sometimes this gets plugged with food and the wand will not spray if this gets plugged.
Posted on Apr 02, 2014
    Scholar:
  • 90 Answers
You may be able to find your answer at the link below:
http://www.retrevo.com/support/Danby-DDW1805W-Dishwashers-manual/id/886dj686/t/2/
Posted on Oct 05, 2009
My Danby countertop dishwasher won't wash-the dishwasher detergent is never used at the end of the wash and nothing is clean
Was it working before, and now has stopped working? If so, it sounds like it has poor water circulation. It might be caused by a leak. If you have not noticed a leak, it might be clogging due to hard water deposits. Do you live in a region with hard water?
Feb 10, 2014 | Danby DDW497W 22 in. Countertop Dishwasher
I turned on my Danby countertop dishwasher without water! and now it does not work at all. Someone help me please, how can i fix it!!!
unless it ran for quite a while there should be no damage. plug it into the water, add a few cups of water to the water to fill the sump and prime the pump and turn it on it should work then.
Our danby at home shuts itself off when there is no water so I'm assuming thats what you are seeing.
Aug 23, 2010 | Danby DDW497W 22 in. Countertop Dishwasher
Danby Designer Dishwasher sprayer arm stopped working
is anything in the way of the arm? Sometimes you can't see an item sticking down too low ... interfering with the spinning.
Oct 05, 2009 | Danby DDW1805W Designer Series...
It is filling and running but the water is not
Could be two different things -- either the pump is not moving water through the sprayer arm, or the sprayer arm isn't free to spin around.
I've fixed one of each in the past year, so either is reasonable.
First, check the easy one -- the sprayer arm.
Open the dishwasher and pull the bottom tray forward so you can reach the sprayer arm.
Reach in and try to spin it around by hand. It should move freely, and if you flick it around, it should spin a full turn around before stopping.
If it's unable to move at all, then look for something stuck like a fork or plastic bag.
If it moves, but very quickly stops spinning, it might be a foreign object or it might need a new sprayer arm assembly. The one I got this year was $38 including shipping.
If the sprayer arm is free and easy to move, then check the water pump:
Start the dishwasher and listen. When it's done filling and sounds like the wash cycle, quickly unlock and open the door.
It shouldn't spray water in your face, but there should be lots of water dripping from the racks and the top (and the dishes, if it's loaded when you do this test!)
If not, then the problem is either a failed main pump or a blocked pump, and the repair will be a bit more money and a lot more time.
If this helps, be sure to click the thumbs-up to tell me so!
Sep 01, 2009 | Maytag Dishwashers
Danby DDW399W dishwasher - drainage and spin arm problems
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Nov 19, 2008 | Danby 22 in. DDW396 Free-standing...
What does E3 mean?
E3 not hot enough. This defect can be caused by, but not only, a defective element or clogged spray arms.
Sep 29, 2017 | Dishwashers
Inside on the back of the tub, there should be a grate with screws that come out. Check for obstructions around the pump area. There may be food debris settling in the sump pump area
Jul 06, 2008 | Dishwashers
I have a Danby DDW399 W countertop dishwasher
I have a Danby DDW399W countertop dishwasher. I need a replacement tap attachment and haven't been able to locate one. Email buddysmom@telus.net
Jan 14, 2008 | Danby 22 in. DDW396 Free-standing...
Danby Countertop Dishwasher Spray Arm not turning
now ya need to find out how the food got by the screen and into the pump motor to get shot into the spray arm
Dec 29, 2007 | Danby 22 in. DDW396 Free-standing...
Danby DDW1805W Designer Series Free-Standing Dishwasher Logo
286 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
