Question about Refrigerators
Crosley conservator is freezing, fridge not cooling
My crosley conservator refrigerator is freezing, but the fridge is not cooling. i have tried turning it off for about an hour, but that didn't work. there is no cold air coming from freezer to fridge. the openings on either side of blower feel like there is ice built up inside them...don't know if this is normal.
  • 4,070 Answers
No, it is not normal. The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Posted on Oct 05, 2009
My refrigerator keeps freezing things...,.changed the gaskets around door and still have the freezing probkem
Most fridges have a cooling vent above or on the side of the top shelf. This is where most of the cold air comes from, so keeping food away from here may preventfreezing. ... Some side-by-side refrigerators (particularly older models) feature a vent that funnels cold air from the freezer into the fridge.4 Aug 2015
How to Prevent Your Refrigerator From Accidentally Freezing Food ...
refrigerators.reviewed.com/features/how-to-prevent-accidental-food-freezing-in-fridge...or try this link... refrigerator keeps freezing things Google Search
Oct 23, 2017 | Refrigerators
Jenn air refrigerator jcd2389ges freezes fridge
Bea, try this. UNPLUG the refrigerator for 12 hours and keep the fridge and freezer doors open. You might lose some food. NOW you will find some water under the fridge. clean that and now power up the fridge. Make sure you hear the motor working. Your fridge will start cooling. Keep at recommended temp.
Mar 07, 2014 | Jenn-Air JCD2389G Side by Side...
Refridgerator side-by side dripping water drips to floor and freezing on bottom of freezer compartment
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 06, 2011 | Crosley CRFF16 15.9 Cu. Ft. Frost-Free...
Hello
Sounds most likely it's just dirty, Unplug the fridge and pull it out and check out the coils on the back and or bottom of the unit. The coils need to be free of dust, pet hair, for it to work properly. It is very common reason for fridge cooling problems. If it is an old unit than it could be the coil inside and that would require a bit of work on your behalf.
Please respond back with results and vote if I have helped you in any way Thanks Dan
May 22, 2010 | Crosley CFFH10W Top Freezer Refrigerator
Crosley side by side. freezer/refrigerator. Has ice maker/water. Question is why is the fridge side freezing things. Its on lowest setting? I tried cleaning out the coils that were under the fridge.
there is a damper control on the top left of the fridge compartment that may be stuck in the open positin open the fridge door and turn off the unit completely you should be able to here the damper door close. if you do not it may need to be replaced,and or your thermostat for the fridge needs to be replaced.
Feb 23, 2010 | Crosley CFFH10W Top Freezer Refrigerator
Crosley fridge will not stop running?
Check the seal (gasket) around the door. If the seal is not sealing properly the compressor has to keep running all the time.
Aug 07, 2009 | Crosley CRFF16 15.9 Cu. Ft. Frost-Free...
Crosley Frost free Runs continuously
Try not to panic firstly, if you open the door and it starts to run then it was not running before hand right? or did I miss something?
Temp guage or thermostat I think this is one and the same leave it at a midway position for a while and lets see if it reaches temp in the fridge or not.
Jun 24, 2009 | Crosley CRFF16 15.9 Cu. Ft. Frost-Free...
Crosley Servidor WCR17/E K3 Top Shelf and Drain Plug Freezes Over
first thing I would suggest is to flush the drain line. defrost any ice in the drain and then flush warm water thru the line until it flows freelyif  your having a hard time getting the line flushed out you may try using a large syringe or turrkey baster filled with warm water to forcfully flush water thru the line. this will most likely fix the problem.
you didnt mention if food was freezing in the refrig as well as the drain but there may be an off chance that the temperature control could be bad. since this is a manual defrost unit it depends on above freezing temps to help keep frost off of the cooling coil. if the temp control goes bad it will allow sub-freezing temps and possible drain freeze ups. so if the drain continues to freeze you will need to replace the temperature control.
if it comes to that, the control actually has a part number on it since maytag cant find your model number.
message me back if you have any further questions. thx peyton
Jan 30, 2009 | Crosley CRS40 Manual Defrost Compact...
Refrigerators Logo
838 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
