Question about Garden
Replaced coil breaks down when it gets hot. spits & sputters. have changed coil 2 or 3 times . keeps breaking down.
  • 148 Answers
Does this machine have an electric fuel solenoid on the carburetor bowl?
If so, shutoff fuel supply to the carb and remove solenoid. Check for sticky operation using your finger pressure olny. If sticky, spray and spray and work with finger to free it up. Then spray once more!
Blow it completely dry and bench test it with a 12vdc source AWAY FROM FLAMMABLES!
It should snap down quick, nice & firm with power on and rise back in the same manner when power is interrupted.
Hope this helps.
Posted on Oct 05, 2009
2002 kia sportage spitting and sputtering no power at all, changed coil packs , checked for spark its fair/poor. Idols very low even in park and neutral. Thinking timing may be out.... Please help driving...
Is the check engine light on ?
Normally if a timing belt fails, it breaks or otherwise stops turning the cam. So it could be a couple of teeth off, but that would be rare.
Have you checked base fuel pressure with a gauge ?
May 29, 2013 | Cars & Trucks
96 honda accord trouble starting, spit and sputter with no rpm's, give gas and it shuts off
Check your timing belt, Most honda's are interference engines and when the timing belt breaks it causes more serious problems
Oct 14, 2012 | Honda 1996 Accord
I have a John Deere 170 ( Kawasaki Engine), after mowing about an hour and get in some taller grass, it starts to sputter and then stalls. It will start up but still sputtering and stalls again (...
it sounds like the coil is breaking down at high temperatures. when a coil gets hot it expands. when it cools off it work right. i would change the coil and try it. i think that will solve your problem.
Sep 26, 2017 | kawasaki Garden
MY CAR LOST POWER, STARTED BACK UP AND ONE PERSON TOLD ME TO CHANGE THE SPARK PLUG WIRES BECAUSE ONE OF THE 4 CYL WAS NOT GETTING POWER, WE DID THAT BUT IT STILL IS SPITTING AND SPUTTERING WHAT COULD IT...
Follow the number 4 cylinder spark plug wire back to that ignition coil.
Verify that the wiring is getting voltage approx 12 volts with key on and that ground is good
Make sure that the wiring going to that coil is not corroded, broken pins or breaks in wiring
Jan 20, 2011 | 1997 Saturn SL
My nrg keeps booging out when i ride it
change the coil its breaking down under pressure dont be fooled by it giving a good spark its only when its hot that it breaks down
May 19, 2010 | RTO 50cc Moped Scooter
Coil breaks down when it gets hot. it spits & sputters. have changed coil 2 or 3 times. keeps breaking down.
I think you MIGHT have the cart before the horse ... what is the problem? you think the solution is replace the coil. Whats happening?
are you points or breakerless ignition? Is it set correctly?
You running off the fly wheel or from the battery?
Your plug wires are in good shape?
Oct 05, 2009 | Garden
Stops firing on middle 2 cylinders when it gets to running temp
The coil is probably breaking down internally when the heat rises. The only other possibility is the electronic ignition going bad. Have a dealer check the bike before spending bucks on a new coil when the old one may actually be good.
Please rate this solution. Thanks! :)
May 21, 2009 | 1999 Bimota YB 11 Superleggera
96 dodge grand caravan help me please
Check MAP sensor. If PCM gets wrong data from MAP sensor it should offset ignition timing and/or make fuel mixture too lean or too rich.
Nov 05, 2008 | 1996 Dodge Grand Caravan
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
