Question about Minolta DI-2010F Copier
Di2010 i would like to install fax and network printing capability on my di 2010 can this be done?
  • 146 Answers
A Print Controller can be installed.
Network print kit: NC-4 PCL Print Controller:
http://www.amatteroffax.com/ItemPage.asp?INVID=1047235&CT=1&CRY=%B4o%B8s%E7PQ%5D%60vT%B1%C8%F5%C9%87%BA%D2%B91%98%1FC
or a
Pi3505e Minolta PN:4513-612:
http://www.amatteroffax.com/itempagey_INVID_1047328_d_Minolta-Pi3505e-PostScript-3-+-PCL-Print-Controlle.htm
or you can install both if you wish.
I haven't found any data supporting the addition of a fax expansion kit. These models were before the FK-502 slide in expansions and I believe that's why the also sold the Di-2010f with the fax.
A network fax option, however, is available with the network scan kit.
Fax Kit:
Posted on Jan 02, 2008
Can a Di2010 be connected to computer
You have needed a printer driver in PCL format,and scanner driver TWAIN or Page scop cabinet
Feb 10, 2013 | Minolta DI-2010F Copier
Fax driver missing
Microsoft Office 2010 has a feature that lets you send Outlook, Word, Excel, and PowerPoint files as Internet faxes. This feature relies on having the Windows Fax Printer Driver or Fax Services installed on the computer to send the faxes. The Windows Fax feature is not enabled by default for all editions of Windows. If your edition of Windows includes the driver or service, you must install it before you can send Internet faxes.
Which operating system are you using? Windows 7
  1. In Control Panel, click Programs, and then click Programs and Features.
Note In Classic view, double-click Programs and Features.
  1. Click Turn Windows features on or off.
  2. In the Windows Features dialog box, under Print and Document Services, select the Windows Fax and Scan check box.
  3. Click OK.
za010077668.gif Top of Page
Windows Vista The Windows Fax Printer Driver is included in the following editions of Windows Vista: Business, Enterprise, and Ultimate.
  2. In the Windows Features dialog box, select the Windows Fax and Scan check box.
  3. Click OK.
Windows XP
  1. In Control Panel, click Add or Remove Programs, and then click Add/Remove Windows Component.
Note In Classic view, double-click Add or Remove Programs.
  1. In the Windows Component Wizard, select the Fax Services check box.
  2. Click Next.
Windows Server 2008 To create a fax server, you must install the Fax Server role. This installs the Fax Server role page, Fax Service Manager, Windows Fax and Scan (with faxing capabilities only), the Fax service, and the Fax printer.
  1. In Control Panel, under Programs, click Turn Windows features on or off.
  2. Right-click Roles, and then click Add Roles.
  3. In the Add Roles Wizard, under Select Server Roles, click Fax Server role.
Note If Print Services are not installed, you are prompted to install it.
  1. Click the users or groups that you want to send faxes.
  2. Click who you want to have access to the fax server inbox.
  3. Click Install.
Windows Server 2003 The Fax Service is included in all editions of Windows Server 2003 except the Web edition.
  1. In Control Panel, click Add/Remove Programs.
  2. In the Add/Remove Programs dialog box, click Add or Remove Windows Components.
  3. In the Windows Component Wizard, select the Fax Services check box, and then click Next.
  4. If you want to share the fax printer so that everybody in the network can send and receive faxes, click Yes.
  5. Click Finish.
Click here for fax driver
Jul 26, 2011 | Office Equipment & Supplies
Can I do network scanning with hp laser jet 3055 printer
Yes you can print, fax & scan with HP Laser jet All-in-one through LAN port (wired or wireless). Un-install and re-Install driver and Check "Extended Capabilities" when prompted.
Feb 16, 2011 | HP LaserJet 3055 All-In-One Printer
DOES THE MACHINE HAVE FAX CAPABILITIES? DO YOU
No. They have print,scan and copy capabilities but no fax option is avail.
Dec 17, 2009 | Canon imageRUNNER 5000 Copier
How do you add Lan capability to machine?
1. pull side cover and establish that you have a pci slot free ( peripheral component interconnect ) which will be located at the bottom left hand on your motherboard and they are white in color .
2. if you have one free , go to a computer store and purchase a network card . they will come with a disk to which you install the driver from.
3.connect your category 5 cable and voila ....done
Hope this helps !
Oct 09, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Can I print via my wireless network with HP OfficeJet 6310xi?
Nothing helps. Print servers are capable of connecting a multifunction printer for printing capabilities only. For scanning, you have to connect directly to the Computer or by a Multifunction printer with wireless capabilities.
Jan 15, 2009 | HP OfficeJet 6310 All-in-One Printer...
Faxing
You need Option, AR-FX7 (FAX) installed, real easy to figure out, look at the side, if you see a telephone line, with line and telephone connections (not the Network connection) then you have a fax.
Next your arm237 will also need to be able to print from the nextwork.. if this is all together..
you will need a driver called, PC to Fax for the AR-M237.
which you can find at www.sharpusa.com
Then you will have to set up the computer in the printer folder to PC to Fax.
Sep 29, 2008 | Sharp AR-M237 Copier
Problem in networking minolta di 520/620
do you have the optional print controller installed? if not you would need to buy one.
Jan 26, 2008 | Minolta DiALTA Di520 Laser Printer
Printer not being detected
Have you gone into the printers and faxes folder and on the brother printer properties(right click) make sure that sharing is enabled. Also look tto see that it is online.
May 03, 2007 | D-Link AirPlus DI-524 Wireless Router
Minolta DI-2010F Copier Logo
190 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
