Question about Panasonic SC-HT740 System
F61 code after a speaker wire touched the chassis and sparked
I was hooking up the speaker wires and one touched the chassis and arc'd. F61 came on the unit is dead. Is there a reset or something. I can't believe this thing dies so easily... thanks..
  • 4,234 Answers
You have shorted the speaker wores and blown the output amp pac. Depending upon the model, the replacement part varies from $75-$95.I don't have a listing for the SC-HT740, but the cost range should be accurate.
Dan
Posted on Oct 05, 2009
Have a 2002 chrysler town and country, stumbles and back fires, have a code p0302
#2 cylinder misfire. Plug, wire, or coil pack. One of them is bad. My guess is the coil pack. Pull the wire off the coil, lay it on top the coil close to the #2 port. Start the van. You should see the coil throwing an arc to the plug wire. No arc replace the coil. If you have arc, then replace the plug and wire. I would do all of them.
Feb 14, 2015 | Chrysler Cars & Trucks
F61 on panasonic SA-AK220
There are no error codes in the users manual. In this series of models panasonic has standardized error code meanings. F61 means a failure in the power out circuits. Your first option is to remove all your speakers and the associated wiring with the power off. Repower unit and see if error is still there. If not, you have a speaker or wiring problem. If still there, you have an internal failure requiring service.
May 19, 2012 | Panasonic Audio Players & Recorders
When car is hooked up I get visuals, lights. etc. but no sound transmits from the stereo to speakers. I have checked all speaker connections and RCA jacks, along w/ amp and subwoofer and all are connected...
The illumination wires (orange, not yellow. Yellow is for 12 volt in) would not have an effect on sound. Either the internal amp is blown or you have a shorted speaker which is preventing the internal amp from turning on. Disconnect all speakers and hook a KNOWN GOOD one to an output. I f you get sound, the problem is in the car, if not, the problem is in the radio. If you accidentally crossed two of the speaker wires or let one touch a chassis ground, you blew the amp.
Jul 01, 2011 | Car Audio & Video
How do i hook up two speakers to a deh-21001b pioneer radio. I dont want the four speakers
Hook 1 speaker to the white (+) and white/black (-) wires and the 2nd speaker to the gray (+) and gray/black(-) wires.
The green and the purple wires are the other speaker wires dont use them cut them so they are connected to anything and tape them with black electric tape so they wont short out and touch the chassis of the car by accident. Also dont let them touch each other too thats why you have to tape the exposed wires and insulate them. Many people forget to do that.
Apr 09, 2010 | Pioneer DEH-2100 CD Player
PROBLEM F61 ON MY EQUIPMENT AND SHUT DOWN
You possibly took out the output ic by crossing speaker wires or touch one to the case when the other was in the terminal. (turn off and unplug when moving speaker wires)
Before taking it in remove all wires unplug power cord wait 30 seconds and plug just the power cord and turn on. If it still goes to f61 it's going to most likely need the output ic replaced.
$70-90 labor and about $100 for the part.
Nov 11, 2009 | Panasonic Home Theater System System
1993 buick century. motor noise stsrted coming out of speakers even with volume turned down.orig equipment
spark plugs been changed ? cheap plugs can cause this. spark plug wires ok? broken spark plug wire can cause this too or one just arcing to ground pass a loose boot raise hood after dark and run motor watch over all wires to see anything noticeable. Dont touch anything while running or things could go bad for you fast... some electric fan motor have a filter bolted to them this could be? does it vary with the engine? or stay one level? if all else fails it might be easyer to pick up a filter and install it in the power cable to your radio?
Aug 07, 2009 | 1993 Buick Century
F61 pops up as a error code on stereo
try starting out with volume low. And check to make sure no wires are touching I believe this is a circuit protection code
Jul 07, 2009 | Audio Players & Recorders
Panasonic stereo SA-PM28 displays fault code F61 then switches off
Hi dearnley1
The error code your unit is presenting relates to either a speaker cabling fault or a fault speaker. Sometimes, it is neither, and may be a fault inside the unit. Needless to say the unit is in protection moe to prevent more damage occurring. Check you speaker wiring for any short circuits or frayed wires. If all appears to be ok, disconnect the wires from the unit and see if it turns on and stays on then. If it still presents f61 with speakers and cable disconnected, then I am afraid that you may need to take the unit to a Kenwood service center near to you for an inspection . Good luck
regards
Graeme
Apr 06, 2008 | Audio Players & Recorders
Speaker Failure
search for a short to chassis when you mount the speaker,there's no problem if the magnet touch the chassis. you can test the cables with a multimeter.check if the tiny flexible cables on the speaker touch metal when is in movement. (on sound).
Sep 17, 2007 | Rockford Fosgate (P210D4) Car Subwoofer
CODE F61
F61 tells you its a power source problem according to the manual. to all F61 error it is very likley that the str470-050a reg legs desolderd and have broken away from the main body of the regulator giving you the f61 and shut down.
Jan 12, 2006 | Technics SCEH790 CD Shelf System
Panasonic SC-HT740 System Logo
605 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
