You can use the previous solution, but you will need a driver to convert the text to ZPL, which is the programming language the printer uses. So, if you use word, download the printer driver from Zebra's website, http://zebra.com/id/zebra/na/en/index/drivers_downloads.html
and select this model. Then when you print from Word, you can select this printer to print.
Just like you would any printer. You could use word but word by default is set for a 8.5x11 full size paper so it must be configuared under file, page setup. Your label size gets entered and margins are zeroed out, or use the free label software called zebra designer which can be downloaded from this link.
Hi, I am having Zebra TLP 2844 barcode printer.I have installed the printer in my machine. I have...
(More)
Hi, I am having Zebra TLP 2844 barcode printer.I have installed the printer in my machine. I have tried to take barcode labels.From application, for each and every label i need to generate the label in PDF and the i need to take print. I need to take print directly from the application. Kindly assistance me. Regards, Ramesh ramesh.perumal@csscorp.com
i have installed a zebra printer drivers correctly.. but once i send a test page its starts to blink...
(More)
i have installed a zebra printer drivers correctly.. but once i send a test page its starts to blink red light am currently running windows xpsp2
My ZPL2 command is: ^FO230,250^AF^FD&wz_descr&^FS where wz_descr is a variable with...
(More)
My ZPL2 command is: ^FO230,250^AF^FD&wz_descr&^FS where wz_descr is a variable with value of 'RUBBER POLYCHLOROPRENE POLYMER' what gets printed on the label is 'RUBBER POLYCHLOROPRENE PO' Why does it print 6 spaces between the word RUBBER and the next word POLYCHLOROPRENE
