Question about Dell E228WFP LCD Monitor
Power button not working, willing to try to fix, just need to know how to open it up
  • 1 more comment
  • Jim Taylor Jan 14, 2010
    Thanks, No warranty :(
    But I found out how to open it up and was able to resolve the problem :)
  • Lou Ebert May 11, 2010
    se20417, First make sure that all cable and power connections are good. Do you think that the "ON/OFF" button has really failed due to over use or some form of ABUSE? The typical lifespan of a switch of this type should be > 20,000 actuations!!! 2 pushes a day= 10,000 days= about 27 years! I suspect that your LCD power supply (SMPS) is not starting up or at best is going into what is known as SHUTDOWN MODE to try and save itself from a catastrophic nonrecoverable failure. Sure you can open up the monitor, but do you own a DMM that you know how to use? You can go to YOUTUBE and view some video clips of LCD monitor disassembly to get an idea of what you are getting yourself into and then let me know what plan of action you will be taking. You may also want to search web for the reasons that "switch-mode-power-supplies" fail, and "swollen capacitors", and visit www. badcaps.net and or www. ccl-la.com/badcaps.htm for more info. I'm louie12fix on fixya or lmistyrel@ aol.com Bye for now.
  • Jim Taylor Feb 25, 2012
    That is exactly what was wrong with mine and quite likely a host of others. Very poorly designed! I drilled a small hole in the monitor bezel directly opposite the actual switch and now that it is back together and working well I use a paper clip to turn it on and off :)
    Problem Solver:
  • 7 Answers
I have a similar problem on my E228. I opened it to discover the power button was broken. Specifically the switch itself was fine and if you pressed it, the monitor worked but the plastic button that presses on the switch was bad. The part that lights up has a little plastic "ear" which presses on the switch. The ear is not well supported and broke off. Hopefully there is a similar part on one of my other Dell monitors.
Posted on Feb 25, 2012
  • Alan McCormick
    Alan McCormick Mar 13, 2014
    I had to cut a groove in the power switch and glue in a sturdy piece of L shaped plastic cut from a pill bottle to strike the button. It has worked for over two years.
  • 69 Answers
CALL DELL GIVE THE 20 DIGIT SERIAL NO AND SEE WHETHER ITS IN WARRANTY IT HAS 3 YEARS WARRANTY GET A REPLACEMENT MONITOR IF IT IS IN WARRANTY CHEERS
Posted on Jan 14, 2010
My tv power button is just flashing not switching on
Try resetting it by unplugging and waiting 60 seconds before plugging it back in.
If that doesn't work, most likely the power supply board needs to be replaced.
If you don't know what you're doing, DON'T OPEN THE TV UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE TV IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
Sep 20, 2016 | Televison & Video
Locked dvd tray.
have you tried to unplug the unit from the mains power wait around a minute and power back on if not press the setup button on the remote and reset to factory defaults.
Thanks J
Feb 16, 2008 | Televison & Video
Oregon scientific meep power button
OSI does not repair power buttons and opening your Meep tablet will void any remaining warranty. Having said that, some people have reported that they've opened their Meep and fixed the switch themselves. You might try a Google or YouTube search for their advice.
Apr 24, 2014 | Oregon Scientific MEEP Kids Tablet
My laptop fan was not working
You did not say whether the laptop boots up or is dead.
Check the following:
1. Defective Battery will cause laptops to not power up
2. Defective AC power adapter
3. Try vacuuming the open grills on the laptop to suck out any debris clogging the fan
These are about the only things you can check as a consumer without opening the device and troubleshooting at the board level.
If none of these work then the laptop needs to see a MBD (mainboard doctor)
Nov 19, 2013 | Lenovo IdeaPad S10-42312CU Notebook
2005 Chrysler Town & Country. Passenger side window problem.
HAVEK 1005 sounds right on track.... but also try this, usually works well for non functional power windows, specially Caravans.
NO COST PROCEDURE TO FIX IT:
1. Sit in vehicle, on seat next to problematic window
2. Ignition key is on
3. Door in question is opened (in case you closed it)
4. While door is open, press and hold power window button in desired window travel, keep button pressed !!
5. SLAM hard the door closed with one hand while other hand holds button as per #4.
6. Watch window operate as it should.
7. Repeat 3-6 if necessary, but usually the first try works!
NOW, for the naysayers that says you must replace power window motors etc, at $$$ cost because the above fix does not work, or is not long lasting fix, or less than a "professional fix".... Well then, when the window fails to operate again, apply same fix again at that time.
I have fixed my van this way numerous times (usually once a year), and to all local friends I recommend this fix too, likewise do the same and are happy with the solution.
Jun 24, 2010 | 2005 Chrysler Town & Country
How do u fix a laptop touchpad buttons?
Hi, click on the "Start Button" in the (right, pane) select to open the Control Panel, next open the [Hardware and Sound] applet. Next in the "Mouse Properties" (window) click on the "Device Setting" button, once the window open, click on the "Setting" button just below the "highlighted" (Name of the device TouchPad. Try out some of the "items listed" Tapping, Virtual Scrolling... "You must click on the "Apply, OK buttons when finished." Note: Restart the computer; this will make sure the changes are correctly applied, and working properly. "Rating the solution will let me know if the problem is fixed, or you will need further assistance, thanks."
May 29, 2010 | Dell U0636 Mouse
I want to know what is the problem with my tv because why it does not turn on
Have you tryed the remote? the power button on the tv could be bad
Could be a fuse, or power strip if your useing one,,
If not the power supply may need to be worked on,, Sorry to say if its not something small, it could cost more then its worth to fix,,
If you know someone that will help you[if needed] open it up and check the main and secondary fuses on the power supply,, the board the power plug go's to..
Opening a tv can be varry dangerous!! tuch the wrong thing and your on your way to the hospital or worse..
I cant strees the fact enough to be safe,, make sure you or your help know what not to tuch, or how to discharag the TV first!!
Nov 28, 2009 | Sony Grand WEGA KF-50WE620 Television
Whirlpool Duet HT WFW9200SQ Ser CST50067K7 Power Problem
I have the same problem. Did you ever find the solution to this problem?
Dec 10, 2007 | Whirlpool GHW9200L Front Load Washer
Jammed camera
A temporary fix to power up is to press the menu and power button at the same time. When the lens is extended and it beeps, on my camera , the lens is *stuck* Give it a gentle tug , then try the power button again
Oct 19, 2007 | Samsung Digimax S800 Digital Camera
Dell E228WFP LCD Monitor Logo
433 people viewed this question
Alun Cox
